Sharp 68 inch tv will not turn on
Our 4 year old Sharp 68 in tv stopped working in the middle of a program. It will not turn back on.  It was making a humming sound which someone told us it was the color wheel, but now it is completely dead, you can hear it try to start, ,but then the power button and the lamp button just start blinking back and forth can you tell us what the problem may be?
  • 106 Answers
If the tv has never had a lamp put in it, that is the first place I would go. You can refernce your owner's mainual to find the exact location, but usually the lamp has easy access so that you can check it quickly. If the lamp is OK, the ballast is probably an issue. I hope this helps. Check you lamp first
Posted on Dec 07, 2008
Sharp aquos will not turn on. power opc light flashing
I got a Sharp Aquos Quattron LC-60LE847U, a 60inch LED TV, I only brought it for a year and 4 months, factory only a have one year warranty. Last week when my kid try to turn on the TV, the TV power light keep repeat blinking in 2 slow and 5 fast sequence, don't know what did it mean. When I press the power button, the light will stay on for few seconds and it kept blinking after, the TV cannot turn on at all.
My kid have called the Sharp help line in US, number found in user manual, but the Canada help line are different number, it is 1-877-278-6709, they told my kid to unplug the TV, hold down the Input and the Volume down key, then plug the power back on, the TV can turn into service mode, it have a K icon on the screen, but every time I selected the menu, it went away very quick. Then the customer assistant told my kid to call service.
When I did a lot of research, every solution seems to point to the power supply, so I bought a power supply from ebay, replaced it, it does the same thing, no different at all, then I turn the TV back on in service mode, to try to do a reset from the menu, upgrade the firmware, re-seat all ribbon cables of the main board and the middle logic board (Not sure what is that board call, it is in the middle of the TV), neither way can make any different, the TV light still blinking in same sequence.
So I kept doing the research, I find out another way to reset the TV back to factory setting just by holding down the Volume up and Channel down, then plug in the TV, kept hold it down those 2 buttons until the TV came back on. TV will reset for just by doing this. Happy news, problem seems to get fixed, but not 100 %. The TV seems no problem to turn off and on after reset, but if I unplugged it, the blinking problem will come back, but if I reset it one more time, it will works again until I unplug it again. It is better than completely dead.
Then I unplug the TV, removed all ribbon cables (6 ribbon connectors), use sand paper to clean all the ribbon cable contacts, don't rub it too hard in case the cable contacts get destroy, then re-seat all the ribbon cables. After I did that, everything back to normal and my TV got fixed completely.
This seems to be my way to fix it, not sure everyone can use the same method to fix their blinking power light problem, but I hope this tips can help some people to save big buck to the Sharp service. This TV is over $2000 dollars and I brought few pair of the expensive 3D glasses, I do hope it can last longer, didn't expect it have problem already, it just less than a year and half old and even I bought the power supply to tried to fix it but I ended up didn't needed to spend any money and solved the problem.
Hope this helps.
Aug 22, 2012 | Sharp AQUOS LC60LE847U 60 inch 1080p...
4 year old vizio 42 inch tv lcd. While watching tv, the screen started dimming. There is a 4 inch shadow all along left side of the screen and the 1 inch line shadow going down the middle of the screen.
Maybe a power supply or related issue but at 4 years of age the set has reached its life span----parts will be hard or impossible to find.
If you got four years I would retire it and recycle it and then replace it.
May 14, 2012 | Televison & Video
My sharp 32" LCD stopped recognizing the remote, b...
I had the same issue with my Sharp Aquos 52 inch LCD TV. I called Sharp. The tech had me unplug my TV, take the batteries out of the remote (TV remote not cable) and press all buttons on the remote (including the buttons under the flip top at the bottom of the remote). I did this, put the batteries back in and plugged in the tv and everything worked. I had gone 4 months having to use the surround sound for volume and turning the TV on and off by hand. This took 2 minutes to fix.
May 20, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I can t find a fly back for my tv sharp ultra flat 32 inches
"My Sharp TV worked great for ten years and then something broke. I will never buy another Sharp product."
What a *******.
Mar 07, 2009 | Sharp 32C-240 32" TV
My Sharp Aquos
Burnt out pixel line. Usually the panel needs replacing
Jul 13, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
DirecTV installed but TV reverts back to set up screen for the model.
2 yr old 42 inch plasma.screen goes black,sometimes only half screen,sound is on.it does it after 1 hr of viewing, theres a greenish line in the middle of the black sreen when that happens,
pls help.
Jul 04, 2008 | Televison & Video
Samsung TV about 4 years old, the tv turned off by itself last night and for whatever reason will not turn back on. When we use the remote the middle green light comes on in the middle as well when we use...
have u repleace the lamp yet , if not repleace, 4 years old would be a lot of hours the lamp may look intact but after severals hours tv start to go off
May 03, 2008 | Televison & Video
Sharp TV Problem
everythin ok that what you hear is work of oscilator from tv set
Feb 04, 2008 | Sharp 27C-240 27" TV
RCA RCR3273 3 DEVICE SNOWBOARD UNIVERSAL REMOTE
Answer for how to program the RCA RCR3273 3-DEVICE SNOWBOARD UNIVERSAL REMOTE:
Make sure the device is on. Hold down the tv (or whichever device you're trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly, letting it flash until the device turns off. Then press the stop button...and it is programmed.
phoenixx100@hotmail.com
http://www.angelfire.com/journal/archer/index.html
Oct 12, 2007 | Televison & Video
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
Aug 29, 2007 | Philips Magnavox 20MT4405 20" TV
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
Electro Med Services...
