Question about Alpine MRP-M350 Car Audio Amplifier
Alpine mrp-350 amp
I have the Alpine MRP-350 amp and on this one channel amp I have two JL audio 12 in. subs bridged. First question is , is that safe to have two twelvles bridged on a non bridgable amp , will it harm the speakers in any way? Second what is the function for the gain knob, lp filter knob and the nominal knob, what are they for and what do they do? Thanks
  • 62 Answers
1) If you bridge on a non bridged amp your sound will be horrible as they sine waves comming out of the two teminals will be different... I suggest removing the bridge. 2) The gain knob is to adjust when the amp will reach its max volume with respect to the sterio;s volume. 3) the LP filter is a Low Pass filter and its purpose is to eliminate the higher frequencies that do not sound all the well when played over subwoofers.
Posted on Mar 26, 2007
Will this amp push 2 2000 watt subs?
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
I haw alpine mrp-m350 amplifier how many sub can i
Hook up the MRP-M350 to one 4-ohm sub, and you get 200 watts RMS; connect a second 4-ohm subwoofer and the power output increases to 350 watts! All that juice means that your subs won't just be loud, they'll sound clean and thumping.
Apr 08, 2010 | Alpine MRP-M350 Car Audio Amplifier
How do i hook up the mrp-m1000 to 2 type r subs since it is a one channel amp? the subs r 4 ohms so it should work right?
hook the positive to positive and negative to negative on both subs then run wire to the amp the amp will see a 2ohm load
Jan 07, 2010 | Alpine MRP-M1000 Car Audio Amplifier
I have 4/3/2 ch. alpine f-240 amp- i want to hook up four 6x8 3-way and one 12''sub. the amp has bass EQ on ch. 3. how would i hook it up and get the most power. can i put the 4 6x8 bridged all together...
run two 6x8s on each of the front channels of the amp. then depending on the sub you can bridge it on the rear channels.only if its a single four ohm. if its a dual 2 ohm sub run each coil on each channel. 1 coil-1channel. the other coil-the other channel. amp should run fine may run a little hot since it will be doing all it can do at a safe ohm load. just make sure it is mounted in a well vented area. should be safe.
Dec 25, 2009 | Alpine MRP-F240 Car Audio Amplifier
Can this power a subwoofer and what is the rms wattage
Hello crucible19,
The Alpine MRP-F240 is a 4-channel amp that outputs 40 watts RMS per channel. It is more suited for powering normal speakers, but since it is bridgeable, you could power a small sub by bridging 2 of the channels.
Hope this helps.
Oct 02, 2009 | Alpine MRP-F240 Car Audio Amplifier
What is the best way to connect 4 speakers and a sub to a 4 channel amp.
I would connect the 4 speakers to channels 1-2 in stereo with high pass filter. Bridge the sub to channels 3-4.
A thumbs up would be greatly appreciated if this answer is helpful to you. best-way-connect-4-speakers-sub-4-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
May 01, 2009 | Car Audio & Video
Amp keeps shutting off
you dont have it bridged right your dropping your ohms down way to low.. when you go to bridge your amp you have a negative and a positive on your amp thats it i have an alpine v-power mrp-m350 i think there identical should be but anyways you have to buy a Y splitter there RCA JACKS its has the 2 ends that plug into your amp than ties into a single one its a male or female adapter the place were your gonna get it w know the trick of these amps when bridging is only keep your left channel cable plugged in to your cd player i think its white colored dont plug the other one in rap tape around it or get a rubber cap and put over it.. run your RCA cables to your location of amp location and do the same just tie that into your left channel and tape or get a rubber cap to put over the other one i wish i could draw you a diagram of it hard to explain when typing it if you have a cell phone or house phone i would prefer you calling me from a cell so i dont get charged a fortune my cell number is 1814-594-2667 call me i will get it working for yeah hope to hear from you soon my name is Brad
Jan 07, 2009 | Alpine MRP-M350 Car Audio Amplifier
Weak rear left amp output?
hey whats up bud i got an ALPINE V-POWER MRP-M350 these amps are great go to a walmart od any music shop buy a set of R.C.A cables that plug into your amp than that Ys off to a single connection its a male cable that run a set from the back of your cd player heres the trick ONLY PLUG YOUR BLACK COLORED RCA INTO HEAD UNIT MAKE SURE YOU RAP THE RED ONE WITH TAPE OR GET A RUBBER CAP TO PUT OVER IT SO YOU DONT GET ANY STATIC FREQUENCIES COMING OUT OF THE RED ONE THAN RUN THAT SET TO YOUR AMPLIFIER AND AGAIN ONLY TIE INTO THE LEFT CHANNEL OF YOUR AMPLIFIER.... Hope you know wnat i mean by that Y adapter ther is 2 prongs that tie into amplifier than it splits into 1 were your rca cables will plug into just that one thats how you bridge these confusing amps.... TRUST ME BOTH SUBS WILL SLAM HARD I RUN 2 JL AUDIO OFF OF MINE NO PROBLEM.... WRITE BACK TO ME IF YOU HAVE ANY PROBLEMS OR WHEN YOU GET IT HOOKED UP MY EMAIL ADDRESS IS gordo8785@yahoo.com hope to hear from you soon...
Dec 27, 2008 | Alpine MRP-M350 Car Audio Amplifier
Ohm load???
You can't wire a pair of single voice coil 2ohm subs to achieve a 2 ohm mono load. Too bad you don't have 2 four ohm SVC's. Sorry
Jun 19, 2008 | Jl Audio 12W3 Car Subwoofer
Problems with MRP-M650
as far as it staying on it may have been wired to your hot unstead of your remote on your radio
when it runs wide open it gets hot
how are your gains
I have an alpine and I just hooked up jl 12 w3s and it kinda j did what yours did
it played.. hit hard then no subs.. my mids and highs platyed, but until I would turn off the car and restart the radio the subs immediately came on and the subs are only connected to this aplpine mrp m 650 amp
what speakers and what ohm did they wire it too?
i think my problem was I was overloading my amp feeding it a 2 ohm load or a one ohm load and it was shutting down my subs.. protectection I suppose?
Jun 02, 2008 | Alpine MRP-M650 Car Audio Amplifier
Alpine MRP-M350 Car Audio Amplifier Logo
505 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
