Dell p1110 display monitor flashes green then shuts itself off
  • Dan
    Dan May 11, 2010
    Have you checked the connections to the pc and made sur ethe pc is turned on? When a monitor is on and the pc is off, there is no video to display and the monitor will seem like it is shut off.
  • 160 Answers
The monitor has gone bad
Posted on Dec 07, 2008
My dell 2005fpw screen has gone blank and power button is flashing green. The monitor is connected to my laptop via a docking station.
A flashing green is usually a power supply failure on the main board of the LCD and a protective shut down circuit kicks in when the voltages are not correct at the check sum.
This also depending on the circuit configuration that the monitor is in standby mode. Your user manual can give you this information.
This also may be the video card itself or a loose cable.
Check the monitor cable to see if it is secured.
Also check you resolution settings on the PC. This procedure will require you to connect another monitor to the pc to see if it will bring a signal.
If a signal is visible then the video card is ok.
If not then you will have to check the video driver for the video graphic display card and or replace the card.
Apr 17, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
The green led begins to blink very fast. The screen is dark and the monitor is cold.
that only standby mode, not yet power on. you need to check first power ckt are going to main ckt. trace parts by parts for possible defective or change value parts.
Apr 04, 2010 | Dell P1110 21" CRT Monitor
No pictures, the power light flashes a orange light
the connection to the video seems have a problem... or the video card to the mobo...
Nov 07, 2009 | Dell P1110 21" CRT Monitor
When i turn on my computer, it displays signal cable disconnect,and the restart switch doesnt function
try 2 check the cable if it is properly attached. try connect a different cable from your computer to your VGA
Jan 25, 2009 | Dell UltraScan P1110 21" CRT Monitor
Screen Display gone black
your flourescent back bulb is prolly burned out, or something is wrong with your video card. try another monitor to rule out your computer first.
Sep 01, 2008 | Dell UltraScan P1110 21" CRT Monitor
Monitor displays signal cable disconnected
Check if motherboards you connect the monitor into has a video signal frequency range that the monitor supports.
Feb 01, 2008 | Dell UltraScan P1110 21" CRT Monitor
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Monitor goes into standby when RS232<>TTL cable connected
Use original software for the device. Check to see if monitor is compatible with the motherboard
Sep 05, 2017 | Dell P1110 21" CRT Monitor
P1110 Blurry/dubble image
your beam needs calibration take it 2 a pro... windman
Jan 28, 2006 | Dell UltraScan P1110 21" CRT Monitor
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
