Question about Tools & Hardware - Others
Ryobi Oscillating Spindle Sander OSS450 Manual and Sandpaper Changeout
I have a OSS450 but am unable to changeout the 1/2" spindle sandpaper. The other attachments have rubber sleeves that are inserted over the spindle and accepts the various sizes but not the 1/2" which seems to be on the spindle directly. Other than the nut and washer at the top of the spindle that secures the spindle attachments, I cannot find any other means of disconnecting the spindle or the spindle sandpaper sleeve from the unit. The 1/2" spindle sleeve just won't budge, so I can't use the other attachments. I bought the unit used but do not have the owner's manual. I don have a parts schmatic but it doesn't help.
  • Anonymous Jan 11, 2009
    hi
    i have the 450 and smallest belt broke that moves shaft up and down. Is that a common problem or does something else go bad that causes belt to break. If that is the case (broken belt) then where can I get them the cheapest price?
    Thanks,
    tom from Michigan
  • roycenpam
    roycenpam Oct 28, 2012
    Tom did you find the belts i have the same problem and have found the wide belt but not the narrow one.
  • 22 Answers
Go to Harbour Freight Website. Their Oscillating Spindle Sander drums & sleeves are direct replacement parts for the Ryobi unit.
Posted on Jan 24, 2011
The solution is simple. The 1/2" sleeves fit directly onto the metal shaft and are secured with the flat washer and nut. You should be able to remove the nut and the washer and them if the sleve has is stuck to the shatf simply peel it off like a toiele roll tube. You can get replacement sleeeves in a multi pack from Home depot (Amazon have this same multipack for $1.00 a really great deal) or you can go to a woodworking site or a sandpaper site like Kingspor or sandgrit and order what you want.
I have the same sander and always run out of the 1/2" sleeves before the others so I order my 1/2" on line.
Good luck.
Posted on Jan 04, 2009
I have had this problem also. On the 1/2 inch spindle, the backing of the paper fuses onto the metal spindle shaft. If stuck, the only way to remove it is to cut it off with a utility knife. I spray the spindle down with WD-40 now before putting the 1/2 drum on the spindle so that I can remove it.
Posted on Aug 31, 2009
How much does this sander cost
Posted on May 13, 2009
MODEL 11322506 MAINT. TO CHANGE DRUMS
To change drums you have to remember it is reverse thread. If the nut will not because the drum keeps turning you need to either squeeze the drum or hold the shaft near the bottom where the fins are. At least this is my experience with the Porter Cable oscillating spindle sander.
Jan 30, 2013 | Tools & Hardware - Others
What type of sandpaper do I use on a dewalt dw421?
this sander appears to use the hook and loop system, you can download an instruction manual by going to dewaltservicenet.com and typing in your model number.
Jan 04, 2012 | Dewalt DW421 5'' orbital sander
My ryobi oss450 has stoped oscillating. Is there anything I can do to repair it? It operates just fine except for the oscillating.
You can try taking it apart and cleaning the mechanism that makes it oscillate, but i have found most times when those stop they are just wore out and need replaced. Those sanders are pretty much disposable.
Mar 17, 2010 | Tools & Hardware - Others
I have a stuck sanding spindle in the arbor of my JOVS-10 spindle sander. I have tries penetrating oil to no avail. Any ideas without tearing down the whole machine?
One last idea is just trying to tighten it more to possibly breach the seizure or you could put some torch heat to it to try and expand the metal. I'd be careful torching as all the super-fine sawdust and oil. Good luck
Dec 14, 2009 | Jet JOVS - 10 / 708411 Oscillating...
On the Bench Oscillating Spindle Sander how do you lock the spindle so that you can remove the bolt at the top to change the sanding sleeve? When I try to loosen the bolt the spindle turns and I don't have...
Remove the spindle from the machine itself before you change the sanding sleeve. There should be a flat section on the bottom of each spindle that you can hook a wrench on to hold it while you undo the top bolt.
Mar 09, 2009 | Delta Machinery ShopMaster SA350K Bench...
USING MY DELTA #17-960 SCILLATING SANDER FOR THE FIRST TIME IN A LONG TIME. NO USER'S MANUAL.
OK you will have to contact a Dewalt Service Center, They do not have that manual online at this time. If there is still a problem and you cant locate let me know and I will try something else. I found a breakdown at Ereplacementparts.com but no user manual
Jan 01, 2009 | Delta Machinery ShopMaster SA350K Bench...
Tools & Hardware - Others Logo
5,512 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
