Question about Garmin eTrex GPS Receiver
Broken battery spring
2 problems:
1 the spring wire that makes contact with the negative end of the battery broke.
2. seems it eat batteries. Much quicker than it used to.
thanks for the help
2 Suggested Answers
SOURCE: battery contacts
The only way is to send it back to Garmin. They will not sell the part. I just folded a piece of aluminum foil and poked a hole in it and unscrewed the contact, placed the foil under the contact, screwed the contact back down and then folded the aluminum down so the battery end could contact it. .
Posted on Jun 16, 2009
X300 want turn over after replacing battery and checked fuses. Make clicking sound when you try to start it
There's three things that spring to mind ..
One is a loose/dirty wire/connection from the battery positive terminal (the red cable) to the starter motor.
There's a problem with the starter motor itself - such as a sticking/dirty solenoid.
You have an earthing problem. Check the security/tightness of your battery negative terminal. Also check the cable itself - corroded/broken strands in the copper cable will cause an earthing problem.
Also check where the negative - black - cable attaches to an earthing point, which is usually the engine block or the gearbox housing. Undo the bolt that connects the black cable to the block, clean the cable terminal and mating face, then refit the cable/bolt.
The symptoms you describe are classic 'bad earth' problems.
A very quick check .. if you have a battery booster cable (you only need one...) .. connect one end to the battery negative terminal and attach the other end to any suitable earthing point on the block. If the car then starts, that's pointing at a 'bad earth' problem.
Sep 16, 2017 | Cars & Trucks
1986 BMW R80 no lights on dashboard, when key is turned, new battery, changed out old 15 amp fuse near positive terminal
Hi, Don #8 is jumping up and down waving a red flag if you have a dash or instrument light that is out and you have confirmed that the bulb is good then you need to do some quick diagnostics all you need is a test light and a wiring diagram usually found in the back of your service or owners manual.
1. Make sure your battery is fully charged with "CLEAN" and "TIGHT" connections and the instrument light fuse is not blown.
2. Inspect the bulb socket for corrosion and clean as necessary, a spray can of electrical contact cleaner and compressed air works the best.
3. Confirm your test light is working properly by connecting one end to the battery negative post and touching battery positive post with the sharp probe, the test light should illuminate.
4. With the ignition turned on to confirm you have power to the bulb socket by connecting your test light to battery negative or ground and probe the center contact, the test light should illuminate if not you need to check the integrity of the switch or sending unit the light represents, if that is ok then you have a short in the wiring between the component and the light bulb, if all is ok proceed to the next step.
5. Confirm you have a good ground to the light bulb socket by connecting the test light to battery positive and probe any metal part of the socket housing, the test light should illuminate, if not you need to find the short and repair as necessary.
6. Inspect the integrity of the spring loaded positive contact insulation tab by pushing against it with your test light to see if it goes down and springs back fully to it's operating position again contact cleaner and compressed air works best to restore proper function.
7. If your bike has a lot of mileage the vibration can cause bulbs to become loose in the socket by wearing down the soldered contact thus loosing spring pressure from the tab and eventually stop making contact this can be fixed by replacing the bulb or putting a drop of solder on the worn out end to ensure contact.
8. If all of your dash lights are out but are good then you most likely have a faulty connection to the dash wiring harness, inspect the connector for corroded, broken, or loose pins/sockets.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
BMW Airhead Motorcycle Electrical Hints
Bike won start no dash lights
https://www.manualslib.com/manual/1101973/Bmw-R-80-Gs.html
BMW Parts Microfiche
http://www.bmwmotorcycles.com/us/en/index.html?content=http://www.bmwmotorcycles.com/us/en/services/manuals/manuals_main.html¬rack=1
Feb 18, 2017 | BMW R 80 Motorcycles
Oil light and neutral light not working when the ignition is switched on
Hi, Michael if you have a dash or instrument light that is out and you have confirmed that the bulb is good then you need to do some quick diagnostics all you need is a test light and a wiring diagram usually found in the back of your service or owners manual.
