Hi - there is no air suction at all. The microwave is not installed to be vented to the outside.
You
can download Samsung over the range microwave installation instructions
here.
The installation instructions will tell you how to set it up.
Even if you're exact model is not listed, there should be one close enough to yours to work.
Once you look that over, if you still have trouble, please reply back.
Otherwise...
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Your fan may be burnt out or shorted
Hello Lori Wilson - Thanks for your post! Generally speaking, the vent is not very strong. Try to place a single paper towel on the underside of the microwave. With the vent on, it should suction the paper towel to the bottom of the microwave. If not, I personally recommend contacting the installer to verify that the vent fan is installed properly and the exhaust outer is correct.
Hi - The fan does not have any air suction - never did. I think it was not installed properly. The model is Samsung SMH8178STG 100 watt over-counter version.
Correction - it is 1000 watts (not 100!)
So are you saying that your hood vent exhaust fan is not running?
Or is it possible that your filters are clogged?
Please reply back with your model number so we can help you.
