Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Chamberlain Liftmaster Pro. Garage door Problems closing
I have a Chamberlain Liftmaster Professional Garage door opener 1/3 horse power. We are having trouble closing the door with the wall mount as well as the remotes. The only way I can seem to close the door is with the wall mount and then I have to press the wall mount and not release until the door is fulling closed or it will stop. Opening seems to work ok, but does not always work correctly. I have looked for obstructions, but there are not any. I made sure the "obstruction sensor eye (?)" was not dirty. Any suggestions?
  • Anonymous May 16, 2009
    I have to hold the opener in the garage down in order for the door to close or else it just jolts and the light starts to flash. The remotes will no longer work
    Problem Solver:
  • 6 Answers
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Posted on Dec 07, 2008
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Jan 21, 2012 | liftmaster Chamberlain Garage Door Opener...
The motor in the openner is not running at all, 1/2 horse power crafman. 315mhz garage door openner,model 139.53914D
Have you checked the house circuit breaker? Do the lights come on? Is the door stuck in the open position?
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
My opener is a 1/2 horse lift master professional chain drive . The door will not close unless you hold the closer button in. From the remote it will only move a few inches and then reverse. The door works...
If the main light flashes 10 times when the door reverses it is a door sensor problem. If not, you probably have a bad RPM sensor board which is a small printed circuit board just in front of the motor.
Jun 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener won't close. travels 6-8 in.,
If you cannot get the light on the sensor to come on by tweaking it,making sure it is pointed at the other sensor and your wiring is not broken or shorted then your sensors need to be replaced.
Jan 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door won't close unless I hold the button all the way down.
make sure the eyes are clean and aligned if the opener thinks something is obstructing its path it will not close
Oct 07, 2009 | liftmaster Chamberlain Garage Door Opener...
check the safety photocells is theres not obstacle between then, check both photecells leds are on.. otherwise no need to replace them
Mar 11, 2009 | liftmaster Chamberlain Garage Door Opener...
I have a Sear 1/2 horse power Garage door opener problem 41A4315-6c
YOU CAN BUY A CRAFTSMAN / LIFTMASTER / CHAMBERLAIN UNIVERSAL RECIEVER THAT PLUGS IN THE WALL.AND WIRES TO YOUR PUSH BUTTON.
Sep 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,214 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
