Question about Hamilton Beach BrewStation 47224 Coffee Maker
Permanent coffee filter
I recently bought a coffee maker and I look for a permanent filter but it's not available were I bought my coffee maker. The number on the box is 47665C. can you say me were I can have this filter. I'm from Terebonne, Québec, Canada it's near Montreal My name is Laurette Martin and my amail adress is laurettemartin@videotron.ca
  • 33 Answers
Hopefully this should help
option 1 http://www.abtecparts.com/hamilton_beach_coffee_filters.htm
or option 2
1-800-851-8900 HB customer care
Thanks and please rate me!
eric
Posted on Feb 16, 2009
Looking for paper filters for kitchen selective one cup brewer
You don't need paper filters it has a 'permanent filter'. That means it has a fine mesh nylon filter that you rinse and re-use.
Kitchen Selectives Single Serve Coffee Maker Permanent Filter Mug Included
Nov 28, 2015 | Kitchen Selectives Coffee Makers &...
The light is on to clean it and I do not have an owner's manual. Can you please explain? How do I get the light to stop blinking?
Most coffee makers are cleaned by filling the reservoir with undiluted white vinegar (3 cups). (Do not add coffee.) Remove the water filtration disk if you use it before starting. Then start the brew cycle as if making a cup of coffee (including putting a paper filter or the permanent filter in the filter basket and close the lid). Put a decanter on the warming plate. After brewing, turn off the coffee maker and let stand for 30 minutes. Run another cup of vinegar through the coffee maker. Take the decanter filled with vinegar and discard the liquid (pour down the sink drain). Rinse the decanter. Fill the reservoir with clean water and put in a new paper filter (or clean the permanent filter and put it back). Again do not add coffee. Run a brew cycle to rinse the unit. Discard the water that is in the decanter after the brew cycle. Do a second clean water only brew cycle (with new empty paper filter or permanent filter after cleaning again). However, if you notice an odd taste, repeat the rinse cycle.
You can alternatively use the Mr. Coffee Coffee Maker Cleaner (mix as directed on that package). In either case, this removes mineral deposits (calcium from hard water). For soft water, the cleaning should be done every 80 brew cycles. If you have hard water, do this every 40 cycles.
The manual is available from www.mrcoffee.com/Product.aspx?pid=121 , if I have the correct product version. For some reason this site isn't coming up for me today. Check the manual to find out if there is any specific details for cleaning that aren't shared with other Mr. Coffee products.
I hope this helps.
Oct 29, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
Just bought a new Bunn Thermafresh and it overflows coffee grounds and coffee all over. What can I do?
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Don't overfill the basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Make sure that the Pause 'n Serve button isn't sticking. (If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.)
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Nov 04, 2009 | Bunn NHB Coffee Maker
Permanent Keurig filter leaks
Are you using the my k-cup with the Keurig pre-filled K-cups? If so it won't work. There must be a needle on the top and bottom of the K-cup for this machine to work. The My personal K-cup does not have a needle in the bottom. It's only to be used for filling with your own coffee.
Sep 17, 2009 | Keurig B70 Coffee Maker
Our coffee maker overflows,coffee grinds get in coffee and overflows.
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
Jul 11, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Looking for a permanent filter for a keurig coffee maker
Hello sunflower012,
When I need accessory parts, I do a search on Amazon with model number, name and permanent filter, in your case, for Keurig .
Hope this is helpful to you! Positive feedback is appreciated. Kind regards, NormanZ
Jul 03, 2009 | Keurig Coffee Makers & Espresso Machines
Coffee brews cloudy
If the coffee grains are too fine, it will flow through the permanent filter. Use the paper filter instead. Also, make sure the lid is on the caraffe tight, or the filter basket will back up.
-Tha Mp3 doctor
Dec 22, 2008 | Cuisinart DCC-1200 Coffee Maker
Have the Cuisinart DCC-1200 coffee maker. When you begin to brew coffee it brews some of it but leaves the whole filter top full with coffee and coffee grounds. Called then customer service line and...
It sounds like you were using the gold permanent coffee filter in addition to a paper filter. You should use one or the other.
The gold permanent filter must be cleaned between each brewing cycle.
Try this:
1. Remove the filter basket from the coffee machine.
2. Remove the gold permanent coffee filter from the basket.
3. Clean the basket thoroughly. Ensure there are no grounds clogging any holes.
4. Insert a new paper filter only into the basket. Do not use the gold permanent filter for this test.
5. Fill the water reservoir with the desired amount of water.
6. Add the desired amout of coffee grounds into the paper coffee filter.
7. Replace the filter basket into its holder in the coffee machine, and close the water reservoir lid. Press firmly on top where it says, "Press to Close".
8. Ensure the glass carafe is placed correctly in its position on the heating plate.
9. Turn the Function Knob to "BREW", then flip the Power Swich to "ON"
Hope that helps.
Jul 07, 2008 | Cuisinart DCC-1200 Coffee Maker
MR. Coffee ARX23/ARX20 permanent filter
8-12 permanent filter...i also came across that "MR. COFFEE® brand" is a good brand .
Have a nice day!
tc
Jun 10, 2008 | Mr. Coffee ARX23 / ARX20 Coffee Maker
Hamilton beach brewstation
I found this site that calls it a "permanent dispencing filter" but the small print says that it is the small domed filter that sits on the bottom of the tank so I sounds like the same as the filter screen. FYI, there is a pricing conflict when you click on the part. The part link shows that it's $4.99 but when you select the part or try to order it, it comes up as $5.99. Here's the link http://abtecparts.com/hamilton_beach_brew_station_filters.htm
I will probably still call HB tomorrow and see what the want for it before I buy.
Jun 01, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Hamilton Beach BrewStation 47224 Coffee Maker Logo
91 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
