Question about GE WDSR2080D Top Load Washer
Water will not drain
How do I open the machine to get to the problem?............Thanks......Theo
  • 333 Answers
Open the back panel on the lower side of the back panel. Follow the hose at the bottom of the tub. There you will see your water ****. You can remove this and replace if needed. Sometimes it gets clogged and cvan be taken apart depending on which one you have. I hope this will help.
Posted on Dec 07, 2008
Zanussi wfd1257w giving E11 error on dry cycle. Is there a way to further diagnose the fault?
Hey Rich,
Error Code E11 means that your Washing machine has detected an overfill of water - over filling with water
  • Check drain pump for blockage or obstruction
  • Check drain hose for blockage or obstruction
  • Check drain pump
  • Check fill valve is not jammed open or leaking
  • Check electronic control module
Good Luck
JP
Jun 04, 2015 | Zanussi Washing Machines
Door of my LG washing machine(front load) is not opeining, Pls advise how to open it, Thanks
If there is water in the machine above a certain level, it will not allow the door to be opened.
To open the door, Open the hatch to the drain pump at the lower left front of the washing machine. If there is water in the machine and you can't put machine in drain, then you can detach the drain hose and drain the water into a container.
make sure that power is disconnected.
With the hatch open, remove the screws holding the red plastic handle in place. Pull the handle and the door will open. Put the handle back into its slot and put screws back in place.
Mar 31, 2011 | Asko W6021 Front Load Washer
I have an f3 and f4 error code on asko washing machine front loader. i know what the error codes are just dont know where they are anyone can help I need it thanks
F3 indicates a problem with the drain pump. At the bottom left of the machine, theres a square cut-out. This is where the drain pump is located. Using a flat head screwdriver or similar object, insert in opening on right side and gently pry open the drain pump cover.
Once the cover has been opened, be careful when opening the drain pump, as there is always a little water left in the drain pump. Before you open the drain pump, place a small container on the floor below the drain to catch the water. Pull the small black hose from the door and let the water drain into the container. You can now open the drain pump to clean it out. Also clean the pump rotor at the back of the pump housing. Replace the drain cover and reconnect the drain hose securely back to its position on the door. Close the cover.
F4 indicates a problem with the water inlet valve. Make sure the water supply is fully turned on. If no water enters the machine, then turn water supply off. Disconnect the hoses from the water inlet valve to see if the strainer in the inlet connection is blocked. Reconnect the hoses and turn on water supply. Hopefully this solves your problem.
Feb 14, 2011 | Asko W6441 Front Load Washer
Kenmore elite beeps all the time
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
Does not complete program
Mar 15, 2009 | Kenmore Washing Machines
My gw712 washing machine no longer empty's the tub during the rinse or the spin cycle. It produces a single beep every second, I have followed the manual and I still have the same problem
Feb 17, 2009 | Washing Machines
Kenmore front load washer just beeps doesn't start error code says "lol"
Jan 04, 2009 | Washing Machines
Washer Dryer - drum is filled with water even when switched off and door can still open!
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
Oct 31, 2008 | De Dietrich LZ9619 Front Load Washer /...
GE WDSR2080D Top Load Washer Logo
37 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
