Question about Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television
Projection TV makes a chirping noise
I have a Phillips 51-inch projection HDTV (Model No. 51PP9100). When I turn it on, there is no picture and no sound. There is only a chirping noise. From what I've been reading online, it seems like a convergence amp may have gone bad. How much does it usually cost to replace the amp(s) if that's the problem?
techman
  • 3130 Answers
SOURCE: Panasonic blue convergence problem
Yea, you have to have the two convergence Amp IC's replaced. Should run you about 300 bucks or so. Good Luck
Posted on Sep 14, 2007
ctf1800
  • 4402 Answers
SOURCE: Phillips 60 inch HD rear projection? Convergence!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 21, 2008
ladywinn
  • 5138 Answers
SOURCE: corner convergence for panasonic pt51hx40c projection tv
Yes there is a Service Code you need in order to set convergence and on this set it is not easy to enter! 1) Switch Antenna to cable (2) Set Sleep Timer to 30 mins,Exit menu Enter ch 124 (3) Now Press vol- on front of TV / A red CHK should appear on screen / NOW enter menu and turn sleep timer off / Exit again,now Press Power untill you see 0V00 press ch up untill you see 0V1 Then Press vol+ you should now have convergence Pattern on screen. To adjust use (ch- ch+ and vol- vol+) (cursor) moves to where you want to adjust (mute) locks place you want to adjust RTune changes R-G-B when done make sure you Save adjustments.
Posted on Jan 04, 2009
video-tek
  • 150 Answers
SOURCE: convergence problem
Hi, you`ve lost the convergence IC`, requires a good knowledge of soldering and. posssibly an alignment after replacement, good luck, video-tek
Posted on Feb 14, 2009
jhinsincity
  • 616 Answers
SOURCE: projection tv won't turn on after replacing convergence & resist
STKs are static sensitive, your tv though, also has a digital convergence board that if damaged will cause any new ICs and resistors to fail. you need to have a technician repair this. This is why many of the DYs that seek help on the net would save money, simply by calling on a repair shop. Julio milleniumtvsvc@gmail.com
Posted on Jul 26, 2009
Chirping
Chirping sounds on that model is almost always caused by shorted converence chips. The site www.TvRepairKits.com has the parts, instructions, etc.
Jan 25, 2013 | Philips 51PW9363 51" Rear Projection...
Philips 60pp9202 I get no sound, no picture and a chirping noise
Chirping in a phillips is usually related to the HOT ( Horizontal Output Transistor) or the Flyback ( HV Generator having a issue.
Dec 11, 2009 | Philips 60PP9202 60" Rear Projection...
Turn the TV on and it just make a chirping sound no picture
Without examing the set. IN general as a techs when they hear chirping noise is an indication of what is know as a Bad Flyback transformer; You may possibly have a shorted Horizontal Output Transistor or both that will need replaceing.
Apr 24, 2009 | Philips 60PP9352 60" Rear Projection...
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
My 65 Philips inch rear projection TV picture went out. Makes a chirping noise
Whats the model number, as thats usually a bad HOT transistor or flyback the causes that. Please respond to this same post with your model number and I will try to assist you with the problem.
Jul 08, 2008 | Philips 60PP9202 60" Rear Projection...
No picture or sound - TV makes chirping noise
The chirping sound is the power supply coming up then breaking down because there is a short somwhere in the high voltage. The most common fail in this area is the horizontal output is shorted ( 237470 ) but what cause this short could be simple cold solder joints or the High voltage transformer ( 239111 ) If you have noway to "ring" the flyback change both parts
Feb 13, 2008 | RCA Scenium D40W20 40" Rear Projection...
TV makes chirping noise, won't turn on!
That usually means a problem in the start up or deflection circuits. Diode, Horizontal ouput or driver transformer. What Chassis is this set, and I will be ableto give you some better information. Rca , GE and phillips need to be diagnosedwith the chassis number. Let me know the chassis.
Jan 25, 2008 | Televison & Video
No Sound or Picture, Chirping Noise coming from back
There are many other fuses on this board you need to check them all. May need a schematic.
Dec 03, 2007 | Philips 51PW9363 51" Rear Projection...
Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television Logo
132 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
