Question about Jabra BT150 Wireless Headset
Cannot pair Nokia N70 to Jabra BT150 bluetooth headset
I have turned bluetooth on on my Nokia N70 cell phone. When I search for devices, it won't find the Jabra headset. Can you help please????
Turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
Posted on Dec 08, 2008
It cannot detect your bluetooth because the headset is still inpairing mode, you should unpair the headset to your mobile first, just press and hold the answer button for two seconds until the bluetooth led is blinking. it should now detect your headset.
Posted on Oct 11, 2011
How to clear bluetooth to add new device?
You can pair BT150 with up to four phones or other bluetooth devices.
Before you pair it with a new phone, use the bluetooth menu on the phone it is currently paired with to disconnect it.
The passkey is 0000
Jan 31, 2011 | Jabra BT150 Wireless Headset
How to switch on jabra bt150 blutooth handset
First Fully charge the BT150. Turn BT150 on by pressing the "answer/end button". To put the BT150 into pairing mode press the answer/end and volume+ at the same time to activate pairing mode. Next Set your mobile phone to detect a Bluetooth device. Press yes or ok to pair phone with Jabra BT150. Put in pass key 0000 (four zeros) Then press yes or ok. Your phone will confirm when pairing is complete. Enjoy your earbud/headset.
Dec 26, 2010 | Jabra BT150 Wireless Headset
How to connect jabra BT150 to blackberry 8520 curve
You need to pair your Blackberry with your headset.
  1. Turn on your Blackberry's bluetooth and search for bluetooth devices.
  2. While the Blackberry is searching and the headset is off, press and hold the call/end button on the headset until it's light glows steadily. Do not let go until the Blackberry finds it.
  3. Pair the devices and allow the headset to connect automatically.
  4. Default passkey is 0000.
  5. To connect, press and hold call/end button on headset like the one in step 2.
Oct 29, 2009 | Jabra BT150 Wireless Headset
How to conf jabra bt150 bluetooth for nokia n73
switch jabra off. switch cell on. turn bluetooth on. press "right hand" button next to middle button on cell to search for bluetooth devices. Hold down on switch and volume up switch TOGETHER on jabra. The cell then finds the jabra. I couldn't do this before I found Marie's problem below. Thanks for the info Marie!
Nov 29, 2008 | Jabra BT150 Wireless Headset
Bluetooth handfree not working
Verify that your Jabra BT headset is turned on. You might need to "discover" the device as well.Your RAZR should have instructions on how to pair devices.
Apr 30, 2008 | Motorola Mobility RAZR V3
Lost instructions BT150 how to connect to phone?
1. Turn the BT150 on. To do this press and hold the answer/end button until the light flashes blue, then release.
2. Press and hold the answer/end button and the volume up (+) button until you receive solid blue light. This may take up to 10 seconds.
3. Go into the Bluetooth menu on your cell phone and follow the cell phone’s instruction guide for pairing a Bluetooth headset. This generally involves going into a “devices” or “hands free” menu and adding a new device. Your phone may ask if you want to pair with the headset, accept by pressing “yes” or “OK” and confirm with the passkey or PIN 0000 (4 zeros).
Goodluck
Apr 27, 2008 | Jabra BT150 Wireless Headset
How do i reset it?
You may need to reset your Bluetooth devices. Please follow the steps below:
1. Delete BT150 from cell your phone (if listed).
2. Turn your cell phone off completely, and remove battery for 10 seconds. Please consult your phone provider prior to removing battery.
3. Connect the BT150 headset to the charger for 10 seconds, then unplug.
4. Place the battery back into your phone and power your phone on.
5. Remove the headset from the AC cord.
6. Turn off the headset by pressing the answer/end button until the light flashes rapidly, then release.
7. Turn the headset on by pressing the answer/end button until you receive a flashing blue light.
8. Press and hold the answer/end button and the volume plus (+) button until you receive solid blue light. This may take up to 10 seconds.
9. Go into the Bluetooth menu on your cell phone and follow the cell phone’s instruction guide for pairing a Bluetooth headset. This generally involves going into a “devices” or “hands free” menu and adding a new device. Your phone may ask if you want to pair with the headset, accept by pressing “yes” or “OK” and confirm with the passkey or PIN 0000 (4 zeros).
Oct 09, 2007 | Jabra BT150 Wireless Headset
Chocolate phone will not discover the Jabra BT150
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Oct 07, 2007 | Jabra BT150 Wireless Headset
Jabra connection
Oct 02, 2007 | Jabra BT150 Wireless Headset
Setting up pairing
# Fully charge your Jabra BT150 and switch on by pressing the answer/end button # Press the answer/end button and the volume up (+) button together, to put the Jabra BT150 in pairing mode # Set your mobile phone to ?discover a Bluetooth device? (see your phone user guide) # Press Yes or OK when asked if you want to pair the phone with the Jabra BT150 # Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK # Your phone will confi rm when pairing is complete
Jan 05, 2007 | Jabra BT150 Wireless Headset
Jabra BT150 Wireless Headset Logo
1,203 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
