Question about GE 24 in. GSD2220Z Built-in Dishwasher
Door leaks on the floor in front of my dishwasher
The dishwasher leaks out of the front left side unto the floor, but not all all the time.
MDL # GSD223)F)1ww
  • gman1949 Mar 21, 2009
    When I dont use detergent, I dont get the leaks at the door. When I do, I get the leaks. Its the right detergent, been using it for years.I check the lower spray arm but see no cracks.
  • hjefferson2 Apr 21, 2009
    When I dont use detergent, I dont get the leaks at the door. When I do, I get the leaks. Its the right detergent, been using it for years. I checked the detergent door from the inside of the front door cover. I found the leakage coming from the detergent box. Detergent and water is leaking inside the door cover and onto the floor. Will it hurt to use a water proof caulk to seal the detergent box?
  • 1,543 Answers
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Posted on Dec 07, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Dec 14, 2008
    Hi. I was curious to find out if you were able to resolve your leakage problem. It's always nice to get some feedback which can help with other's future problems as well. Hope you were able to get your dishwasher Fix-Ya 'ed!
Leaking door
Open the door and look inside at the lower left corner where the door gasket ends. See if there is any type of obstruction or foreign object in that corner. It doesn't take much to cause a door leak. Some door latches can be adjusted tighter. Look at the top door latch system and see if has 2 screws in it. You can sometimes loosen the screws and push the latch inward slightly and re-tighten the screws. That will make the door tighter when latched. Not all dishwashers have adjustable latch systems.
Apr 04, 2015 | Dishwashers
GE Potscrubber,Quiet Power dishwasher leaks while running
Check to see if the door baffles are intact they are little black rubber things in the front on each side of the tub. the pump seal could be leaking underneath. the wrong detergent (dishwashing detergent) could have been used.
Oct 08, 2014 | Dishwashers
Float switch dripping water onto floor while dishwaser running
You will find that the flood switch will be operating due to the leak, it will most likely be from one of 2 places:
1. Around the door seal, Give it a clean and check for splits/damage, and make sure screws on door hinges are tight.
2. Check the rollers that screw onto the inside of the dishwasher cabinet, The screws on these can come loose and cause water to run down into the base, check they are tight.
Hopefully this helps.
Mar 04, 2012 | Dishwashers
Our Hotpoint Aquarius Dishwasher BF11, built into the kitchen units is leaking steam from the door ( and starting to cause the wooden floor to bend ). Can I get a door seal for this model ? It's probably...
you gotta send the full model number,open the door and look at the very front of dw where the door closes into the machine,usually the tag is on the left side at 9 oclock,first are you positive that's where it's leaking remove the bottom kick panel and see if the motor or anything isn't leaking there too.if it is the door gasket it's an easy fix
Oct 07, 2017 | Hotpoint Dishwashers
Dishwasher leaking
Hi, Yes, it is not hard to replace...
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Feb 09, 2010 | Maytag MDB6000 Dishwasher
Water dripping from front left side of dishwasher
feel the botom of the door is it leaking from a plastic tube on the left between the door shell,if ti is you need a vent ***. good luck!
ERIC
Jan 26, 2010 | LG Dishwashers
GE 24 in. GSD2220Z Built-in Dishwasher Logo
3,047 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
