Question about Canon CanoScan LiDE 25 Flatbed Scanner
Scanner does not scan. It seems to be jammed, stuck.
Making a clicking sound and scanning arm cannot move.
Thank you,
Richard Miller
It's dead simple to clear the jam. If you already bought a new scanner, you can fix the Canoscan and sell it.
OK, first how did it get jammed in the first place? Probably because you moved the scanner without closing the lock on the bottom. The scanner arm then got jogged out of the home position.
There are two ways to go.
1) Reverse the impact that caused the jam. To check if this is feasible open the top of the scanner. If the arm is not tight against the front (where the 3 black buttons are located) then this might work. Get a cushion that is not too thick and place it on your desk. Holding the scanner in both hands stand it on end so the front edge is down and the back edge is up. Look at the back to make sure the lock is open, then tap the front edge of the scanner firmly against the cushion. Set it down and open the cover to see if the arm is now tight against the front. If not repeat two more times tapping a little harder.
If this seems to work, test if the scanner arm is in the home position. Turn to the back of the scanner and try to close the lock. If the scanner both looks like it is in the home position and you can lock the arm, then it is probably in the home position.
If this seems to work, unlock the arm of the scanner, connect to your computer and test it.
2) If this method does not work it's time for a little open scanner surgery. Open the lid of the scanner and observe the cable that runs from the front to the back. It is just a cord about 1/10 inch (3 mm) thick. Observe where it meets the back of the scanner.
Close the lid and stand the scanner on its front edge. You will see an oval patch slightly darker than the panel. Use a penknife to lift the edge and carefully peel this off and save it. You will observe a hole with a slot shaped like the letter Q, the slot being the tail of the Q. This slot keeps the cord in place. You must plug the hole befoe proceeding further to ensure that the cord does not slip out of the slot. (Mine did and it took me half an hour to figure out how to reassemble the moving parts.) Use a twig, tapered pencit stub or a wooden chopstick as a plug.
Now set the scanner on the desk, open the lid and locate the two oval plastic patches at the left and right front corners. These cannot be peeled off because they are part of the frame that secures the glass plate. You need to lift each oval patch with your penknife. First slip the penknife into the crack on the right side of the scanner just a little back of the oval patch and lift the patch. Gently wiggle the knife and slide it back to lift the whole right side of the frame. Be especially careful not to lift near the back end because there is a little lip that goes under the back side of the frame. Repeat with the left side, which is a little more difficolt to get loose. Do not try to lift off the front or back sides of the frame.
Now you are ready to remove the glass plate. Slide your penknife in the gap at the front of the plate and nudge it to the back. Gently pry up the front edge of the plate and lift it up about 4 inches (10 cm). You may be able to push the arm into the home position without completely removing the glass plate. If not, pull the glass plate forward and lift it off. You may need to wiggle it a little to get it loose. Gently push the arm to the home postion at the front edge.
To test if the scanner arm is in the home position, reach under the scanner and try to close the lock. If you can lock the arm, then it is in the home position.
Don not turn the scanner over to see the lock. This would cause the whole assembly to fall onto your desk.
Reassemble the scanner in reverse order. Unlock the arm of the scanner, connect to your computer and test it.
Send $5 to Oxfam or the charity of your choice.
Posted on May 23, 2009
Thanks for your interest. The problem appears to be in the hardware - so I'll
be visiting the store where it was purchased, to either fix it or replace the scanner.
Regards,
Richard
Posted on Dec 08, 2008
The scanner bar is stuck and will not scan or move. i am unable to print to the printer or make copies. it is making a noise like it is stuck in one position. can i turn off a feature?
sounds like it is broken or maybe some thing is jammed inside the printer if it is under warranty let service fix it. if not you may need to replace it or remove the top cover to see if it is jammed
Jan 30, 2011 | HP PSC 2210 All-In-One InkJet Printer
My Epson scanner makes whirring noise
There are a couple possibilities that can cause the problem.
1. you need to unlock the scanner. There is a lock at the side of the scanner that could be in the locked position which is preventing the scanner from moving. you can use a nickel or penny or screwdriver to turn it to release it.
2. the tab that is holding the gear is broken
3. the glass is not attached 100% to the upper case and the scanner is hitting it when trying to scan.
if its 2 or 3, you might be better off getting a replacement.
thank you
May 25, 2010 | Epson Perfection 1250 Flatbed Scanner
Scanner mechanism stuck, making loud clicking sound
I've just got this problem after a powercut, whilst it was not being used but on. If you have only had it a few months send it in warranty.
Think I will have to take this apart and see if the scanner cable/ribbon/drive belt is caught on something or been stretched too much and can be replaced at all.
Its like at one end its caught and wont move the scanning head being stuck somehow, caught on something (doubtful tho').
Apr 14, 2010 | Epson Stylus Multifunction Inkjet Printer/...
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Clicking noise scanner stuck
have you checked the scanner lock ? it should be off.
May 13, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Problem with new set
Sounds like the lock-switch is in the locked position. This is on the bottom of the scanner. Move the lock-switch back and forth a few times and then leave it in the unlock posotion. Try scanning again.
If you are scanning a book, it may be too heavy and putting enough pressure on the scanner that it is preventing the scan head from moving fully. Try scanning with nothing on the glass to see if it does the same thing.
Mar 27, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Scanning
sounds like the carrier might be jammed, lift the lid and plug the scanner in, see if the carrier assembly moves ?
Feb 27, 2008 | Canon CanoScan D1250U2 Flatbed Scanner
Lexmark aio will not scan does everything else!
all these problems seem to be with Lexmark equipment
Dont see any Epson problems, story here somewhere
Feb 14, 2008 | Lexmark X1270 All-In-One InkJet Printer
Black output
This type of issue could be related to different sources. First step I would do is check to see if the lamp is coming on within the scanner, possible bad lamp. One other possibility would be the CCD failure, it may not be moving across to capature your film. Also, when attempting to scan does the scanner sound normal or abnormal. If abnornal sound is occurring then CCD could jammed/stuck hardware failure. Last step would be uninstalling/reinstalling your scanner software, check for updated drivers from the manufacture of your scanner. At this point if none of these suggestions helped then test scanner on a different computer system.
Sep 02, 2007 | Pacific Image PrimeFilm 1800u Film Scanner...
Will not scan
With the power off & the machine unplugged, remove the scan glass & move the scanner a few inches from "home" position. Plug in & turn on machine. Does the scanner return to home position? If not, you either have a bad scanner motor or scanner cable. I'll look for you to post the results of the scanner drive test.
Jun 19, 2007 | Canon PC-1080F Copier
Canon CanoScan LiDE 25 Flatbed Scanner Logo
397 people viewed this question
old marine
old marine
