Question about Acer AL1912 19" LCD Monitor
Config screen keeps popping up
I hope you can help! This monitor is less than 3 years old and a few weeks ago the menu for the monitor started popping up. I can't use the controls on the monitor to make it go away. I've tried unplugging, turning off and on, etc.
Sometimes it will stay on there for a long time, other times it will just pop up and then go away. The contrast bar is at 0 and I can't fix it
It just popped up again so I can't see what I had just typed. The contrast keeps flashing and the exit symbol keeps hightlighting (now it went away again). I've tried troubleshooting
A friend of mine had the exact same same problem. I think I fixed it, because it has been 2 hours, without the menu popping up. You need to open the monitor:
- Place it face-down on a flat surface
- Remove the cover of the hinge by gripping it with both hands and gently squeezing and pulling.
- Undo the 4 screws and remove the stand (base)
- Undo the four screws tha hold the cover down (4 corners)
- Use a flat screwdriver to seperate the 2 halves (I used 2, a small one to lift the back, a bigger one for leverage)
You will see a small PCB, fastened by 3 screws, at the bottom (where your menu+on/off buttons are) with a ribbon connection to the screen. Next:
- Unscrew the PCB, and gently lift it out.
- Clean the microswitches and the ribbon cable connection.
- Reassemble the monitor.
To clean microswitches and the connection, I used Kontakt Video 90 spray. There must be sprays on the market where you are. It's basically an alcohol-based cleaning spray. Good for cleaning video/tape/floppy heads, CD/DVD lenses, memory modules, etc.
Posted on Jan 07, 2009
The menu options keep poping up
I doubt this is a user fix. There is a problem in a mother board .
I would run to the warranty and try to replace it.
Mar 09, 2014 | Televison & Video
My 15 inch Dell LCD flat screen monitor has 4 blue (cyan) verticle pixel bands about half an inch wide on my screen. The monitor is about 3 or 4 years old. Can you help?
Sorry, but it's kaput. Broken. LCDs were pretty bad a few years ago. A new one will cost a lot less than that one did, and will work a lot longer.
Oct 01, 2009 | Dell 1505FP 15" LCD Monitor
Lock/unlock symbol appears in the middle of the screen
5-22-09 Same problem last month. I had the problem a year ago for a month, then it stopped, reappearing this last month. Last week, I finally called support...I was accidentally transferred to a Dell "internal" technical support department...happily a very diligent technician spent a bit of time with me for free...for same problem, even though he confirmed I was over a year past all warranties. He confirmed this was a monitor problem (not virus, malware, etc.). He also confirmed their standard "guidance"/solution for this monitor issue (if under warrantee) is to replace the monitor (i.e. not attempt to fix it). New monitor needed. But problem again gone for last 10 days. So, when fully irritated, buy new monitor.
Apr 03, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
try cleaning spray for electronics
Dec 17, 2008 | Acer AL1916W 19" LCD Monitor
LCD Main MEnu
hi,
It is possible that menu button on the monitor is stuck. I suggest to call your computer manufacturer where you purchased the monitor, check for the warranty and request for a replacement.
Keep me posted.
Thanks
Dec 03, 2008 | Dell E173FP 17" LCD Monitor
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
No lights or monitor
first of all you will to replace those buttons as its useless after few years. as per your problem is concern you might see some change after replacement. still it does not work then there is a video problem 1 crt filament supply less 2 voltage on g2 is less . 3 check voltage on video ckt to be normal. 4 crt base loose. 5 there might be crt weak if it is old. hope this will help.
Oct 06, 2007 | Acer AL1914 19" LCD Monitor
Help!
You have a button stuck either on the set itself or on the remote. Stargazer
Aug 16, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Acer AL1912 19" LCD Monitor Logo
507 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
