Question about Frigidaire Kitchen Ranges
When I select convection bake the letters conv doesn't come on but the bake does. The fan icon comes on also. The oven range model #FGFLZ87GCF and Ser# is VF83656226.
  • 116 Answers
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Posted on Mar 11, 2007
docjohn174
  • 943 Answers
SOURCE: Jenn_Air Oven Problem
HI thanks for your question. A common problem with gas ovens is that the oven will not get hot enough. and the part that's at fault is the ig niter. replace the ig niter. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
jumptrout51
  • 3361 Answers
SOURCE: Range door will not seal properly.
Place a hammer handle between the door and the frame at the hinges..
Push on the door, carefully.
This usually works to re-seat the door hinges.
Posted on Mar 08, 2009
cactus bob
  • 267 Answers
SOURCE: I have a Kenmore Elite Electric Range and when I
this is a super common problem for all convection ovens . your motor is going bad . you can replace it yourself as long as your handy . parts can come from searsparts .com or any appliance parts store . any repair person you call to do the job should have no problem . these motors go bad every 10 years or so , or more if you use it a lot ..........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 17, 2009
  • 81 Answers
SOURCE: Uneven rising & baking in convection oven
I repair commercial cooking equipment for a living. When a customer complains about uneven cooking the #1 thing that these manufacturers ask is..... are they turning (180*) the baking sheets half way thru the cook cycle. #2 are they staggering the pans front to back & side to side. It's kind of a pain but, works for the commercial ones.
Posted on Jul 25, 2009
Locked Oven Door
You mention shutting off the power. Did you use you circuit breaker to turn off the oven. If not, you should try shutting off power using the circuit breaker. Turn off breaker, wait at least a few minutes, then turn breaker back on. This may reset the oven
Dec 25, 2013 | Electrolux Icon E36DF76GPS Dual Fuel Range...
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Need manual for Kenmore oven model#C970-648141
I am looking for a manual to a Kenmore Self-cleaning Convection Oven. I bought it used it has selection for conv bake, conv roast, bake or broil. According to the website, my model number doesn't exist -- really? Everything works perfectly - I just want to understand the difference between "bake" - "Conv bake" and "Conv Roast"
Mar 29, 2013 | Kenmore Kitchen Ranges
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
Cadco XAF 115 fan not working
make sure you have selected convect bake, otherwise remove oven from wall to acces the back and test voltage at the fan, most likely the fan is bad, if you use conv. bake alot
Mar 29, 2008 | Ovens
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Kitchen Ranges Logo
70 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
