Question about Baby Lock Imagine
I need help with setting satin stitch to applique a decal on a jacket. My stitches are not close enough together.
  • Anonymous Mar 18, 2014
    I have a bernina 910 and need to blanket stitch applique? Which setting do I use for the best stitch?
  • 4,889 Answers
Here is the manual. Hope this helps
http://www.babylock.com/ftp/whitepapers/ESG-QGF.pdf
Posted on Dec 07, 2008
I have a Bernina 145 S activa and I can't get my satin stitch to work , it brings the bobbin thread to the top , what can I do ?
Do you use stabilizer when you are satin stitching? I had a teacher who also hooped the fabric with a spring-loaded embroidery hoop (turned upside-down under the presser foot so the fabric is flat against the needle plate) that would keep the fabric taut.
It is not uncommon for bobbin thread to rise to the top when doing embroidery, satin stitch, etc., especially if you are using lighter-weight thread than usual. You would normally loosen the upper tension so the upper thread will sink into the fabric. However, if loosened upper tension is not doing enough, you may need to adjust bobbin tension when doing embroidery, applique... You might try tightening the bobbin tension just a smidgen to get the bobbin thread to stay below the fabric. Be sure to mark the bobbin case before making any adjustments so you can return it to the original setting when finished with the satin stitch. (If you do a lot of satin stitch or applique, etc., you may want to invest in a separate bobbin case that is set up only for doing that kind of work--saves having to alter the bobbin tension frequently.)
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwiRr76k0sbLAhXBKGMKHei6AfIQFggqMAI&url=http%3A%2F%2Fmachinequilting.mqumag.com%2Fwp-content%2Fuploads%2F2014%2F12%2FSatin-Stitch-Techniques-Part-1.pdf&usg=AFQjCNFXYKp2C-RJEAAUMWwApqZlU895uQ&cad=rja
Mar 16, 2016 | Bernina Sewing Machines
What can I do to widen my satin stitch when it is to narrow for the applique
Unless you have and know how to use digitizing software, will you be able to add width to the satin stitches when doing applique. You need to cut the applique fabric larger than the cut-out-line so the applique fabric will held down properly. Some Commercial or higher end home embroidery machines can re-interpret the embroidery design and widen the satin stitches in a design without software. 6f3dbcfe-19c3-4021-b143-de10c9a89868.jpg
Jul 14, 2014 | Brother PE770 Computerized Sewing Machine
Stitch length for zig zag satin binding 8mm equals what number?
Neat zigzag stitches are usually achieved at "2.5" or below.
Closed up zigzag stitches (close together) are referred to as a
satin stitch its likely you will want to set for 1.5 or at most 2. http://www.searspartsdirect.com/partsdirect/user-manuals/3116-singer-parts-SEWING+MACHINE-manual Look for page 40 in the owners book or scroll down and if you see numbers not on the page but on the scroll bar look for 47. It has some great pitures that can help you out.
May 13, 2014 | Singer 3116 Simple
Distorted embroidery with Designer SE
have you tried changing the needle
try rethreading the machine top & bottom
also clean under needle plate area & bobbin area for loose threads & lint
Jan 27, 2012 | Husqvarna Designer I
I want a loose button-hole type of stitch to do my first applique by machine. I have put the needle to one side, put on foot #20 -- and now what stitch?
This depends entirely on your model of machine and the kinds of stitches it is designed to make. Not all machines will make the kind of stitch you describe. My machine has a buttonhole stitch, but with slanted bars, and it really doesn't give the right look.
Check your machine manual and look for a stitch that gives you the look you want--you might have a "blanket stitch" option. If your machine doesn't offer a buttonhole or blanket stitch that gives you the look you want, you may want do use a narrow zigzag satin-stitch. You can also do a straight stitch very close to the raw edge of a fused applique but it won't look as tidy.
Apr 01, 2011 | Sewing Machines
I don't know how to make satin stich Janome DC2010
As a general rule of thumb, satin stitch is obtained by selecting zig-zag, turning stitch width up to 3 or 4 and stitch length to 0.5. If you have a clear plastic open toe sewing foot, put that on to help view the area.
If you are doing applique (attaching pieces of fabric to another surface) with a satin stitch, you may also need to use tear away stabiliser underneath or interface the fabric first, it depends on what/where you are doing the satin stitch onto.
And a nice machine embroidery thread will give you a much silkier appearance than plain thread.
Mar 13, 2011 | Sewing Machines
What settings for doing zig zag for satin stitch around applique. I have used 3.5 width and 0.2 length but the fabric has a tendancy to pucker and the stitches sometimes bunch
It depends on a couple of things. Depending on the fabric you're using you might want to use a stabilizer like an iron on tear away. If the stitches are bunching the stitch length might be to tight. Try going to 0.3. if the stabilizer doesn't work. With the stabilizer on, it will keep the fabric firmer so it won't pucker. Make sure you have the decorative stitching foot on the machine with the little indentation for the satin stitch to ride in. If you have the wrong foot on, this will cause bunching too. Let me know if this helps.
Aug 22, 2010 | Janome Memory Craft 4900QC Mechanical...
When appliqueing in stitch 11 the thread kees looping...
I believe stitch 11 is a zig zag so you are probably decreasing the length to get a satin stitch. You will get a better satin stitch if you select it directly. I think that it is about 29. The machine forms the satin stitch differently than the zig zag and it should look better. If you still get loops on top, you may need to have a qualified technician check the needle to hook clearance. If this distance is too great, the machine skips stitches and you will form loops. Several other adjustments may be needed to get a perfect stitch and a qualified Husqvarna technician should be able to take care of this problem for you.
Nov 23, 2008 | Husqvarna Viking 1
Sewing Machines Logo
200 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
