Laptop does a long beep, followed by two short beeps.
Laptop : HP Pavilion Entertainment PC dv2000t
When I turn it on, the monitor is blank, and after three seconds, three beeps occur, one long beep, followed by two short ones. The monitor stayed blank after this and nothing else happens.
If it was a video card failure, I'd like a step by step guide of taking apart my laptop safely and repair it. I have some screwdrivers, other special tools and a grounding strap. If it was other hardware or RAM that failed, I'd like to know exactly how to fix them as well. I received one long beep followed by two short beeps. I have switched out ram. Screen remains blank.
  • jasouljagirl Mar 11, 2009
    I have a Toshiba Satellite A215-S4807 Laptop and occasionally when i'm on it, either doing my assignments or whatever; I hear a short beep sound or long-ish beep sound. Should I be worried? What could be the problem? Does it require urgent servicing?
  • nexgen43 Apr 11, 2009
    one long beep followed by two short ones black screen
    President:
  • 1,314 Answers
One long followed by two short beep IS a video error. However, your model laptop does not have a separate video card. The only fix is to replace the mother board. Here is the service manual that will show you how to take apart the laptop and even give you the part number you would need to replace the motherboard.
Thanks and please take a moment to rate as fixya.
Posted on Dec 07, 2008
Hp pavillion dv2700 is not starting, 3 beeps, 1 long and 2 short
That is some sort of video failure. "Unable to initialize video (to display the post code)"
Dec 31, 2013 | HP Pavilion dv2000t Notebook
HP - One long two short beeps
first I highly recommend you to go to HP website and search out possible answers - it may be a known problem to them. Secondly try connecting your laptop to an external monitor to see if there is any display there. If you do get external display it is likely the LCD (display) on your laptop that is bad. If you don't get anything it likely is the video card. These are not easy to replace yourself - you need to take it to a tech.
Jun 17, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP DV2000, one long beep followed by two short beeps...doesnt boot up. after repeated attempts, finally got one solution (sounds silly though), but works everytime for me. i plugged power supply and kept...
Hello there yog26.
Those beeps you hear are a trouble report your BIOS is trying to tell you about in the only language she knows.
1 long, 2 short beeps indicate the following pre-scripted error message:
"Video adapter error: Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly."
  • The "video adapter" is the physical device (aka card).
  • "not seated properly" means connecting cable(s) are not full-in connected.
Corrective actions will require opening case and physically inspecting connections, and if still troubled, swapping out the video card with a "known good" one to test.
If that is beyond your geek-ability, it's PC tech repair time.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 14, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Blank screen long beep 2 short beeps at startup.
The 1 long 2 short beep code means a problem in the video circuitry and the laptop can't initialize the display. This is usually caused by failure of the integrated video chipset. Unfortunately, on a laptop you can't just open the case and install a new video card like you can on a desktop. You need to replace the mainboard. Replacements are available online. Here is one source found by a Google search. (I'm just using this as an example. I haven't dealt with this site.)
The 4 beep code means no memory detected when the computer started up. No surprise there since you had taken it out.
Apr 23, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
3 Beeps: Base 64K RAM failure
Explanation: There is a failure of some sort within the first 64 KB of system memory.
Diagnosis: The first bank of memory probably has a bad memory chip in it somewhere. I would suggest trying a different stick of memory.
Nov 11, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
Hp pavilion dv2000 no lcd dispaly
Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Sep 24, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
I have a HP Pavillion DV 2000 laptop with me. When i boot my system it gives 1 long beep followed by two short beeps and the system doesnt boot. I am not sure as what to do. Can someone help me here?
This website:
http://www.pchell.com/hardware/beepcodes.shtml
Lists standard beep codes for computers. The one long, followed by two short beeps indicates a display problem according to the site.
I have heard other people say that the same beep codes specify a RAM problem.
Have you recently installed any new RAM or a new graphics card, or made changes to either.
It seems likely to be the graphics card because of the missing info on the screen. Usually when RAM is bad there is something on the screen.
Jul 17, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
3 beeps at start
hmmm...that's not good. works fine with no battery. I suspect your motherboard may be taking a vacation from working soon.
got backup for your HP?
Feb 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
1,321 people viewed this question
David Payne
David Payne
