Question about Intel Pentium 3 , 450 MHz Pentium III (SL364) Boxed Processor
USB 2.0 driver
I have PENTIUM III Dell Dimension computer and need to know if I can install a high speed USB 2.0 driver on my computer. If so, can I use any intel driver or do I need a specific one and where to get it from?
Thanks
  • Kunnath Jan 13, 2009
    I have an Intel Pentium II machine. I would loke to install a USB port and use it. Can you let me download the appropriate driver?
  • Kunnath May 11, 2010
    I agree my machine is old I do have a psi slot and I have already installed the card holding the USB port but I cannot see the USB drive in Explorer because the USB port needs a driver update. Can you tell me where to find the driver so that I can download it?
    President:
  • 1,073 Answers
Yes you can, and it ea´sy to do if u have a free psi-slot
And drivers can always be found if there isent a driver-cd following whit the item
But, in not sure that you can use the benefit and full speed of an high-speed usb since your motherboard is a litlle bit old and so is the bus-speed on it.
Good luck
Posted on Dec 07, 2008
Intel Pentium 3 , 450 MHz Pentium III Want a Lan driver
the lan driver is sused realtek download the realtel ethernet card drivers and install in your system
Aug 23, 2011 | Intel Pentium 3 , 450 MHz Pentium III...
Where is the sound card located in a dell dimension 1100?
The sound is integrated onto the motherboard in this model, it isn't a separate card.
Jan 01, 2011 | Dell Dimension 1100 PC Desktop
1 out 50 times I turn on my Dell Dimension E520 there is no signal to the monitor. I have tried to install a new PCI express card instead of using the integrated graphics but the result was the same e.i no...
The problem is the Power Supply. Weak voltage power rail.
You've taken the right steps with your diagnosis.
1) Start with the monitor cable. If removable use a known to be good monitor cable.
Checks okay, go onto the graphics 'engine' of the computer.
If the monitor cable is not removable, use another monitor, and cable for a test.
2) If you are presently using Integrated Graphics the next step in diagnosing is to install a graphics card.
See if the problem is the Integrated Graphics 'engine'.
[ Just to add:
Intel GM X3100 is the graphics 'engine'. It is integrated into the Northbridge chip of the motherboard chipset.
Intel G965 chipset is the motherboard chipset. The Intel ID number on the Northbridge chip is 82G965.
The Southbridge chip is an Intel ICH8, or ICH8R, or ICH8-DH,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_Chipsets
{Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Intergrated_Circuit }
The Northbridge chip handles the Processor, Ram Memory, and HIGH-speed graphics.
AGP and PCI Express are High-speed graphics.
A graphics card in a PCI slot is not High-speed graphics.
The Southbridge chip handles the slower capabilities of a computer.
PCI and Integrated Graphics being two of the slower capabilities.
SATA, IDE, USB, and Ethernet, are also some of the slower capabilities of a computer,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
CPU = Central Processing Unit. Another name used is Microprocessor, or Processor for short ]
3) Power Supply.
The Power Supply has enough power to light LED lights, and maybe spin fans, but Not enough power to turn the Processor on.
A) ALL the LED lights on at once will consume less than 1 Watt of power.
B) EACH fan consumes 2 to 3 Watts of power.
C) A typical Processor can consume (Maximum) 51 to 125 Watts of power.
Depends on what Processor it is.
The Dell Dimension E521 desktop computer's motherboard, has an LGA 775 processor socket.
(Processor has the socket holes, processor socket has the pins)
The Intel processors that can be used in this processor socket, can be an Intel Pentium 4, (Version that uses an LGA 775 processor socket), Intel Pentium D, or Intel Core2 Duo, AND Intel Core 2 Quad, with a maximum FSB of 1066MHz. (If the BIOS version will support Intel Core2 Quad processors)
{Front Side Bus of 1066Megahertz}
Wattage consumption can be as much as 105 Watts.
Do you have a KNOWN to be good, compatible Power Supply available, to use as a test unit?
{Compatible being that the Power Supply case fits, (ATX), has the right amount of power cables, and the correct power cables. (Needs to have a 24-pin ATX main power cable, and a 4-pin ATX +12 Volt power cable, for one)
Perhaps there is an unused computer that has a Power Supply you can borrow.
Maybe someone has upgraded to a better computer, and has an unused one with a compatible power supply for a test unit.
Nov 07, 2010 | Dell Dimension E520 PC Desktop
When uploading pictures from my cameras SD card the computer suggests using a hi-speed USB port. I have tried the other ports and it tells me the same thing. Which port is the High speed? Dell Dimension...
you have no high speed ports installed on your computer. what you have is USB 1.0. you can however purchase a high speed USB pci card (usb 2.0) and install it in your computer to get faster transfer speeds.
Jun 11, 2010 | Dell Dimension 3000 PC Desktop
I have a dell dimension 4600i. I want to upgrade
It should.. Here is a link to documentation.
http://support.dell.com/support/edocs/systems/dim4600/en/4600/sm/specs.htm
Apr 28, 2010 | Dell Dimension 4600 PC Desktop
No high speed usb port
Hi Delvin!
The 2 usb-ports on the front and the 3 back of your Dell is high speed ones, at least the manual says so, they are all USB 2.0.
If you cant get them work properly with the 2.0 usb speed, you can buy an high speed pci add-in- card and install it on your pc.
Here you can read about the "high speed usb" :
http://www.usb.org/developers/usb20/
And here is the manual and avalible drivers for your Dell:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
Good luck to you M8!
Please take a moment and rate my help for you
Nic
Feb 23, 2009 | Dell Dimension 1100 PC Desktop
DELL OptiPlex GX150 Upgrading
The fastest processor you can install in a GX150 is a Pentium III 1.13 Ghz processor.
The Socket 370 was a design used only for P3 processors.
Max RAM for that system is 512MB no way to upgrade past that.
If you paid $100 for a GX150, you paid way too much (You can buy a refurbished Dell Dimension C521 for $225 at their refurb site)
Jan 26, 2009 | Dell OptiPlex GX150 PC Desktop
USB Driver for Intel Pentium II
I received a message from someone else who wants to know the make and model of the mother board to my P II Machine. If he cannot help me solve the problem, I shall revert to you.
Jan 13, 2009 | Intel Pentium 3 , 450 MHz Pentium III...
Does Dell Pc OptiPlex GX1p have access for USB ports?
Here is a diagram of your computer. Look where it has USB is pointing to. That is where they're at. Hope this helps.
Dec 30, 2008 | Computers & Internet
Petium 3 processor with windows xp
Just a bit of information. Your slow speed reguards to DSL is bull. Unless your ISP requires your system to run a min Mhz cpu. Cant really suggest how high you can up your cpu unless we know the model of the board & it wouldn't hurt to know the bios version too. Here is a small list from Fixya of Dells & Pent III. http://www.fixya.com/support/dell/motherboards/f5996
Jan 05, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Intel Pentium 3 , 450 MHz Pentium III (SL364) Boxed Processor Logo
406 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
