Question about Kelvinator 12 cu. ft. / 340 liter Chest Freezer KDC-47
SMELLY FRIDGE HI IVE A KELVINTOR KCI26BPP FROST FREE FRIDGE FREEZER. WHEN I OPEN THE FRIDGE DOOR THERE IS A DISGUSTING SMEEL.I HAVE CLEANED FRIDGE SPOTLESS,LEFT BAKING SODA AND COFFEE AND PLACED FRESHENERS IN IT.THERE IS ALSO NOTHING IN THE DRAIN HOLE.PLEASE HELP
  • 333 Answers
I would move the fridge and check what is under it.
Posted on Dec 07, 2008
The door open light is on and the fridge is not getting cold
You have broken door seals and need a replacement soon. Opened door while your freezer running is WASTE the energy and bucks.
Regards, Jay
Oct 25, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Frost build up in a frost free freezer
It could be the door gasket. It could also be that the fridge needs a good defrosting. (especially if it is an older fridge)
When I bought my house I had the same problem with the fridge that came with the house. I assumed the previous owner had been defrosting it regularly, which he had not.
Eventually I decided to try a full defrost, and my fridge now works like new.
Mar 20, 2009 | Kenmore Freezers
Hii have an indeset fridge freezer 2 year old freezer ok fridge not cooling
Usual problem, let it defrost properly, I mean 48 hours with doors open in warm room. It is most likely frozen up inside (its frost free! no?) inside is a different matter and they dont tell you that!
Mar 03, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Left the door open on my Freezer last night and now it doesnt wor
After looking at some advice from others I turned the internal dial to the OFF position, then turned it back to 6 or 7, and left it for 20 minutes, and it is now freezing again.
Jan 04, 2009 | Freezers
Frosting & water dripping from freezer in Frost free freezer
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
Dec 30, 2008 | Freezers
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
I have an unexplained smelly zanussi fridge/freezer model Model zx99/5si? I have a zanussi frost free fridge/freezer model Model zx99/5si which is just 4 years old and it is now giving off a revolting...
Hi - we had this problem, and it was in fact where some blood from a defrosting pice of meat drained into the compressor condensation tank and began to decay!
I agree the smell is terrible, so a good clean up is needed but this solves the problem immediately!
Kind regards,
Mike
Aug 14, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
229 people viewed this question
Top Kelvinator Freezers Experts
Mike Squire
Victor Nwachukwu
Victor Nwachukwu
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
