Mitsubishi WS-A65 won't power on
I am working on a Mitsubishi ws-A65 for a co-worker. He says the power light comes on then goes back out. I have Read all the posts about the convergence IC's on these units and have already replaced both IC's with the recommended replacement(genuniue sanyo part). Checked all the caps,picio fuses,resistors and the flyback(did ring test). Still have same problem. I read your post about the caps on the DM board. but I cannot ID the caps you said were suspect. The board on this unit on the left hand side looking at the back is two boards connected together. One is where all the input and output connections go and the other has a daughter board attached to it with the metal shield. Is this the DM board??
Thanks for any help you can offer
Mike
  • 1694 Answers
SOURCE: Blinking green light stays on and TV won't turn on.
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Posted on Sep 26, 2007
  • 1694 Answers
SOURCE: mitsubishi WS-55513 won't turn on
Two choices =
1) Replace DM MODULE. 650.00 is right.
2) Rebuild DM MODULE. Done right = a little less than Mits.
Caution: High degree of skill needed and ask about warranty
in either choice.Rebuilds usually cover only parts installed,
not complete module.If you do the research on repair,you
will find pin push reset does not work,in most cases....T.
Posted on Nov 05, 2007
  • 3 Answers
SOURCE: 65" Mitsu with 55" DM ?
I replaced the caps first on my 55" first as well....Then after prodding around with a multimeter on the DM board I found A surface mount 125v 4 amp fuse chip(very small) near the capacitors I replaced that was bad( giving resistance when tested)..On my board the location is labeled fb902 I believe..Test for continuity from one side of the fuse to the other with a multimeter or cheap continuity tester....Couldnt believe I found that tiny problem in the sea of circuits....good luck...Sorry if my terminology sucks but Im a first timer as well....
Posted on Jan 05, 2008
welcomejee
  • 10594 Answers
SOURCE: DM module removal
Check this link for guidance with pictures about DM board removal.
Thank you.
Posted on Oct 07, 2008
Laurens mom
SOURCE: Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
Posted on Feb 22, 2009
MITSUBISHI WS-55315 WON'T TURN ON WITH REMOTE OR START BUTTON
do the self check and find the error code if set shows power and then goes total dead shortly after.
May 02, 2012 | Mitsubishi WS-55513 55" Rear Projection...
I have a mitsubishi model #ws-a65 when you turn it on it turns off after 20 seconds and then later it turns on but no picture ever comes up
This model should have the self-check feature.
when it shuts off and the green light on the front goes out:
Press and hold both the menu and input (device)buttons at the same time and hold them for at least five seconds and release both buttons.
The power light should blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat several times.
The error code will point to what the problem may be; 1,2 is no error found, 2,2 is short protection etc.
SD TECH
May 05, 2011 | Mitsubishi Televison & Video
Mitsubishi WS-55859 power light comes on and then goes off.
I get an error code of 2- 2 x 10 etc Ten times I saw two blinks of the on light. I had a power relay replaced in the year one ,fixed it.then. what do I do now to fix it. What part would you replace thanks.
Dec 22, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Won't come on
The power board has failed and will need to be repaired or replaced. you can remove this board and, replace individual parts and save a lot of money. You will be inspecting for swollen capacitors and resistors. also, look for discolorations on the board itself.
Feb 19, 2009 | Mitsubishi WS-55807 TV
My tv ws-55819 tv won't turn on it cliks on but it won' syat on
ok when the power is plugged in hold down the menu + device buttens for five sec what is the error code there should be two sets of numbers....
like 1 pause 2 let me know and i'll see what i can do!
Feb 01, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-A65 Sparks coming from the Bulb Ballast
Your crt is leaking coolant onto the board , you need to rebuild whichever crt's are leaking and fix the board!
Nov 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
WS-55807 doesn't power on
1) Check all fuse devices in power supply
2)Pc board with transformer possibly defective.............T.
Nov 07, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
