Question about SanDisk Sansa e250 MP3 Player
Deleting files from Sansa e250
How do I delete songs, etc. from my Sansa e250? It does not explain this in the tiny guide I received with it.
  • 1 more comment
  • shoot me May 15, 2008
    when i try to delete a file it says cannot find source or disk
  • valee07 May 15, 2008
    Hi, My name is Lee
    I want to know how to delete some of the songs in my Sansa E250 MP3 player. please provide the information how to deleted.
    here is my email: [email protected]
    thank you,
    Lee
  • Anonymous Mar 21, 2014
    Update available but not enough room for update message is received
The only way I know to delete music files or voice or FM recordings, is straight from the User's manual on the CD: 1. Set the e250 to MSC mode. 2. Plug it in to your computer with the USB connector. 3. Open the Sansa e250 drive in My Computer and browse to the MUSIC folder (or RECORD folder)and delete the files there. (That's where you also add music files, by dragging from other explorer windows.) To delete (or add) photo and video files, you have to use the Media Converter, which you install from the disk that came with the e250.
Posted on Feb 20, 2007
    Scholar:
    New Friend:
  • 54 Answers
Connect the Fuze to your PC with the dock cable. Plug the larger end of the cable into the Fuze and insert the other end into your computer's USB port. A dialogue box will load when the computer recognizes the player.
Select the "Open Device to View Files Using Windows Explorer" option from the list of available actions. A window will load displaying the contents of the Fuze.
Open the "MUSIC" folder.
Right-click on the song you want to remove, then select "Delete" from the drop-down options that appear.
Posted on Apr 02, 2012
Mad nice help thanks
Posted on Oct 07, 2007
SOURCE:
CAN NOT DELET SONGS FROM SANSA E250
Deleting songs on the Sansa e250 can be done on the player itself as described in the manual on page 23 (=26 in the pdf file):
1. In playback mode, press the down/submenu button.
2. Select the Delete Song item.
Manual in pdf format:
http://mp3support.sandisk.com/downloads/um/e200v2_userguide_en.pdf
For deleting files when connected to a computer, see page 32 (=35 in the pdf file)
Dec 25, 2009 | Audio Players & Recorders
How can I delete EVERYTHING from my Sansa E-250. I already deleted all the files from Album and Music folders. However, the device still shows some songs as bad tracks, but I can't see these when I connect...
Try this solution:
Deleting Files,Pictures,Videos,etc from MP3 Player
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Be careful and do not delete files needed to operate your MP3 player. Good Luck, I hope this helps Please rate me, Thank You
Dec 22, 2009 | SanDisk Sansa e250 MP3 Player
How do i delete files on my Sansa e250
Deleting Files,Pictures,etc from MP3 Player
Good Luck,
I hope this helps
Please rate me,
Thank You
Dec 04, 2009 | SanDisk Sansa e250 MP3 Player
Whas the best way to delete songs off the Sansa 250e? ie. "bad tracks"
The songs are in the wrong format or have expired licenses
There are 2 ways to format an mp3 player - if you were formatting the mp3 player from "My Computer," then try reformatting from Windows Media Player instead - I have a "tips and tricks" entry on How to Format an Mp3 Player for details
If that doesn't work, then double-click on My Computer, double-click on the Sansa player, and go to the various folders that it lists - music, voice, etc. Delete the songs ONLY - do not delete the dat, bat, ini, inf, or other system files
Jun 07, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250
If you want to delete EVERY track off the player, then reformat the player in Windows Media Player - it's a shortcut - see my "tips and tricks" on formatting mp3 players
If there are artist, album traces, then you need to click on every subfolder under your device in Windows Media Player and delete every trace that way - tedious, but effective
-Tha Mp3 Doctor
Jun 04, 2008 | SanDisk Sansa e250 MP3 Player
Deleting songs
you need to sync your mp3 player and the right click on the songs/artists/ablums you want to delete and then click the option delete. it worked for me
Dec 21, 2007 | SanDisk Sansa e250 MP3 Player
Deleting downloaded songs
The users guide is on the CD that came with it, otherwise you can download it from here;
http://sandisk.com/sansa/assets/English/products/e200/e200_userguide_en.pdf
As for deleting the pre-loaded songs, you can manually delete them from the device while its connected to the PC. Go to My Computer>Device Name (e250)>Music Folder then just right click and delete on the items you do not want.
Best of Luck.
Nov 04, 2007 | SanDisk Sansa e250 MP3 Player
Deleting music
Need to get Vista drivers, software from Sandisk's website
May 18, 2007 | SanDisk Sansa e250 MP3 Player
Deleting songs from Sandisk
Hi. The minimum requirements of your Sansa E250 is Windows XP and above and Windows Media Player 10 and above. If you're using Windows Media Player 10 or above, your Sansa E250 and its contents should appear on the right pane when you click on the "Sync" tab. You can right click on a song and select "Remove". The songs will be erased permanently from the player. If your songs do not appear on Windows Media Player 10 or above, it is possible that your songs may have been saved on another mode. Your Sansa E250 comes in 2 modes: MTP and MSC. Songs saved on one mode will not be seen by the other mode, and vice versa. There are 2 ways to delete songs from your Sansa E250: By browsing the folders containing the songs, or by formatting the player. You can switch modes by navigating your E250's menu using the following: Menu >> Settings >> USB Mode Next, plug your player in your PC and open Windows Explorer. You should first set your Explorer to "Show hidden Files and Folders" by going to the "Tools" menu (located on menu lists on Windows Explorer window), then choosing "Folder Options", then enabling the "Show Hidden Files and Folders" radio button Deleting Music files under MTP Mode: 1. Your player should appear as a Sansa E250 icon in Explorer as a "Portable Audio Device". Double left-click this icon to browse the player. 2. You'll find a "PPI NAND" sub-folder. Again, double left-click on this sub-folder. 3. You'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it. 4. Your music should appear as individual files or folders. Delete this to remove the file(s) from the player Deleting Music files under MTP Mode: 1. Your player should appear as a Drive letter and entitled either as a "Removable Drive" or as "Sansa E250" 2. Double left-click on this drive letter to browse the player 3. You may find your music files immediately on this folder, or you'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it and view your music files. 4. Delete the music files you want, and they should be removed from the player Deleting files through Format: 1. Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode. 2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process. 3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears. 4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen 5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player. I hope this helps. :)
Apr 22, 2007 | SanDisk Sansa e250 MP3 Player
Deleting songs
Chances are that you are using windows xp. open up your sansa folder to where it says pictuer, movies, ect. look at the picture to see what to do. In your player folder click tools --> folder options --> View. Under hidden files and folders click 'show hidden files and folders, click ok. The music folder would now show up where the videos and pictures are. Simply open the music folder and delete the ones you do not want. By default the songs are sorted by artist --> album --> song.
Mar 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
322 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
