Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Convergence trouble philips mod 51pp9303h/17
Convergence trouble philips,mod 51pp9303h/17,need parts number for convergence ic. I got problem I got picture ,but bottom has "cocacola" wave going from one side to the other, is it convergence, how do I fix it ?
  • Philips Master
  • 3,459 Answers
You can get a convergence kit with a photo instuction guide from www.TvRepairKits.com. The kit is for your exact model and includes the 6.8 ohm resistors.
Posted on Dec 15, 2008
  • 106 Answers
Your convergence IC's are bad. They are STK392-120. You may have some 6.8 ohm load resistors bad also. Depending on your experience level, you may want to have a tech doe this repair due to the complexity and alignments required after the repair is completed
Posted on Dec 07, 2008
Adjust color on philips 51pp930h-17 tv
done with the remote in the customer menu under convergence.
Apr 29, 2012 | Philips 51PP9303H Rear Projection...
The display on my phillips hdtv 51pp9303h
Hi
Thanks for using FixYa. The issue is with the convergence ICs going bad and needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Philips 51PP9303H Rear Projection...
Repair man said my philips tv model #51pp9303h/17 needs coupler.
Tries Shopjimmy.com,Partstore.som,or Ebay.com.These Websites have refurbish old and new tv parts.
Dec 28, 2009 | Televison & Video
Replacing STK-392-120 ICs on Philips TV
Ok, I can tell you not to remove the circuit board--best way with this set is to put the entire chassis--all three circuit boards in the"SERVICE" POSITION.
LET ME KNOW IF YOU WANT TO KNOW HOW TO DO THIS---YOU ARE RIGHT--YOU TRY TO REMOVE THE BOARD WITH THE CHIPS--SEVERAL OR ALL THE PLUGS ARE NOT MARKED WITH NUMBERS--THERE IS A SIMPLE WAY TO DO THIS.
LET ME KNOW AND i WILL ASSIST YOU.
Oct 13, 2009 | Philips 51PP9303H Rear Projection...
Philips Projection HDTV 51pp9303h/17
STKs in your set should be on same board that has tuners on it board you connect cable too.If different model they will be on board to very right end STK ICs are big black chips Two of them together.will have part number on them.
Jan 03, 2009 | Televison & Video
Number is on your STKs in TV Two big black ICs STK392-110s 150s, use 180s For Parts Electronix 1-800-223-3205 As for sound replace microboard has #P on it.
Jan 01, 2009 | Philips 55PW9363 55" Rear Projection...
Need Parts Number For Flyback In Philips W/S TV Model # 51PP9303H/17
If you are not sure how to find/repair/replace the HVG yourself goto www.TvRepairKits.com to get their how to guide that includes the part numbers, suppliers, instructions, etc.
Oct 16, 2008 | Philips 51PP9303H Rear Projection...
51PP9303H/17 convergence repair help
I would change all convergence IC not just the one that holds the red. You will need the schematic to get the resistors location.
May 01, 2008 | Televison & Video
STK392-120 you will need to replace both of them
Mar 17, 2008 | Televison & Video
Color on my big screen tv
sounds like you need to have the two convergence IC's replaced. These are soldered on the main board. Good Luck
Jul 16, 2007 | Philips 46PP9302 46" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
262 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
