Question about Viking DDBB363 Bottom Freezer Refrigerator
The bottom of my Vicking freezer keeps getting Ice build...
I keep defrosting, but every 2 to 3 weeks it does the same thing... Is there anything more I can do?  It working fine other than that...
  • 1 more comment
  • Anonymous Mar 16, 2009
    I HATE THIS FREEZER!!! Give me an old GE any day. The back and the bottom of the freezer fill with ice and the freezer stops freezing properly. I just broke off all the ice, again, but its still not cold enough to make ice or freeze my ice cream.
  • Anonymous May 23, 2009
    We have had the same problem with our viking for the past 3 years; accumulation of ice in the bottome and eventually it locks the fan and the alarm picks up that temperature goes up
  • herbiess May 11, 2010
    where is the rubber tube and how do I get to it?
  • 42 Answers
You need to remove the plastic tube that the water goes through . then take small saw and cut the flat part of the tube completely off . then slide the the plastic tube back in the bottom of freezer . apply a bead of silicone around the top of the plastic pipe (where you cut of the flat piece) so that the water does go into the insulation. whats happening - that flat piece sits up about a 16" too high at times and this causes a small pooling of water that becomes worse over time.... if you still continue with this problem take a short piece of 16 gauge wire wrap it around the calrod defrost heater a few times and insert the rest in your drain hole. this will heatup everytime a defrost occurs . which then melts the ice
Posted on Dec 20, 2008
Bottom frezzer keeps defrosting
Try defrosting the whole fringe top and bottom and make sure the ice build up in the crossover vents is all cleared out. Ice keeps the cold from moving through the fridge as it should.
Try this before you do anything else. simple things 1st.
Mike
Jun 11, 2017 | Refrigerators
Permanent ice on back side of fridge near the sensor (thermistor?)
Hello Paola! If your refrigerator is frost free, that is an indication the ice build up is caused by a failure for your defrost circuit. This circuit is made up of a defrost heater, defrost thermostat (both in freezer section behind the inner shield) and either a defrost timer (if your unit is older than 5 years) or the control board if younger. If you take off the shield in the freezer and the evaporator coil is coated in ice that is probably the cause. To check, defrost the unit by unplugging, and then use a hair dryer or heat gun to defrost all the ice off. NOTE: Be ready to deal with the massive amount of water from this defrost or you will have a mess. IF I am right, the refrigerator will start working normally for 2-3 weeks (depending on your humidity it could be shorter). Then you will get another ice build up and it will do the same thing.
Jan 16, 2012 | Refrigerators
My fridg and freezer is cold but not could enough the freezer wont keep food frozen. there is no ice build up, I replaced the defrost timer, and I cleaned the fan in the back what else could it be please...
Hello Nicole,
Their are a few things that couldbe causing your refrig.troubles.
1) their is ice build up in the return air vents that is not allowing air to flow correctly
you can see the air vents under the crispers in the ref.floor and can see if they
blocked with ice.
2) the freezer fan is bad and not circulating cold air into and out of the ref.
3) In addation to the defrost timer,perhaps the deforst heater and defrost thermostat are bad and frost is building up in the freezer,Do ya see frost
build up in the freezer??
GENE
Sep 21, 2011 | Amana BCI21V1C Bottom Freezer Refrigerator
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Jan 03, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
My LG GR-349SQF freezer keeps getting ice in the very bottom
I believe your defrost condensate drain is blocked with ice or other foreign objects. Could you also double check the model number? Thanks, Sea breeze
Dec 29, 2009 | LG Refrigerators
Ice build up every few weeks
Change the defrost heater inside the freezer. Located behind panel inside the freezer at the bottom.
Jul 09, 2009 | Refrigerators
My Whirlpool upright freezer keeps building up ice inside the bottom back wall. The fan starts rattling and freezer will not stay cold enough to make ice. If I take everything all out and leave it off...
Either your defrost timer, defrost heater or defrost thermostat has failed. All parts are located behind the lower back panel inside the freezer. Most likely are the defrost heater and defrost thermostat.
Jun 09, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Mar 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
GE Fridge/Freezer Having to turn temp up just to keep it cold
From your comment. It's not that you have to defrost the parts, that's what they're called. "defrost timer", "defrost t-stat" and "heat element". Defrosting the whole fridge for a few days actually will clear the ice blockage if that's it but it will return in a couple weeks if the "defrost cycle" isn't doing its thing. A fridge typically goes into some form of "defrost cycle" to keep it "frost free". As an example, every 12 hours the compressor turns off and the evap. fan turns off then a heat element turns on to melt the light coating of ice on the "cooling coils". Once about 1/2 hour goes by the heating turns off and the cooling turns back on again. This repeats over and over to keep the ice from building up too much. If that cycle is broken, the ice will build and build till the whole coil is a block of ice. Then the air can't flow around it to provide cold air for the whole unit. It acts basically like putting a large block of ice in the freezer and keeping the doors closed... without a fan to move the cold air only the very lower portion of the freezer is cold, the rest is warm.
Dec 30, 2006 | GE GTH18KBR Top Freezer Refrigerator
Viking DDBB363 Bottom Freezer Refrigerator Logo
374 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
