Question about Kenmore 84152 Electric Dryer
Extreme heat, electrical smell
Stackable dryer 2 years old emits an electrical burnt smell and seems to be over heating. Causes smoke detector to go off (detector about 2 feet away). Removed top and tried to remove as much lint as possible. Cleaned out exhaust. Cleaned out lint trap. Wife wants results...doesn't know I am asking your advice. You could make me look good with the "fix".
There could be lint on the heater also. clean if ve t-statso. you could also have a defecti
Posted on Mar 13, 2007
Nortron smoke detector
bro there is a possibility that the sensor is going off due to power surges while using the dryer, turning it on and off will cause power fluctuations, you need an electrician to measure the current\voltage while you which on the dryer, if this is the cause he will advise you on how to avoid future false alarms.
vinaka from fiji
Feb 05, 2018 | Kenmore Dryers
TL751 is two years old. Heating element burned
You did clean out the dryer before turning it back on?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 10, 2010 | Asko TL751 Electric Dryer
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a whirlpool gas dryer, 4 years old. i
It sounds like the heating filament below the drum has either fried one of the fuses down there, or has some lint or something fallen on to it.
Did you notice if the drum still heated up? If it did, then its a bit trickier to completely ID what went wrong. If it no longer heats up now, then the thermal cut-off fuse has been blown and will need to be replaced (most common problem with a dryer)
Typically, once it is unplugged, you can open up the panel below the door (there are normally a couple of latches along the top gap that you need to push in with a couple of screwdrivers to open). Once open, you should see a heating coil that provides the hot air to the drum, look to see if there is anything in contact with the coil. If there is something there, remove it. If not, then continue below.
Now, if your dryer has stopped heating up, you need to pull the coil and replace the thermal cut-off fuse (or get someone in to do it for you). If it was still heating up, you can start the dryer with the panel open (make sure everyone and everything is well clear of the opening) and see where it is smoking from.
Nov 01, 2009 | Whirlpool GGW9868K Gas Dryer
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Dishwasher smoking
I would shut down the circuit and open the door. Remove the lower basket and inspect/feel the heating element for breaks/"bumps"
I bet you will find that it is damaged and needs to be replaced. Not a real hard task with tools and patience.
Please report back what you find/do, OK?
Apr 13, 2009 | Dishwashers
Dryer smoking, burned rubber smell
if the rug has a rubber side it will melt make sure dryer is clean and no left over burnt material ..
Sep 18, 2017 | Dryers
Dryer smelling hot and smoke detector goes off
clean the venting going to the outside and the dryer really ahould be taken apart and delinted to avoid a fire if the unit is older
Mar 21, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore 84152 Electric Dryer Logo
253 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
