Question about Fuji FinePix F470 Digital Camera
Fujifilm F470: camera opens, shutter opens but no image!!!
When i open the f470 fujifilm camera the logo appears, the function of the camera appears but its not displaying what i'm pointing at. When i open or close it the shutter in the front appears to open/close properly. I was wondering what could be the problem. Any suggestion?
I had the same problem with this particular camera. Here is the necessary steps to fix your problem.
1. Take out the battery because you dont want to short anything when you're inside it.
2. Free yourself of any static.
3. Remove six screws on the outside of the camera. Note that two of the screws in the botton are not phillips head. If you have a very small flat-head screw driver that will work.
4. Pull the camera apart very carefully. Unplug the little wiring harness by pulling up the little black clip that holds it in its seat.
5. Carefully remove the LCD screen. You dont have to remove any screws here. Just carefully pull it out. There is a peice of double sided tape that holds it in in place so you will fell some resistance.
6. Remove the two screws behind the screen that holds the lcd holder in place. Theres also one or two in the left side of that.
7. Plug back in the lens wiring harness. This is where your problem was. It came unplug from probably being dropped.
8. Repeat the steps 6,5,4,3,2, and 1 to put it back together.
Hope that this fixes your problem. It fixed my camera.
Posted on Dec 29, 2008
I have horizontal lines across the screen of my fujifilm f470 camera. what would be the cause of this please
It's a faulty ccd. There are several comments on this website regarding this problem. If it's under warrantee you can return it but otherwise you either have to live with it until the whole thing dies (tapping it might help occasionally) or repair will cost around $100.
Apr 11, 2011 | Fuji FinePix F470 Digital Camera
FinePix F470 Lines on images and faded colors on photo mode.
You have over exposed pictures due to the shutter sticking.
The video is the clue to the problem. It doesn't use the shutter.
Shutter needs to be cleaned. This is no easy task im afraid
Sep 11, 2009 | Fuji FinePix F470 Digital Camera
Hi I have a fujifilm f470 finepix camera. One
Is it just the live view from the lens that you can't see ( totally blank screen), or are the icons visible?
If it still shows the icons but no live view then I suspect the shutter mechanism is stuck over the lens inside the camera.
Have a look at the lens and see if you can see the inner lens? You may have to adjust the zoom to bring the inner lens up to the end of the lens barrel.
If it is stuck then it will require removing and inspecting / cleaning.
Aug 26, 2009 | Fuji Rod Repair Kit
Fujifilm camera f470 white lines problem horizontal
your shutter is not closing over the lens completely. try taking video, that should be ok. your lens will have to be stripped down to clean the shutter
Apr 02, 2009 | Fuji FinePix F470 Digital Camera
Card full sign
Format the Card. To find how to format the card goto Fujifilm website and download the manual.
Jan 02, 2009 | Fuji FinePix F470 Digital Camera
Fuji finepic F470 - Damage Ribbon cable for menu controls
Broken ribbon cable cause key pad not functioning, you may need contact and order a key unit from fujifilm spare parts and replace it to solve  the problem.
Mar 29, 2008 | Fuji FinePix F470 Digital Camera
Fuji FinePix F470 Digital Camera Logo
144 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
