Question about Aprilaire 700 Humidifier
Aprilaire 760 Humidifier water continues to run
After the furnace blower shut down the water continues to run through the humidifier. Do I replace the solenoid valve or is there another solution?
  • sheff528 Jan 24, 2009
    We just moved into this house, and it had the Aprilaire 760 installed, but disconnected. When I put it back together and turned the water on, the water kicks on when the furnace is off and the humidstat is turned up. When the furnace comes back on, the water cuts off. It's clearly wired backwards, but I can't figure out what's wrong.
    There is a 24V transformer near the humidstat, and one of the feeds runs through it. It has constant power being fed to it. The plug for the humidifier is plugged in to an outlet on the furnace that only has power when the furnace is running. The brown wires coming off the humidifier are wired to the humidstat (one of which has the 24V feed).
    Hopefully that gives enough detail to help.
    Thanks!
    Scholar:
  • 135 Answers
You need to determine whether the problem is in the solenoid or in the furnace electronics. You could put a voltmeter on the solenoid connection to see if the furnace is still holding the solenoid open after the blower stops. This will tell you whether it is the solenoid or not.
Posted on Feb 19, 2007
We noticed the humidity went down to 30% and I adjusted the rate to increase Now our Aprilaire 400 says to change the filter. I did that, and it still says to change the filter. The furnace runs fine....
If your humidifier is equipped with a Digital Humidifier Control with Water
Panel change indicator, after replacing the Water Panel, turn the control
knob to the "Test/Reset" position until the "Humidifier On" light blinks to
reset its timer. (Blower must be operating and HVAC calling for heat.) Be sure
to turn the control knob back to it's original setting. If the "Humidifier On"
light continues to blink, your humidifier is in Test mode. DO NOT LEAVE THE
CONTROL IN TEST MODE OR HUMIDIFIER WILL NOT OPERATE.
Jan 27, 2011 | Aprilaire 400 Humidifier
Water and motor always run on Aprilaire 760, even when furnace is off.
Hope this solves your problem, look for the humidistat, it should be located on cold air return duct near furnace, make sure it is not set in the on position, if it is, then this is why it is staying on, please set humidistat any where from 20 to 35%, never over 40%. If the humidistat is set properly and is still running, you may have a electrical problem, humidifier circuit should only receive power(24 volts) when the indoor blower motor of furnace receives power, also if you have galvanized plumbing in your home, you may have a piece of rust or lime deposit in the humidifier solenoid valve preventing it from closing, turn water off to humidifier and disconnect water supply line entering solenoid valve inspect & clean protector screen. Good luck.
Mar 03, 2010 | Aprilaire 700 Humidifier
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Feb 03, 2010 | Aprilaire 550 Humidifier
Aprilaire 600 humidier: water continuously runs
sounds like you may have it wired to a continuous power source vs one that shuts off with the furnace. The most common wiring is red to C & white to W
Jan 08, 2010 | Aprilaire 600 Humidifier
Aprilaire 760 keeps running.
The humidifier should not turn on untill the furnace blower starts. Since the fan stays on. does the solenoid valve also stay on? If they both stay on you probably have a bad humidistat. If only the blower stays on then the circuit bourd in the humidifier is defective.
Good luck
HVAC Teacher
Feb 06, 2009 | Aprilaire 700 Humidifier
Aprilaire model 760
It could be that the humidistat is not calling for humidity. Make sure that you have the dial turned up all the way (as far as it will go, just to test it) and that the blower on the furnace is running - if the unit is properly wired, the water will not run unless the blower on the furnace is running. This should do the trick. If not, the only other thing would be a bad humidistat. Good Luck!
Dec 14, 2008 | Aprilaire 550 Humidifier
Water does not stop.
soliniod may be stuck. you will need a volt meter to test
Dec 13, 2008 | Aprilaire 700 Humidifier
Aprilaire 700 operating at wrong time
You want the humidifier to run in heat mode which is the r-w1 terminal on the stat.
Nov 17, 2008 | Aprilaire 700 Humidifier
Lots of water run-off from Aprilaire 760 Humidifier
HI would check the filter in side might need changing or cleaning clean out wter tray in side, it could be just a blocked filter , hope this helps
Jan 03, 2008 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
961 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Doug
Level 1 Expert
Joe Paxton
Level 1 Expert
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