4. With the ignition turned on confirm you have power to the bulb socket by connecting your test light to battery negative or ground and probe the center contact, the test light should illuminate if not you need to check the integrity of the switch or sending unit the light represents, if that is ok then you have a short in the wiring between the component and the light bulb, if all is ok proceed to the next step.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Nov 15, 2016 | Motorcycles
Neutral light and oil light not working on a honda cbf 600
NEUTRAL LIGHT WONT COME ON BIKE THINKS ITS IN GEAR WHEN IN NEUTRAL
Honda CBF600SA Service Manual
http://owners.honda.com/assets/OWNERLINK/model/own_man/powersports/2004/2004_CB600F.pdf http://www.partsfish.com/page/oem-parts-for-honda
Nov 15, 2016 | Honda Motorcycles
Replaced three batteries in polder kitchen scale, now it just flashes light. Can't turn on or off and no digital readings
Be sure all 3 batteries are fresh and also be sure they are in correctly .positive+ and negative- , to proper placement in machine. Typically the spring contact points go on the flat -end of battery and the + nipple end of battery goes on the solid or button contact on the machine. Spring end contact points on machine may be an actual spring or a raised metal piece either way they are the end that flexes and holds the battery tight against both contact points. Sometimes the spring must be carefully pulled to make it give more holding pressure. Good luck and I always say Google it!
Oct 18, 2017 | Polder KSC-310-28 Easy-Read Digital...
Xt125r neutral light does not work
Hi, Anonymous if you have a dash or instrument light that is out and you have confirmed that the bulb is good then you need to do some quick diagnostics all you need is a test light and a wiring diagram usually found in the back of your service or owners manual.
https://yamahaclub.com/forums/topic/36839-yamaha-xt125r-dash-problem-neutral-light-on-permanently
Neutral Light Resolved Technical Mechanical Problems
http://gigi600.altervista.org/immagini/xt125r/XT%20125%202005_service.pdf
OEM parts for Yamaha
Yamaha xt 125 service manual
http://mybikemanuals.com/yamaha/yamaha-xt-owners-manuals
Feb 21, 2013 | 2007 Yamaha XT 125 R
Self not working
Yamaha FZ 16 Service Manual
Yamaha FZ16 User Manual pdf
Nov 25, 2012 | 2008 Yamaha FZ16
1986 yamaha venture royale dash light indicators
1983 venture xvz12 problems
http://www.venturers.org/Tech_Library/?action=category&cat_id=001007
http://www.yamahaventure.nl/pdf/servicemanualxvz1300.pdf
YAMAHA XVZ1300A Owner Manual
Jul 08, 2012 | Yamaha Royal Star Venture Motorcycles
How are the batteries loaded, which way etc? Thanks
You have not mentioned your camera model but there are two main types of battery in use:-
1.) Older cameras tended to need two or more AA batteries, whether re-chargeable or not.
The principle here is that the each end of the battery forms a separate electrical contact. The end with a small Button sticking out is 'positive' (+), the Flat end is 'negative' ( - ), and there are markings on the sides of the battery which show this.
There are usually also marks on the battery hatch of the camera, or nearby, with + and - , to show which way the battery goes in, but the marks are often hard to see.
In the camera there is a spring at one end of the slot for the AA battery, and the battery should be fitted so that the Flat ('negative') end of the battery is in contact with the spring.
To fit the battery, you put its Flat end in first, so it touches the spring and compresses it when you press on the battery. Doing this should make more room available so you can push the button end of the battery into place.
2.) Newer cameras tend to use proprietary NiMh batteries which are shaped differently for each model.
It is fairly easy to see how the battery fits because you can look into the camera to see exactly where the metal contacts are. Then you can line up the battery so its own contacts match those inside the camera.
Because the contacts are invariably off-centre there is only one way the battery will go in, but you need to gently hold the catch out of the way to get the battery to start going in.
I hope these comments will help!
Dec 27, 2010 | Cameras
My 45CL-1 AA battery polarity not marked on the holder.
I am not acquainted with the 45CL-1, but as a general rule, if the contacts for one side of a battery is a spring and the other end a solid piece of metal, the negative (-) end of the cell should contact the spring and the post (+) end of the cell should go to the solid metal contact.
Nov 25, 2008 | Cameras
Garmin eTrex GPS Receiver Logo
301 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
