Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Screen flashing on start up
Looks like there is a lot of the same problem in here, my TV will eventually stop flashing and works great. Is it fixable or should I find another TV. This is for my folks, small town, no repair people, no repair store, and I am miles away relying of relatives to help.
    Problem Solver:
  • 9 Answers
Plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Posted on Jul 29, 2009
My tv keeps flashing from fine till how it looks in the photo, what is wrong with it, its a HCT tv its a great tv and i hope its fixable
The t con Board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 01, 2016 | Televison & Video
How can I fix my television?
One thing to look for is overheating. Is the TV shrouded and hot to the touch? This is the symptom for overheating but it could be other problems too, such as a broken intermittent connection and also a bad or failing electronic part in the video channel. In any case, quite likely not user fixable.
But 1st check the obvious. Did you make any changes to inputs, hookups or position of TV? Are any inputs lose or bent (TV set top box, DVD, etc). IE, make sure it is the TV and not an input. Try an external input (from DVD etc) and see if that works the same.
If the TV works with an external DVD on any other input (HDMI, RGB, VGA etc) you may ba able to just swap around inputs to bypass the bad input channel.
Oct 20, 2015 | Panasonic PT-56LCZ70 56" HDTV
Black screen- fixable?
probably a faulty internal PSU, changing the capacitors on the on-board PCB should fix it but hard to tell without opening it up and testing.
Apr 26, 2012 | Hannspree XV32 32 in. LCD Television
My proscan TV was working fine. then the video went and now no audio.. it lights up briefly when u turn on. then screen goes dark.. is this fixable or better to get a new tv..It is only 3 years old
I believe it's fixable! Take a look on your video and audio cables (behind the TV, the red, yellow and white ones). They must have a problem. Already happened to me!
I hope I've helped...
Feb 14, 2011 | Proscan 42LA45H 42 in. LCD TV
Suddenly with no warning tv stoped working.i unplug it and wait a couple minutes to reset. plug it back in and green light comes on for 45 sec. clicks and green light turns to red flashes 7 times pauses...
cireric13,
Your most likely problem is bad capacitors in the power supply. I have a tip at http://www.fixya.com/support/r7490709-plasma_or_lcd_turns_momentarily_shuts which explains how to check the unit and where to get the replacement parts.
Thanks for using FixYa and for the great rating and testimonial.
hardrocko
Jan 06, 2011 | Philips 42PF9631D 42 in. Plasma Television
Clicking from inside the TV. sounds like its going to explode.
That is one or more of the capacitors shorting and discharging. Turn the TV off and take it in to be repaired. If you let it continue to do this it will eventually destory the television.
Doyle
Apr 03, 2009 | GE 25GT240 25" TV
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Samsung TV screen problems
Your new Tv needs to go back to the dealer. This is not Fixable by yourself...
Nov 12, 2007 | Televison & Video
Sony KP-57HW40 Error Codes 6 & 8
ITS PROBABLY THE RED PICTURE TUB (CRT). IT LOOKS EASY TO INSTALL, BUT YOU NEED TO MAKE ADJUSTMENTS TO THE SCREEN ONCE IT IS INSTALLED. THE PART IS $3OO. TRY TO FIND SOMEONE TO INSTALL IT FOR $150 OR LESS. HERE IS A WEBSITE TO HELP YOU MAKE ADJUSTMENT IN THE FUTURE ON YOU OWN.
PRIDAH
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 10, 2007 | Sony KP-57WS500 57" Rear Projection...
KV-32S45 Disappearing Picture, Good Sound
yes you have a bad vertical ic . i,ve seen bad conections on this ic too, it may not need to be replace its a ic that stands up 6 pins the numbeer on it starts with TDA
Apr 19, 2007 | Sony KV-32S45 32" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
22 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
