Question about Cuisinart GR-4 Griddler
Stuck Grill plates
I accidentally put the lower plate on the upper section and now can't get it to come off. I've tried pushing the button and tugging and wiggling, but nothing. No troubleshooting in their manual to help me. It's the Cuisinart Griddler Gourmet GRID-8 Series.
  • 4 more comments
  • juniperbryan Dec 24, 2007
    We have done the same thing and have the same problem. Were you able to fix yours? Does anyone have any ideas?
  • tin7 Jan 06, 2008
    I am having the same problem and don't want to break it getting the grill plate off.
  • diwhy Mar 16, 2008
    Help! We cannot get the lower plate off, because it is supposed to be on the upper half. We've tried to unjam the lock with a knife, but it just won't budge. So frustrating!
  • Anonymous May 26, 2008
    I just contacted the cust. service dept. at Cuisinart. I'm awaiting their solution, or advice as where to send it for repair. I too, jamed the lower to the upper grill location....dumb!
  • setbst Jun 21, 2008
    Does anyone have a solution? We did the same thing. The lower plate is stuck on the upper location. Help if you can.
  • gduffy2552 Sep 24, 2008
    Cusinart -
    I put the lower grill top on the top and now I cannot remove it! Help!
What happens is that the upper post (see the back of the plates; there's a quarter inch wide post) slides into a slot not designed for it (too small). To fix, find the post. Slide a table knife in between the plate and the griddler, and twist. This should un-jam the post and free the plate.
Posted on Dec 21, 2008
Thanks Salexa4 ! you saved me. The key is the post he describes, and inserting the knife just to one side of it. A bit of a twist, and voila!
Posted on Apr 15, 2009
    New Friend:
Amazing, Salexa4!!! This is exactly what I needed! I was getting desperate. And the tip from pmbCT is really what helped me finish the job! I kept thinking that the jam's source was at the base of the plate (where the two metal brackets are), but reading about the post, I understood the jam was happening closer to the top of the plate (in open position)!
Thanks a bunch :)
Posted on Oct 12, 2014
SOURCE:
Drivers side front tire wiggles in and out if you grab onto the top of the tire and push it in and pull out?
replace your control arms (upper)...if it wiggles in and out from north and south, this can cause uneven wear on your tires. ur upper and possibly your lower control arms should fix this.
Oct 21, 2012 | 1997 GMC Jimmy
Tip
How to set/ change time on your Polar F11.
Having trouble setting the time with your Polar F-Series watch, here is simple quick step-by-step guide to follow.
First know your buttons:
upper right - Scroll
lower right - Scroll
center right - choose
lower left - reverse/ back/ stop
upper left - light
#1 - Push the center right button (exercise will appear)
#2 - Push the upper right button (settings will appear) use the upper right or lower right buttons to scroll if neccessary
#3 - Push the center button (a menu will appear)
#4 - choose Watch, use the upper right or lower right buttons to scroll if neccessary
#5 - Push the center button to choose watch, once highlighted
#6 - use the upper right or lower right buttons to scroll through the watch menu
#7 - Choose Time
#8 - Continue to use center button and scroll buttons to choose and set.
Important button to know - the bottom left button is a reverse button. Make a mistake, just tap that button, keep tapping to go all the way back to the main menu.
on Dec 22, 2010 | Polar F11 Heart Rate Monitor
Tip
How to set/ change time on Polar F6.
upper left - light
#7 - Choose Time
on Dec 22, 2010 | Polar F6 Wrist Watch
Loopers jamming
Overlockers require precision timing. Take it in and have it cleaned, adjusted and timed.
Sep 06, 2012 | Sewing Machines
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
My 1999 f250 brake lights do not work, but the turn signals do, and the tail lights do too, I put in a new brake light switch but there does not seem to be any power coming out of the switch
take the hazard button and tug and wiggle it real hard when pushing the brake pedal, if they start flickering, you will need a turn signal switch replaced.
Sep 23, 2009 | 1999 Ford F250 Regular Cab
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | Watches
I need to replace a rear seat belt in a 1997 Ford Tarsus. Does any know the best way to access the assembly? In addition, are there any diagrams available that show the connection points?
please don't forget to rate, thx.
Retractor and Tongue—Sedan
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Safety Belt Bolt Bit T77L-2100A
NOTE: Safety Belt Bolt Bit T77L-2100-A should be used for safety belt removal and installation.
Removal
  1. Remove rear seat cushion. Refer to Section 01-10 .
Seat Cushion, Rear Sedan
Removal
  1. Apply knee pressure to lower front portion of the rear seat cushion. Push rearward to disengage rear seat cushion pad and frame (600A88) from rear seat cushion front retainers (63370).
  1. Remove rear seat cushion from vehicle.
  1. Remove rear seat back. Refer to Section 01-10 .
Seat Back, Rear 60/40 Split Bench—Sedan
Removal
  1. NOTE: Safety belt bolts do not secure seat back to vehicle.
    Remove rear seat cushion as described.
  1. Fold down back seat and remove two bolts in the center of each seat back striker plates.
  1. Remove two bolts from outboard rear seat back frame retaining brackets.
  1. Lift seat back up and pull forward to remove from vehicle.
  1. Remove panel (52018) and quarter trim panel (31012). Refer to Section 01-05 .
Trim Panel, Quarter—Sedan Removal
  1. Remove rear seat. Refer to Section 01-10 .
  1. Pull up on rear section of rear door scuff plate that overlaps lower quarter trim panel.
  1. Pull lower quarter trim panel away from body.
  1. Remove safety belt retaining bolt.
  1. Feed safety belt through lower quarter trim panel.
  1. Remove safety belt anchor plate-to-sill bolt from quarter panel.
  1. Remove retractor anchor nut and retractor from rear quarter panel.
  1. Remove upper seat belt anchor bolt and anchor from upper rear quarter panel.
  1. Slide anchor plate end of safety belt through the openings in the quarter trim panel.
  1. Remove outboard front safety belt retractor and tongue (611B08) from the vehicle.
    Item Part Number Description 1 386277-S190 Bolt (Part of 611B68) 2 31012 Upper Rear Quarter Trim Panel 3 611B60 Retractor and Tongue 4 N800937-S190 Nut 5 389370-S190 Bolt 6 — Rear Quarter Panel (Part of Body) 7 52018 Lower Rear Quarter Trim Panel 8 — Mounting Stud (Part of Body)
  1. Remove seat belt anchor bolt and retractor and tongue from rear deck panel.
Installation
  1. To install, reverse Removal procedure.
  1. Make sure the safety belt webbing is not twisted. If it is, remove the twist.
  1. Tighten retractor anchor bolt and safety belt anchor plate-to-sill bolt to 34-46 Nm (25-33 lb-ft).
  1. Check the restraint system for proper operation.
Jun 30, 2009 | 1997 Ford Taurus
Bought a Brother 560 Plain Paper fax today at garage sale
Pull the upper part towards you...load in about 30 sheets....push cover back.
Put originals to be faxed in lower section, dial in fax number, press start.
Jun 17, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Leaking stroker boxes on 2001 883 hugger
I think you are referring to "rocker boxes" on your Sporty. Replace the rubber gaskets between the lower plate and the upper plate. If the lower plate is leaking, you will have to remove the lower plate with the rocker arms and the push rods.
Apr 24, 2009 | 2001 Harley Davidson XL Sportster 883...
Cuisinart GR-4 Griddler Logo
2,010 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Irene Tulloch
Tom Chichester
Steve Allison
Steve Allison
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
