I have called the tech help for my cable co. and have checked and rechecked the cables at every input to the tv including the input from the remote plus anything coming from the wall and still no picture. When I go through the channels it's a repeated "snow"for about one second and then a blue screen. Then a notice that there is no signal comes on the screen, but at the Shaw end, everything is fine.The vcr/dvd doesn't have a picture either. I can hear the vcr running, but nothing on screen.
The tv was working fine, until I switched it off for the day - when I turned it on again a few hours later, that's when I discovered the problem, so no one had touched the whole setup all day.
The service is completely free and covers almost anything you can think of (from cars to computers, handyman, and even drones). click here to download the app (for users in the US for now) and get all the help you need. Good luck!
You need a TV cable though ANY cable might work. But definitively the only way to connect a VCR co a TV is through the antena setting TV to channel 3 or 4. Even if you can't see it, all old TV sets must have an antena input. If you can't find it, call a TV repairman, should help to make a connection.
Should be just 3 wire like old one ok match them up red white black if it has ground ok its easy once u see what your doing when u get in there ok thx for using fix ya thx nick .
If the cable box has audio and video outputs on it then use RCA type cables to connect the outputs of the cable box into the video and audio IN of the back of the VCR. Then select L1 on the VCR. If your TV has video and audio input connectors connect another set of cables form the VCR OUT to the IN puts of the TV, then select the AV inputs on the TV. If your TV doesn't have video and audio inputs, then use a coax cable from the RF/Antenna OUT of the VCR and connect it to the antenna jack on the TV. Now select 3or4 on the VCR to whatever works for your location and tune the TV to that same channel. That's it ...you now can watch and record the channel you're watching. You will have to have the VCR powered up all the time to watch TV
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture. From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Please recheck the model. It looks like it is the DVP33040V/17 model.
You said you cannot set or play DVD/VCR tapes.
1. Is this unit hooked up properly to your TV?
2. Is your TV set to its correct viewing channel?
This is the tunerless model so the very basic way of connecting this to the TV is using the composite cables (yellow/red/white). Then find the correct viewing channel on the TV. Note:IT IS NOT CHANNEL 3 OR 4. It depends on your TV make. Most of the time it is called AV, VIDEO, INPUT, SOURCE, EXT, AUX, GAME,etc. Most of the time, the TV remote control has a specific button with those labels. You can also check your TV manual how to get the VIDEO channel when using the composite cables.
Furthermore, if you would do recordings, you will need an extenal tuner (cable box or satellite box) for this unit. You have to connect an external tuner box using another set of composite AV cables - that is:
AV out from the cable/satellite box to VCR IN on the DVD/VCR.
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I know the avr 1602 well....What exactly do you mean "I have my TV cable service wired to the Denon".....Do you mean the actual co-ax cable ?....
The denon is only able to switch raw video and audio signals.
What do I mean by that ?....IF you are running your co-ax cable from your cable company directly into the back of the denon, it won't work. The Denon has an AM-FM tuner, but not a video tuner ( channels 1-121)....If this is what you are doing, then you want to run it to your samsung first ( as long as the samsung has a tuner so you can change channels ).
If the samsung operates like an old VCR, whereby you can plug the cable company co-ax cable into the back of it, and change channels with the samsung, then that is what you must do. You would then hook up the OUTPUTS of the samsing to the VCR or DVD inputs on the Denon receiver. ( use DVD inputs on the denon if the samsung has optical audio out, and use an optical cable as well for better sound ).
You would then use the Denon for the sound, and hook up your TV to the Monitor out jack on the back of the Denon.
The Denon is like a big switchbox. You plug your DVD, VCR, Satellite, video game, or what-have-you into the Denon. Then you use the denon to route the signal to your TV for the picture, and the denon takes care of the sound.
Hope this helps, and remember to always follow your owners manual.......Rob
