The smell might be sewage or just stagnated build up of a mix of things . try to use a plunger to make sure your shower drain is not blocked in any way , to use a plunger correctly you will need to block the drain hole and fill the shower with hot water and remove what you have covered the drain with and start plunging while the water is running down the drain , this gives maximum effect while using your plunger , some material may want to expel out the top of the drain while other material will be forced down and along the waste pipe after you have done this pour a large cup or two full of liquid bleach down the shower drain and see if this clears the problem ,because most sewer systems are independent from the waste water of sinks, showers and washing machines. Also when you flush the toilet try adding a bucket of water at the same time as you press the flusher , this will force more water than usual down your toilet helping to keep the pipes fully open , but if you notice that when you flush and add the bucket into the bowl at the same time that the water does not escape freely and seems to back up , this can be a sign that there may be blockages in the sewer pipes and you might try doing this extra water flush a few ,more time hoping you will clear your pipes adding some Landry washing powder to the bucket can have a effect on moving anything along and hot water is beneficial as well . But I think you will find that the shower drain is what is causing the odour pouring a mix of vinegar and baking soda down the drain as a regular maintenance job keeps them odour free and unblocked .
u need to change the Black Leather Circle, it comes between the shower hose and the pipe!! also check the shower hose from inside you may find some small stones and sands inside!!! i had this before and fixed it the exact same way i told you :)
Most likely cause is a blocked drain hose. With water in machine try removing the drain hose from where it joins the house drainage (connection to waste under sink or pipe that is specifically for WM.) Put this in a bowl and lower bowl to floor. If water runs out the drain hose is not blocked, if no water runs then the hose is blocked. If water runs then the pump is either broken or blocked - when it should be pumping if it makes a noise then it is not broken.
To unblock the hose or pump - drain the water from the machine (there should be a small pipe hidden behind a front cover at the bottom of the machine put this in a bowl (it will be very slow.) Once drained you should be able to access the pump (it is really an impeller) this should have a screw on front, undo this and remove you should now be able to clean the pump housing. You can also check whether the hose is blocked by blowing down it or pouring water down it. If it is blocked then squeezing the corrugated part of the hose will free some of the blockage. Keep doing this until water can be poured down it. If you live in a hard water area then it would be worth while doing a very hot wash on a regular basis to removed undissolved soap from the machine.
You probably have a water flow reducer in the shower head. It is a rubber disk with a few holes in it. Just remove it and put the shower head back on. They are installed at the factory to save our environment. (Mine are all removed)
I have read other folks say that this has happened to them when a sock or wash cloth gets stuck behind the rubber seal of the door. There is a pipe that drains the water from your detergent tray and it may be clogged with a sock. Try feeling around behind the rubber seal in proximity to the detergent tray and see if there is a piece of clothing stuck in the pipe that drains the detergent tray. Also remove the tray and check the pipe from that end too.
Sounds like your outlet at the top has clogged with grit/dirt. Turn the shower off, remover the entire shower head hose from its base (where it screws into the wall or pipe. Turn water back on. If you get a steady flow (as you should) the problem is isolated to the shower head/hose. Detach the shower head from the hose and clean the screen inside, attach hose back on first, try water again, if this flows then your blockage is in the head itself. After removing and cleaning the screen inside the shower head, reattach and run water, this should fix your problem, if not, you may need a new shower head. If the water will not flow to the outlet pipe alone, either your shower switch is broken or you have a serious plumbing problem.
hi rob the problem is due to an activated thermal overheat switch, you cannot reset this unit as once it is activated it will require a new unit, its a nuisance i agree as i come across this regularly, however its condusive of a scaled up unit so you eventually turn up the shower setting higher to get the water hotter, & inturn activates the thermal switch.
According to which model it is the part is not that overly expensive, you can phone triton direct 7 they will post a new spare to you
