When the tv is powered on you only get a flaching white light
When you turn the tv on at the wall power socket you see a flickering white light at the right handside of the screen. When you push the power button on the front of the tv nothing happens.
This is a TARGA VISIONARY 32" LCD-TV Model: LT 3220 Type No: DT 3220EH
  • pjpcs Dec 10, 2008
    I will try this solution.
    Thanks.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Failure to power on is very significant. Ordinarily, there would be some indications that power is reaching the electronics inside the TV. In your case, none at all. Should you be venturing into a DIY (do-it-yourself), you may want to focus on the power supply section. Of particular interest to you would of course primarily be the fuse and the voltage regulator. Should be something like 2SK3911 a Silicon N-Channel MOS Type Switching Regulator.
Should the unit still be under warranty or you prefer manufacturer's services, pls click here.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 10, 2008
  • 734 Answers
There is a problem in the power cord of your TV.
White light coming from bottom area of screen in a couple of palces.
This often happens when the logic board or the screen itself is is about to give in. Some times it can be a build up of static which does happen with these HDTV's, Try the following
  • Plug the TV directly into the wall, no extensions or adapters
  • Turn off the wall socket
  • Press and hold the power button on the TV in for about 30 seconds
  • Turn on the power at the wall back on and check you TV
This is called a static discharge and often will fix issues like this. If you still have this issue you may have to take it to a repairer.
Apr 17, 2014 | Panasonic VIERA TC-L42E30 42-Inch 1080p...
SAMSUNG TMS22WS Flickering Picture
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 26, 2014 | Computers & Internet
Tv powers on, see three birds in color then flickers and fades to white
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | ViewSonic N1930W 19 in. LCD TV
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
Panasonic plasma tv doesn't turn on, red light flickers twice
hi look for any swollen capacitors, also plasma's do suffer from poor solder joints on the power board, so check for any rings around the solder pads, test the voltages on the white connectors with a meter the voltages will be written along the connector,thanks
shaun
Mar 01, 2017 | Panasonic Viera TH-50PZ85U Plasma TV
Tv wont come on
try a different socket, or if the socket has a reset button, press it. occasionally sockets go bad, lose charge, or just need to be reset.
Mar 29, 2010 | Toshiba 42H81 42" Rear Projection...
One day just would not turn on, fuse maybe?
Possibly. However, I would try rebooting the unit first. Unplug the TV from the power supply for about 5 minutes. Then reconnect and try to turn the unit on. If it still does not work, plug a lamp into the wall socket where you have the TV plugged into. If the lamp lights, then you're getting power to the wall socket. If you have the TV plugged into one of those "power strips" check that it is turned on. If so, plug the TV directly into the wall socket. If it comes on, then you have a bad power strip. If the TV still does not come on, you'll probably need repair service.
Dec 01, 2009 | iLO 3200 32 in. LCD Television
TV not turning on blinking powerlight with corresponding clicking
Zenith2.gif "Presentation" is just the name of the general model.
Is it a Z37LC6D LCD TV?
Please reply with the model number and the MFG DATE so I can assist you better.
Check the rear for the exact model and the MFG DATE on the FCC label.
Check for loose power cable to the TV.
Make sure the socket the TV plug into is not overloaded.
An overload is dangerous and the voltage drop will cause the TV power supply from turning on.
If possible plug the TV into a different //// empty outlet.
A clicking sound is a signal of a failing power supply or low line voltage from the wall socket.
Please update you post on the reply window.
Oct 16, 2009 | Televison & Video
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
