Question about Sharp AL 1631 Copier
Copier won't print while knob spins
There is a little green knob above the ink cartridge that spins non-stop when I turn on the machine; it won't copy while that wheel is spinning, and I can't get it to stop. This has been a problem from the start. Any help is appreciated.
Unfortunately it sounds like your drum ctg. has a bad cleaning blade. Get it checked out or get a new or remanufactured one. Hope this helps
Posted on Jul 24, 2007
I found if I took out the toner cartridge and reinserted it this problem corrected, but I had to do it almost all the time and now I am getting black lines.
Posted on Jul 05, 2007
Printer says cant print until cyan ink is replaced. Have replaced it with 2 different cartridges, but still wont print
You won't be able to print if one of the cartridges is out of ink. The printer will prime every once in a while thus the need for all cartridges to have sufficient ink levels to prevent damaging the printhead.
May 29, 2012 | Lexmark Interpret S405 - multifunction ...
How do i change my ink cartridge on my mfc-295cn
Hello and welcome to FixYa;
  1. Open the ink cartridge cover. If one or more ink cartridges is empty (for example Black), the LCD shows "Cannot Print (Replace BK Ink)" or "B&W Print Only."
  2. Press down on the release lever to unlock it and take out the ink cartridge for the color shown on the LCD.
  3. Open the new ink cartridge bag for the color shown on the LCD, and then take out the ink cartridge.
  4. Turn the green knob on the protective yellow cap clockwise to release the vacuum seal, then remove the cap (1). You must hold the ink cartridge as indicated in the picture below.
  5. Each color has its own correct position. Insert the ink cartridge in the direction of the arrow on the label.
  6. Gently push in the ink cartridge until it clicks, and then close the ink cartridge cover.
  7. The machine will automatically reset the ink level.
I am sending you the link that shows you illustrated pictures to help you through this.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000030/faq000230_012.html?reg=us&c=us&lang=en&prod=mfc295cn_all&Cat=7
You should be good to go!
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
May 30, 2011 | Brother IntelliFax Fax/ Phone/ Copier
Just replaced toner cartidge and after only 200 copies the red triangle in on and the green knob in the cartridge area won't stop spinning and it will not make anymore copies.
Are you sure you have all the tape and seals removed from the cartridge?
If so it sounds like you have received a defective cartridge.
The other thing to try is to remove the cartridge. Hold it level and shake side to side. Sometimes if those cartridges have been setting on end the ink will pack into the front or back of the cartridge.
Check for tape, shake it front to back , then if those 2 things dont work , replace it. It will have a warranty on it.
Aug 12, 2010 | Sharp AL-1642CS Copier
Error code E-5
Found this, it may help you Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
May 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E3 flashes when turned on
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-1
Feb 22, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Copier won't copy
Some machines have a lock so the scan head doesn't get damaged, make sure that it is unlocked if your machine has this feature.
Does the color cartridge have ink as well, as some machines do not print if eather of the cartridges is empty.
Good Luck.
Feb 22, 2009 | Brother MFC-5440 Printer
Xerox XD130df empties toner back into cartridge overflow
that really sounds like a defective toner cartridge. Either there was no developer in the cartridge or the metering blade that limits the ammount that gets onto the roller is bad.
Has to be the toner cartridge. Unfortunatly that may have also ruined the drum and cleaner within the drum cartridge. Return them for an exchange.
The reason it is running and running is that it is trying to read a patch that is developed on the drum and add toner to make a dark enough copy. And that definatly is not happening.
If the laser was not turning on, the machine would come up with a L something code. Besides if the laser was not comming on, the paged would be blank.
You can pretty much eliminate everything but the toner cartridge.
Sep 22, 2008 | Xerox WorkCentre XD130DF Laser Printer
ImageRunner 400S works, but prints a blank page
check the drum is seated well or not,check the drum drive lock, check the drum is rotating freely or not.check the chargin g rollor are seated well or not
finally replace the drum and see the result.
best of luck.
Aug 13, 2008 | Canon imageRUNNER 400S Copier
Error e5
Isnt e5 error meaning the cartridge has been previously used before?? Best bet is to hold in both the colour and black copy buttons for about 5 - 10 seconds and this should allow you to print again. If you do not have a copier/scanner, hold in the resume button. (triangle within a circle).
Sep 11, 2007 | Canon PIXMA MP150 All-In-One InkJet...
No Color Suppy Error Code
Try cleaning the print connectors on the cartridge housing area with a q-tip. This should resolve your problem, or else try to run ink cartridge test on your copier. Let me know if this fix your problem.
Mar 23, 2007 | HP 610 Color Copier
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
