No sound on audio test - Computers & Internet
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    What make model and OS is your PC?
    President:
  • 2,110 Answers
You need to install Audio driver first...
Posted on Dec 07, 2008
No sound from skype. Speakers pass test but camnnot hear the person I am connected to
If you are using skype
open skype go to tools from the drop down list select options scroll to audio settings
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment or
control panel sounds and audio devices audio and also voice it
Dec 05, 2010 | Computers & Internet
After reinstall i don't hear any sound
You sure you install all the driver? Try re-install the OS and make sure all the setting for audio driver is correct.
If the problem still remain. Means you having problem with hardware. If notebook, try using the audio jack and test the sound. If PC, try using alt port for audio or you can add the sound card for testing.
If those thing cannot solve the problem, audio chip on Motherboard is malfunction. Change it.
May 09, 2010 | HP Computers & Internet
I am not getting any sound from desktop speakers..i have sony driver installed
Onboard audio is disabled in the BIOS
The BIOS Setup program is accessed by pressing the <F2> key after the Power-On Self-Test (POST) memory test begins and before the operating system boot begins. Go to the Advanced > Peripheral Configuration menu to make sure onboard audio is enabled.
Audio settings in the sound mixer are incorrect
Check your audio mixer software to ensure audio is not muted or the volume level is not turned too low.
The speakers or headphones may be connected to the wrong jacks
Make sure you connect all speakers to the correct jacks. If you connect them to line-in or microphone jacks, they won't work.
Audio drivers are not properly installed
Check Device Manager under the Sound, video and game controllers section for any errors associated with the audio driver. Reinstall the audio driver if necessary.
Audio to back panel is muted if front panel is connected
Check your audio mixer software for a setting that mutes back panel audio if you have plugged headphones into a front panel audio solution. Uncheck this setting to allow audio to both the back and front.
Sound Playback is set to wrong device
In Control Panel > Sounds and Audio Devices, go to the Audio tab. Check the default device for sound playback; there may be multiple selections. Select the desired device, either rear panel or front panel.
Mar 06, 2010 | Office Equipment & Supplies
How can I test if my my g51 speakers are working
Hi Try using your MB Audio Programs that came when you installed your MB drivers...I know GIGABYTE Audio Programs Test sound from each Speaker that is connected....Or you can try this website and download that and test....Hope this helps
Happy new year bud :)
http://audio.rightmark.org/index_new.shtml
Dec 30, 2009 | Logitech G51 5.1 Multimedia Surround Sound...
When playing any audio (real player or movies) the sound lasts for approx 5-10 secs and then stops working. box appears saying that the audio device has been removed or reconfigured but I do not have an...
You can try removing the device driver and re-installing it this more then likely will fix your problem. If you don't have the driver you can go to HP and download it for your computer for free. I would give you a link but you did'nt list a model of computer. It will not be the speakers.
Oct 22, 2009 | HP Computers & Internet
Creative Labs Sound Blaster Live! 5.1 crackling sound problem
you need to re-install the drivers of your sound blaster live.
Sep 16, 2009 | HP Creative Sound Blaster Audigy 5.1
Turned stereo on and turned volume all the way up and could just verly hear it comeing out of the speakers
assuming same issue does not happen if you connect a headphone to your receiver - can you check your speakers' connections - it should be straight not crossed for each and in case speakers are properly connected to your receiver - can you test the audio/sound with internal test audio rather than connected device (ie player) - if this is ok and there is no sound/audio volume settings on connected device - change the input the device connected and test again.
Sep 01, 2009 | Pioneer VSX-456 Receiver
QuickCam Connect Audio test - OK Skype audio test -OK but the sound is intermittent. Your advise? victor victordan33@msn.com
Test the sound offline using your webcam center software. If it isn't intermittent there then its likely being caused by your internet connection.
Mar 06, 2009 | Logitech QuickCam Connect Webcam
Asus M2V Audio problem
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Jan 02, 2009 | ASUS M2V Motherboard
Computers & Internet Logo
David Payne
David Payne
