Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Self-cleaning ovens is it safe to run with humans and cats in the home?
  • 333 Answers
Yes it is safe. all the oven does is fire up to a high temperature to burn off the debris.
Posted on Dec 07, 2008
I have a built-in double electric oven (Circotherm Model 1058 HCSG). Is it safe to use Oven Mate gel to clean it?
If it's self Cleaning, it is recommended to not use any cleaners except for what's left dirty after self clean has done its job. The residue from the cleaner could catch on fire as the oven gets incredibly hot during Self clean.
Nov 12, 2017 | Ovens
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
Electrolux Icon Oven self cleaning won't start- the lock button keeps flashing. Yes, the racks and rack holders are removed.
Good Afternoon Friend,
I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
    1) Place the rack holders and the racks in your oven.
    2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
    3) Restore power.
    4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
    5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
    6) Take the racks and rack holders out and start the self-clean cycle again.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
    -Best Regards-
    WP
May 18, 2014 | Electrolux ICON Designer E30SO75ESS Oven
I started the self cleaning process with the timer, however, there was a light fire in the oven due to grease. My husband turn the oven (self-cleaning process) off by turning the circuit breaker off. ...
if the door is unlocked then clean all the grease and let go, if the oven is still locked then get a tech down to your house to have it unlocked since its not safe to have it run again with greaase
Sep 05, 2011 | Magic Chef 9512 Electric Single Oven
Just cleaned my recently purchased Frigidaire self-cleaning range per instructions for the first time. It left alot of spattered residue on the viewing glass in the door. how can i safely remove the...
Sorry to read about your problem, I hope this helps you out.
just oven cleaner
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The oven was cleaned with oven cleaner instead of using the Self-Cleaning operation. Is it safe and should we be worried about any problems.
It is safe to use. Make sure you let it run for about 20-30 minutes at 350 before putting any food in it, this will burn off the residue. Also before starting it make sure you didn't get any cleaner on the heating elements if so wait for it to evaporate before using.
Mar 05, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven locks after self cleaning After self cleaning the panel indicates locked
I believe they can stay "Locked" for up to 3/4 Hours. See they heat up to like 900 Degrees, to "Clean" the oven... It stays locked until the oven "Thinks" it is "Safe" to be opened.
Feb 10, 2010 | Ovens
Is it safe to use the self cleaning if someone has used oven cleaners? is it safe to use self cleaning with a small crack in door glass?
No and no...
I would use the self cleaning anyway it gets everything too hot and cuases things to go wrong faster, like burning up the coatings on your wires and such...it is a bad idea but it sells ranges...so go figure.
Definetly noy if your glass has a crack... unless you want to replace it right now...
Heatman101
Jan 21, 2010 | KitchenAid KEBC101 Electric Single Oven
How does self cleaning work on my frigidaire gas burner stove?
Self cleaning would be better named... Running the oven real hot to burn off residue.. so in essence, the oven is locked out and then heat is raised to a high level to bake out grease and food byproducts so they either burn off or turn to ash for easier cleaning.. Does that make sense to you? Most self cleaning ovens lock out the user until the oven has cooled down to a safe user-friendly level..
Nov 28, 2008 | Ovens
Tin foil stuck to bottom of oven
if not a lot of foil get that easy off thats made for self cleaning ovens soak it let it sit then wipe make sure you get the one that says safe for silf cleaning dont scrape soak then after wipping off run self clean
Dec 27, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
