Question about Frigidaire FER231A Electric Dryer
Frigidaire dryer gets clothes caught in between the drum, and body of dryer
The friction burns the fabric, and I mean burn! Scorched is a more accurate description. What can be done besides buy a new dryer?
Just did this today! The brown marks are the felt that is around the part that suspends the drum. It has probably been making a rubbing noise for awhile? The mechanism that supports the drum and allows it is spin is called a bushing This is no longer balancing the drum properly so it is rubbing against the felt and wearing the felt down. The brown marks are burnt felt rubbing off onto the clothes. Get a new bushing assembly and either a top and or bottom felt replacement kit. Replace all worn felt! The top felt has either two or three plastic gliders on it as well. It has been an all afternoon job for me. A second pair of hands is also helpful so long as you are not married to them! Good luck...(I paid $90.00 for a top felt, bottom felt, and a whole brand new bushing unit.)
Posted on Jun 23, 2009
  • 247 Answers
Even if there's nothing wrong with the appliance, this sort of thing can happen if you put too many many clothes in at once. If the drum is more than about a third full, some machines will start to get it wrong. If you're sure that isn't the problem, then inspect the machine carefully. Look for door hinges or catch loose or broken and for damaged or missing seal strips on the body or on the edge of the drum. Finally, grab the inside of the drum and try to move it up and down, then towards you and away (can't really imagine you've lost a bearing without noticing the noise, but it costs nothing to check). A.
Posted on Feb 18, 2007
SOURCE:
Frigidaire Gallery dryer Model FSG447GHSO. Clothes and dryer sheets get caught between the drum and one of the three "bumps" inside the drum, causing burn marks on clothing. I can see the gap where it
There is a gasket that fits around the back side of the tumbler. Sounds like it needs replacing. It's job is to keep clothes inside the tumbler.
Oct 10, 2014 | Dryers
Making thumping noise and burning clothes
You list no brand or model so an answer must be somewhat vague. A loose drum causes the noise described while it also allows air to leak from outside the normal air flow path causing erratic high/low temperatures contributing to burning. Sometimes clothes can also get caught in the gaps caused by the tub moving excessively which causes tears, pinches and rips in clothing. Most dryers will have rollers and/or glides to carry the weight at the front of the drum. Check to determine if these are worn, loose or broken. A few models carry all the weight at the rear of the drum (Frigidaire and some GE) so check the rear bearing for excess wear and replace as needed. It's always a good idea to also clean debris and lint from inside the cabinet while the dryer is disassembled for repairs.
Aug 25, 2014 | Dryers
Clothes caught between drum and top of front panel: Frigidaire
You have a bad tub seal. It is glues onto the front panel...looks like a thick felt pad. Common thing on Frigidaire dryers.
May 21, 2010 | Dryers
Dryer is grabbing and burning clothes.
Take a putty knife or spatula and insert it in the seam on the dryer between the top panel and the rest of the machine, and pry up the top. The top will pop right off and you will probably just need to tighten some screws or replace a small part at the most.
Oct 17, 2009 | Frigidaire Dryers
Burn marks on clothing
The front felt drum seal may be bad. It is attached to the front panel, around the door.
Check and or replace the rear drum support it has worn down the ball and cup support. It will soon begin making a grinding/squealing noise.
When it wears and drops down the gap is greater at the front around the felt seal. Laundry gets caught in the gap and scorches.
Apr 20, 2009 | Dryers
Clothes getting caught in dryer tub and appear to be burning.
-Base on what you said. There is nothing or sharp edge to hold the
cloth by the time the drum spin. Looks like when you close the door. The door snap or bite the cloth and hold it still (no moving)
and the drum keep spinning and rubbing it at the same spot. That's why it mark a burning line.
Same thing like you drive a motorcycle. You apply brake to the front wheel and let the back wheel spin. So it will make a burn line on the ground.
Good luck
Mai
May 18, 2017 | Frigidaire Dryers
Dryer Leaving Burn Marks On Clothes
HI thanks for your question. the problem with your dryer, is that the front felt bearing is worn. and dropped the drum a bit and clothes getting caught. replace the front bearing and the back bearing. not too expensive. thanks the appliance doc. please rate my question. thanks.
Oct 09, 2008 | Dryers
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire crown series dryer
The back of the drum has a hub (a flat steel piece with a shaft and ball) which allows the drum to turn. That ball rides in a plastic "cradle". Unfortunately on the crown series...if the ball and cradle are not greased regularly, the plastic wears. This allows the drum to "sag". The front end of the drum is lower than the back. You can confirm this by running your finger around the front of the drum. You'll notice that the top of the drum is almost flush with the body of the dryer and the bottom of the drum is 3/4 of an inch lower that the the body. This allows clothes to slip into the gap at the bottom and then they are spen to the top pof the drum were the lodge between the body and the top of the drum. The turning drum burns the clothing. Replace the plastic piece that the hub rides in.
Dec 28, 2007 | Washing Machines
Frigidaire FER231A Electric Dryer Logo
655 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
