Question about JVC HX-Z3 CD Shelf System
High frequencies On my JVC HX-Z3, when playing CD (no matter audio or mp3) in surround modes (Dance, Hall, Stadium), the high frequencies from time to time just goes louder, without doing anything.The sound just changes by itself! I noticed that 1min & 40secs the sound is normal, then the next 1min & 40secs are with boosted high frequencies. When in Rock, Pop or Classic EQ there isn't such a problem. This happens ONLY when playing CD in surround modes(and most noticeable in Stadium).
SOURCE: PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
I had the same problem with a jvc stereo set, it turned out the two cables of a speaker were touching each other.
Posted on Nov 30, 2007
SOURCE: JVC HX-D77 PROTECT!!!
MAKE SURE YOUR SPEAKER WIRES R CORRECTLY COLOR MOUNTED INTO OR CROSSED INTO THE STEREO
Posted on Mar 16, 2008
check the golden wires in the back if they are touching then make them not touch and it should work
Posted on May 09, 2008
im tryin to connect the digital audio optical cable from my tv to my stereo..its not working but is it even possible to get the sorround sound that i want using
Posted on Oct 02, 2008
How do i fix that i get the message on my cd play (JVC HX-D7) and it says PROTECT and shuts off by its self what do i do to fix the problem ?
Posted on Nov 23, 2008
WHAT IS A PICK-UP UNIT
Compact disc and DVD players use a laser pickup and the older analogue systems such as records used direct contact such as tape heads and phono cartridges/stylus which were essentially the pickup units for these items.The pickup unit for a CD player is simply the laser assembly that reads the digital information from the dics..I hope this was helpful.....Peace....
Jan 01, 2012 | JVC HX-Z3 CD Shelf System
Unit powers up, cd and radio seem to be operating properly, but no sound is heard, unit worked fine a few days before, all wires are conected, everything seems unchanged
Well...as you said...the unit powers up...so you don't have a "dead set".I don't know if the speaker can be disconnected from the unit.As a rule of thumb...it is very rare that both channels (left and right )fail at the same time...it is usually one channel while the other speaker still operates.This is what I want you to do...In a quiet room..get really close to the unit...Switch it on and listen for any sound from the speakers...get really close...you should hear a slight hum from the woofers and a high frequency "hiss" from the tweeters....If no sound is heard..switch the unit off..You should hear a "plip" sound...If not...switch it on again...you should hear a slight "bump" sound from the woofers...If you hear no sound from the speakers at all..there is a problem with the output stages of the amplifier section.If you do hear sounds fron the speakers,,Turn up the volume and watch for an increase visually on the display (such as ascending numbers).If there is no indication of a volume increase...The "mute" may be stuck on..Try switching it off and on...please let me know what happens after you do all the tests....Looking to hear from you......PEACE!!!
ok...
Jul 11, 2011 | JVC HX-Z3 CD Shelf System
I can't set the clock on my jvc hx-d77
You Can Only Do This With the Remote in the Following Steps.
1. Activate Clock Set Mode by Holding Down Shift and (6) then Shift (9)
2. Adjust the Hour by Pressing the Next or Fast Foward Button Under Group Skip,then Press Shift and (9) to Set the Hour.
3. Adjust the Minutes by Pressing the Next or Fast Foward Button Under Group Skip,Then Press Shift and (9) to Set the Minutes.
To Check Current Time while playing Press Shift while holding (7) down for 2 Seconds.
Mar 02, 2011 | JVC HX-D77 Shelf System
My JVC HX-Z1 cd player not working, no sound when disc is playing
Please try another good disc on your player. If nothing change , get your lens cleaned by cd lens cleaner. Repeat cleaning 2-3 times and retry it back. If still problem , please replace your lens with new one.
Regards, Jay
Feb 02, 2011 | JVC HX-Z1 CD Shelf System
My jvc hxd77 won't play dvds
If they play cd´s then the motor disc spindle are in bad conditions loose their speed to read the dvd´s you need to replace him
Aug 10, 2010 | JVC HX-D77 Shelf System
Beeps, no visuals, cd player doesnt respond
wow man just clean up the in side cd player hxz3 tower of power wow man lens just clean reading player laser lens just jvc tower of power is cool man bye
May 01, 2009 | JVC HX-Z3 CD Shelf System
Sep 27, 2008 | JVC HX-C6 Shelf System
JVC HX-C6 goes directly into "Protect Mode".
I received a reply promptly from JVC to check power connections for shorts. O course I had already done that. So as a last resort, I pushed the power switch on and held it for maybe 10 seconds. It seems to have reset the unit, and it's playing fine. Best of luck, hope you all read this and it works for y'all. AJ
Sep 26, 2008 | JVC HX-C6 Shelf System
Nakamichi AV-7 5.1
in this case the centre speakers are the main route to the sound. 5.1 is for movies, where the centre speaer takes predcedence.
Aug 29, 2008 | Nakamichi AV-7 Receiver
Nakamichi AV-7 (issue with surround mode - prologic)
Nice Receiver!
>In your surround sound settings make sure the levels are set correctly and the distance from your listing point to the furtherest
speakers are set to accommodate the levels etc.
>How many speakers 5.1, 6.1, or 7.1 (1meaning subwoofer)
>Pro-Logic supports 5.1 but not sure about 6 or 7
>Pro-Logic II does support all
>Make sure you are hear the sound from all sometimes the sound is really faint if you are in surround mode
Thank You and good luck
Aug 28, 2008 | Nakamichi AV-7 Receiver
JVC HX-Z3 CD Shelf System Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
shaun taylor
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
