Question about Copystar CS-1500 Copier
We have a 99 and c-7 error on out copystar 1500. We cannot find the waste toner bottle to replace it, can you help?
  • low_toner May 11, 2010
    remove the drum cartridge from the machine, on the rear side youll find screw inside a deep small hole take it out youll find the waste toner, try to recycle atleast half refine it using stocking or some small hole fishnet, mix it with new toner theres no problem
  • Everett Lin May 11, 2010
    the error code mean toner battle full if you need the container we do selling that please contact with me
    New Friend:
  • 38 Answers
C7-99 is not a waste toner error code.
Posted on Dec 03, 2009
Where is the waste toner bottle on a CS-1500?
On this unit it is built into the Image unit. When it fills up you have to replace the image unit.
The process to clean it out is messy and will possibly damage the unit.
Jun 09, 2011 | Copystar CS-1500 Copier
C-7 980 error code
can you give us the error code?
waitin for your reply.
May 08, 2008 | Kyocera KM-1505 Copier
My photocopier has been displaying this error code message C-7990 a photocopier kyocera KM-1500
C7990 is
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
Mar 05, 2011 | Kyocera Copystar CS-1820 Black and White...
I have an error code C-7 980 on a Copystar 1500. What does that mean?
This is a drum related problem. The waste toner is full. Remove the drum unit, remove toner cartridge and unscrew 2 chrome screws on on the left side of the unit. empty the waste and screw back the screws. replace toner and put back in the machine
Oct 26, 2010 | Copystar CS-1500 Copier
My kyocera copystar CS-1815 shows in the message screen "Waste toner near full." How do I empty the waste toner?
Hi there just open it up and inside there will be a small plass bottle that hold the waste toner you can clean out and put back.
Mar 04, 2010 | Copystar CS-1815 Printer
C-7 990 error code just keeps showing up on copystar 1500 copier
the process unit.
Aug 19, 2009 | Copystar CS-1500 Copier
COPYSTAR 1500
the waste tank is full, remove the drum carriage. on bith side remove screw( the one who is inside the hole) dump the waste toner
Jun 22, 2009 | Copystar CS-1500 Copier
ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
Hello sir; The code you display which means waste toner bottle full, just dump it .
May 12, 2009 | Copystar CS-1820 Copier
Km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Oct 22, 2007 | Kyocera KM-1510 Copier
Lanier Copy Machine 3635
Is this a small table top model? They usually do not have a waste bottle. The waste toner accumulates is the drum housing Where hopefully the change drum warning will come on before the waste toner fills up and causes poor copies. I have taken the drum asm apart and vacuumed the toner out.
Aug 03, 2007 | Copystar (023-JF503) Fax
Copystar CS-1500 Copier Logo
100 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
