Question about Miele Novotronic Premier 500 Front Load Washer
Miele Premier 300 Model W304
When I run any wash programme the machine starts to fill with water and then the programme jumps to anti crease/finish and empties. We have cleaned the filter and all pipes with no success. Do you have any suggestions please? I have a Miele Premier 300. Model W304.
gittos73
  • 244 Answers
SOURCE: machine is locked
to open your door make sure all the water is out of your drum if not get the outlet hose and place on the floor into a bucket if water comes out than your pump is either blocked/faulty
Posted on Aug 12, 2007
  • 16 Answers
SOURCE: Wate rleak Miele premier 300
The conditioner part of the drawer is still blocked. Take the drawer out and turn it over, on the bottom of the drawer you will see what looks like a blanking plug, it's about 1" or so in diameter. Carefully, prise off the plug with a flat blade screwdriver, and you will find lots of sludge blocking the syphon path. Remove syphon and and run hot water through until you can see daylight through the syphon hole where you just removed that blanking plug. Re-fit blanking plug giving it a little tap home. This should sort it.
Posted on Feb 08, 2008
  • 16 Answers
SOURCE: Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
SOURCE: machine wont programme
I hate my meile washer
Posted on Jul 12, 2008
localwonder
  • 6784 Answers
SOURCE: NEFF washer not starting. error code 3/flashing anti-crease butto
This may be a simple control fault that can be reset by unplugging for 5 minutes or switching the breaker switch off for five minutes also. if the five minute reset doesn't restore the machine to its original operational value, you will then need to replace the main control board in this unit. it has failed.
Posted on May 11, 2009
10 year old miele 300 washing machine jumps to
Most likely brushes. Fit carbon brushes part no.4297411 as they are less then half the price of the brush module Part no. 4229779.
Jun 15, 2010 | Miele 300 Front Load Washer
The motor on my Miele washing machine is running constantly even when not set on a programme. The water seems to empty out as soon as it comes in. I Have to release the Stop /Start button to stop motor.
what motor do you mean the motor that spins the drum or the pump motor if its the pump motor i would check the programmer as it tells the pump when to run, on a rinse water evacuate cycle it would seem that you are stuck in that mode call a loacl engineer
Jan 16, 2010 | Miele Novotronic Premier 500 Front Load...
Where can i buy a new door seal/gasket for a miele w304 m/c?
only can be purchased through Miele spare parts or a service agent of Miele.
Dec 31, 2009 | Miele W304 Front Load Washer
I have exactly the same problem with my new Miele washer dryer - and my kitchen is soaking wet. Have you found a solution ?
Jul 28, 2008 | Miele Novotronic Premier 500 Front Load...
Jan 07, 2008 | Miele Novotronic Premier 500 Front Load...
Machine is locked
Aug 12, 2007 | Bosch Logixx WFT 2806 Front Load...
Oct 22, 2006 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
193 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
