Question about Hotpoint WM56 Front Load Washer
Why dont my machine take the soap powder
Hi I have recently move into a place and just got a cheep washine machine its a Hotpoint first edition 1000 spin i belived its a VM52 or could be WM52 not sure When i put the power in the draw it dont take it does anyone no why this is? there sence to be walker coming out off a little hole for the other bit in the draw but not for the powder please help
  • 247 Answers
Assuming that the bit the water is going into is the prewash dispenser (rather than a bleach or conditioner dispenser), why not just put the powder into there? Some of these machines can be a bit illogical about where the main wash powder is meant to go - sometimes even varies depending on which cycle you're running. If you can find a place that will take the powder at the right time, your problem is solved. If the instructions say different, it might even be them that's wrong. Wouldn't be the first time. A.
Posted on Mar 04, 2007
Hotpoint soap drawer leaking, wfooo
The problem is not a leaking soap container. The problem is that it is overflowing because the line from it to the washer tub is clogged. This happens mostly when using powdered detergents. Check you operating instructions for soap dispenser cleaning procedures.
Jan 03, 2015 | Hotpoint Washing Machines
Hi, my hotpoint Aquarius 1100 washer dryer keeps leaving the soap from washes in the drawer. Any ideas why? Thanks
Try removing the draw and cleaning it thoroughly i would recommend running a few hot washers with no powder through the machine too.
Thankswww.TalkAppliance.co.uk
Apr 24, 2012 | Hotpoint Washing Machines
Hi there, i have just moved into a flat and there is the ariston aml 125 washing and dryer and ihave no idea how to use it. all the soap powder sold in nz is top loader soap powder, is this ok to use in a...
Enter this URL into your web browser and you will be able to download the full manual.
http://safemanuals.com/314159.php?k=3c09a0dae46be7bd02298add3193e78a&ID=433640&q=HOTPOINT-ARISTON%20AML%20125
Jan 26, 2011 | Washing Machines
Water coming back into Soap Powder BOx Filter Blocked Need cleaning out?
remove soap drawer this is easy it just pulls out clean this then look into the hole incase there is a lump of powder blocking the inlet pipe and clean
Jun 11, 2010 | Hotpoint Ultima WF860 Front Load Washer
Is powder or liqued detergent better for front
They are trying to make money off you!!!!!!! LIQUID!!!! Dont ever!!! use powder soap in your front loader. Powder soap doesnt dissolve all the way and then gets into the bearings of the washer and eats them away! This caused about a 450 dollar repair for your repairman. Never use powder soap.
Feb 19, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a hotpoint bc1450 no water coming into machine
Did the problem start directly after the washine machine was fixed ? I wonder if when the washing machine was moved back, the hose to the dishwasher has become trapped and kinked behind the washing machine. Or maybe the supply to the dishwasher is separate to the washing machine and has been turned off by mistake.
Dec 30, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
How do i change the door seal on hotpoint ultima wf860
hi this is a ten minute job take your lid off your machine and then take you soap drawer out there are 2 screws in the behind the soap drawer undo these unclip the top board as you look in side the machine and put the fasia in a safe place now you will have two screws on the top of machine from where you just took the facia off and 2 underneath the bottom by removing the plastic kicker plate undo these and open the door to the right you will see 2 screws that hold the interlock in remove these and then remove the band around the door seal normally metal with spring now lift the front of the machine upwards and that will be the front off now unclip the door seal from inside and check for holes if ok soak in bleach over night and rinse in the morning try some descaler to remove and limescale when you use machine again total 10 screws to undo really easy goodluck and please leave feedback
Sep 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing machine
Could be one of the springs that hold the drum is broken.
Jun 25, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WM56 Front Load Washer Logo
258 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
