I have a carrier hotel heat and air wall unit, model #52sec312301 aa, date of mfg 2/28/97. installed and unit ran for 5hrs, when the fan motor quit (it only hums). I need information on how to repair if possible, or where to find a replacement motor.
  • 306 Answers
Chances are the capacitor is bad. Lets hope anyway right behind the control section is the capacitor it will be a dual one it runs the compressor and fan. First turn the breaker off for unit. access the capacitor make note of the wiring this is where it gets real difficult so many wires in a little space. make labels out of tape it you need to there are two sides to capacitor the fan should only have one wire going to fan side. remove the capacitor you can test the capacitor if you have volt ohm meter. Put in ohm's and check resistance on the fan side. If the meter goes up then down capacitor good. If it runs up and down reverse the leads from the ohm meter and repeat runs up and down. If that checks bad replace the capacitor. but other wise the Fan motor is bad and they are tuff to replace. Can be done but you have to undo the inner part from the outer shell and pulling the whole inside out. You will need long Allen wrenches. Have to remove alot of housing items. let me know what you check on capacitor. ken
Posted on Dec 07, 2008
Can the compressor run w/ a 'blown' capacitor?
The capacitor starts the motor. You would have had some other problem had the motor not started. The A/C ran until the failing capacitor no longer provided the ability to start the motor at which point your A/C died.
My A/C bulged both its capacitors 2+yrs ago and it's been running ever since they were replaced, no problem.
I think you're OK.
Sep 13, 2017 | Carrier 38CKC060 Air Conditioner
Please advise heating/cooling capacity for carrier quietline air conditioner vertical through wall model 25 years old model number unknown Thanks
Hello rgar919,
It is imposible to tell you the capacity of the unit without some kind of numbers to find out what it is. They made more than one unit 25 years ago. The numbers off the compressor may help to find the size of the unit. Please try and find some sort of model or serial number, compressor number, fan motor number something that can be cross referenced.
Thank you for choosing FixYa.
Mar 06, 2011 | Heating & Cooling
We have recently had three problems with our three year old Carrier 24 ACA airconditioner that I believe has led to it no longer producing the low temp. chilled air it did when it was installed. !. water...
Your air temp should be at least 20 degrees cooler than the indoor air temp. This is ideal. But it sound like your unit is low on freon. When units get low they will freeze up. They will also freeze up if air flow is restricted on the inside coil or the fan quits on the external unit.
Aug 08, 2010 | Carrier 38CKC024 Air Conditioner
Fan motor runs backwards
Make sure the capacitor is connected to the start lead, not the run lead(s). Also some fans come with some wires you can switch to reverse the direction. If your motor has them there will be 4 and the label on the motor will tell you how to connect them. Let me know if you need more assistance or if this helps.
Jun 02, 2010 | Carrier 38CKC042 Air Conditioner
My Carrier Weathermaker 8000 makes a screeching sound when it first starts but quits screeching about 45 seconds later. I turned the heat down today and it quit about 2 seconds after. The blower still...
the screech is probably the condenser or exhaust fan as you guessed. And yes, a decent handi-man can fix it. Check the horsepower, RPMs,rotation,shaft size, and frame # of motor and order a new one from or a local carrier dealer.
Install the new motor exactly as the old one was and wire according to the motor literature or the graphic on the side of the motor.
Use care when removming the old fan blade. a good file on the shaft and some WD-40 makes the job easier. Also a bit of patience... :-)
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Dec 17, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Need to check the condensor fan. If the fan quit working this could lock out the unit so the compressor does not over heat.
Nov 15, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
I cannot find the model number on an older model Carrier Air
you should be able to remove the front cover and access the filters and a date sticker that tells the model no. The filters are likely to be reusable filters instead of disposable.
The covers of those through the wall systems are held on with clips or clips and hooks.
They can typically be removed by two methods.
1) pull the bottom out and then lift up and out.
2) lift the cover straight up and then pull out.
Some units have the filter mounted to the unit, others have it mounted to the inside of the cover.
Aug 29, 2009 | Carrier KCA101P Air Conditioner
Air Conditioner in wall not window like hotel unit, leaks inside
Open the cover. In the bottom drip pan, there is a hole that is clogged. Just unplug it and it will drain.
Jul 07, 2009 | Amana AC053R Thru-Wall/Window Air...
Carrier Thru-Wall Heater and Air Conditioner won't heat
Here is some troubleshooting tips.
Also service available.
Feb 25, 2008 | Carrier 52PQ307 Wall/Window Air...
Heating & Cooling Logo
291 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
