Won't boot even in safe mode. Changed BIOS settings to boot cd drive with recovery disc but still won't work
Run hard drive diagnostics: http://www.tacktech.com/display.cfm?ttid=287 (or http://www.bleepingcomputer.com/forums/topic28744.html) You could also try a Live Linux like Knoppix Live from here:- http://www.knoppix.net/get.php, hope this helps
Make sure, you select tool, which is appropriate for the brand of your hard drive.
Depending on the program, itll create bootable floppy, or bootable CD.
If downloaded file is of .iso type, use ImgBurn: http://www.imgburn.com/ to burn .iso file to a CD (select "Write image file to disc" option), and make the CD bootable.
download the Free ISO using a Torrent, burn it to a CD then run that it will load into Ram and then ith all the software in the CD you can examine the hard drive
SOURCE: Toughbook CF-51 Sound
You can download the XP drivers from the panasonic site. CF-51 got many flavors and be sure that your model numbers are at hand when you retrieve the factory installed drivers.
Delete all SigmaTel drivers from the registry hardware section. This would help reinstall the correct driver. The presence of these wrong registry values prevent successful installation of the factory drivers.
I have installed se7en, vista and XP successfully. The sound is really problematic since Dell and Gateway laptops use similar sound chips and offers drivers on the net... but they don't work at all. The Gateway driver seems to install perfectly from device manager report, but only the mic works & no sound.
What I do is install the factory provided drivers in XP compatible mode and then use windows update to download the latest SigmaTel drivers (se7en pre-beta). Windows got a more compatible driver but it can only install over the original since the chips cannot be recognized.
SOURCE: Panasonic CF-51 Toughbook Fn keys don't work at all
The following website contains the needed drivers:
https://eww.pavc.panasonic.co.jp/pc/cgi-bin/itn/toughbook/dl01.cgi
Select your model of CF-51 Toughbook, but you MUST be specific. There are about nine variations of the CF-51 so you must use the right drivers.
Download the hkeyapp, hkeyset, and hotkey files and unpack all files. Use the default unpack locations. If you download the files for a laptop version that is not your own, when you try to run any of these files the computer will tell you that the file is not for your model. If the files successfully unpack then you know you have the right files.
For hkeyset and hkeyapp you must run the set-up applications in the unpacked folders.
Go to Control Panel>System>Hardware>Device Manager and go to Other Devices.
The Hotkeys will appear as an "Unknown Devices" so if there is more than one, right click and choose "Update Driver".
Select "Install driver from specific location" and direct it to "C:\util2\drivers\hotkey" folder.
The computer will find the file and install the driver after which point you must restart the computer.
Hope this helps. It took me a while to figure this stuff out on my own so hope it speeds up somebody else's attempt.
Andrew
SOURCE: Panasonic CF-51,s are becoming common on Ebay but
I found this via pendrivelinux.com:
http://www.pendrivelinux.com/testing-your-system-for-usb-boot-compatibility/
So try that out. I just got a toughbook cf-51 and will try it soon myself. Mine came with an XP reg code so maybe that can run from a virtual machine inside of linux.
My advice is to resist the urge to drop yours onto cement from a couple of feet. Not quite that tough.
The hard drive caddy is "the catch", for certain.
Too lazy to look into what the hdd connector is for that, maybe there's a cable or converter somewhere.
AV
SOURCE: Panasonic Toughbook CF-27
i need help i have a panasonic cf-27 toughbook with a usb cd drive and usb floppy drive ive tried both seperate and with a multi usb connector to boot both but it doesnt find them can anyone help me?
SOURCE: how to remove wireless card from panasonic cf-51?
The mini pci card or wireless is under the small access door on the bottom of the laptop. It is accessed with one screw holding the access door in place.
