Question about GE JVM1440 Microwave Oven
The start button on the Panasonic NN-A773 will not work at all
Other buttons on the pad work intermittently.
  • mrsmirfield Dec 08, 2008
    It's not spray cleaner but I think that moisture has got in there, where I was hiding a cooling chicken from the cat!! Thank you very much, I'll give that a go.
  • GE Master
  • 9,098 Answers
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
Always spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
Always use the vent fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
The best place to order Panasonic parts is Tritronics. You can also call them at 866-779-5835.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Posted on Dec 07, 2008
How do i unlock my Panasonic NN-SD787ST? All features work but want start and displays locked?
Press function pad then for child lock push pad 5, 1 in on and 2 is off this is from the manuel I have for A NN-S787BAS 787WA, 878WAS, 878LA, 787BA ETC. HOPEFULLY THAT HELPS
Jul 02, 2017 | Panasonic Microwave Ovens
Start button not working
take it to a repair shop many things can cause this problem
May 11, 2015 | Panasonic NN-H765WF Microwave Oven, 1.6...
PANASONIC Microwave Inverter #NN-SD697S. Everything works except the START button. Works sometimes, and not other times. Checked outlet, all was good.
This is either the door sensing switch (most likely) or a bad membrane switch [start switch] (that's what Panasonic calls it) on the touch pad. The contacts on the door sensing switch can be slightly contaminated and not read "zero ohms" to the control PCB. The control board thinks that the door is open and it will not allow the cook cycle to start.
Sep 11, 2013 | Panasonic NN-S251 Microwave Oven
NN 8501V Panasonic Dimension 4 Convection/Microwave oven keeps blowing fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
Apr 16, 2013 | Microwave Ovens
Button pad on microware NN-A872 not working
Customer Care Centre 08705 357357
Selected Spares and Accessories:
Order direct on line at or by
telephoning the Customer Care Centre number above.
Dec 20, 2011 | Panasonic Microwave Ovens
I got this microwave in my house, but its not working. all the buttons are not working accept stop/cancel button. please send me the sollution.
I have a similar microwave that I recently repaired. NN-9854 (bad capacitor). So your microwave functions but you cant stop it unless you unplug it, it ends its cycle, or you open the door? Does it beep when pressed? If not, you need a new control pad.
Dec 19, 2009 | Panasonic NN-T888S Convection/Microwave...
Buttons on number pad dont work , except one
HI, the key pad or, touch pad is defective. you will need to replace it asap if possible.
These key pads run about 130 dollars tops. contact Panasonic for this part.
Jun 21, 2009 | Panasonic NN-S433 1100 Watts Microwave...
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
GE JVM1440 Microwave Oven Logo
113 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
