Question about Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
I have Ruud Deluxe90 furnace that runs on propane. It ran out of propane and ever since then it won't ignite automatically. We had a furnace tech here & he couldn't get it to run so I messed with it & figured out that if I reduce the air intake to the induced blower motor, the burner will kick on, but if I uncover the inlet, it blows the burner out.
    Problem Solver:
  • 14 Answers
Sounds like you need a gas valve or inlet pressure adjustment. You will need a proper pressure guage for this.
Posted on Jul 27, 2009
  • jeremy2142
    jeremy2142 Jul 27, 2009
    sounds like you need a gas valve or inlet pressure adjustment. You will need a proper pressure guage for this.
Automatic pilot light wont light on a honeywell furnace
Honeywell is a controls company and makes a variety of auto-pilots. If this is a no spark problem,does the lead from the igniter go to a big PC board or a module. If a module, check voltage to the spark module or thermostat voltage to the ignition module. If it comes from a large board, the board may be bad. I'll need more Info. if this does not cover it for you.
Nov 18, 2013 | Honeywell Power Humidifier: Furnace...
My lennox furnace works just fine except that 25% of the time the fan keeps running when it shouldn't and blows cold air
You are using too restrictive of an air filter. If the codes you are getting off the lights says anything about a high limit this is the cause of your blower running all the time. Use a less restrictive filter or have your contractor install a media filter in the system. if you reset the furnace and it does not stop running the blower you have a stuck limit switch and may have to get another or call a service tech to reset it or replace.
Oct 27, 2013 | Honeywell Power Humidifier: Furnace...
Coleman kersene furnace in mbile home, (furnace is only 4 years old--just inspected 3 months ago) However,it ran fine last night, now it will not come on unless you hit the ret switch, then it tuns 20-30...
Sounds like a fuel or ignition problem. If the unit does ignite when its reset it could be a bad Cad eye or primary control. If it does not light off when reset,DO NOT re-rest anymore and call the Heating contractor back to inspect and repair.
Dec 12, 2009 | Humidifiers
Aprilaire
Commonly outdoor wood boilers use a hot water coil mounted in the ductwork above your furnace. In this application the Ruud furnace is still using its blower assembly to circulate the warm air from the boiler to your home. If this is the case. Have your heating guy install a #50 relay on the furnaces blower motor to activate your much needed humidifier. If this is not the case and your Ruud furnace is totally independent of the boiler. Still install the #50 relay in the furnace and manualy activate the fan only feature on your thermostat.
Good luck
HVAC Teacher
Feb 21, 2009 | Aprilaire 600 Humidifier
Ruud 90 deluxe plus, in the last week blower motor noiser
George, make sure the belt is not loose flapping around making all that noise.
Not hard to change if you can get one from an hvac friend, they won"t sell to homeowners normally.
Jan 18, 2009 | Honeywell Power Humidifier: Furnace...
Runs without the furnace blower blowing
sounds like wired incorrectly. always do this? not wired into blower circuit correctly
Dec 11, 2008 | Aprilaire 700 Humidifier
Blower won't stay lit
If the fan motor is blowing out the burner then is there a hole in the heat exchanger
Jul 18, 2017 | Honeywell Power Humidifier: Furnace...
Furnace keeps running, no heat
The pressure switch is not allowing the igniter to heat up. Pressure switch is blocked or the flue is blocked. Take the draft fan off and inspect the flue. Also inspect the rubber hose connecting the fan and pressure switch make sure the ends are tight. Make sure the hose is clear and not restricted. And the pressure switch sometimes is position sensitive. I don't think it has been moved or anything. And very rarely do they go bad.
Dec 02, 2008 | Honeywell Power Humidifier: Furnace...
AprilAire 760 not running after installing new circuit board
I called the service company that put in my new furnace (FAmily Heating and Cooling in Detroit, very highly recommend these people)
Anyway they sent out a second service tech who determined that I would be better off having the humidifier wired to go on whenever the furnace fan was running instead of using the humidifier signal from the circuit board on the furnace. After he changed the wiring the unit runs fine. It is pretty likely that the circuit board was bad also.
Nov 27, 2008 | Aprilaire 700 Humidifier
Install HE220 HoneyWell , humidity not increasing in the house.
You can try installing the water line to your hot water if it is installed on cold line for more humidification. You should make sure your humidistat is up line 6" @least from humidifier for proper humidification measurement.
Feb 26, 2008 | Honeywell HE220A1019 Whole House...
Humidifiers Logo
52 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
