Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
I need to find replacement parts for my Kenmore side by side refrigerator, Model #596-555510, Mfg #P1190410WW, Ser #9510162258. The door handles are worn, one of the fruit bins is broken, and the support pegs for the freezer shelf is broken. I can not find the refrigerator on the web site
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Can't find a Model #596-555510 listed. I suggest you check that again, maybe using a lupe to read it.
  • Anonymous Mar 31, 2014
    Need parts
    Scholar:
  • 62 Answers
You are missing a number in the model number. The model number most likely should be 5969555510 this number runs in the sears system. You need a number 9 in front of the 555510 try this. it seems that this is the only model that will run with what you have provided.
Posted on Dec 07, 2008
I have a Kenmore elite Model #795 7554 2501 MFg date 2005-01. The water container behind the left door is leaking I need a replacement. Can you help
in trying to locate this model # with sears data base it didn't come up. i don't know of any kenmore that has a water container behind the left door . left door being the freezer door .. the water container is located in the botttom of fresh food side in the back behind the crispers . if thers a leak in the freezer door i would think that it a water line that is carcked or come loose .. mm hope this helps .. pls reck your model # and in needed get back with me ..mm
Oct 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I need a tech sheet for a kenmore refrigerator mod # 50594000 ser
go on searsapplaince site type in your model number and it will bring up a parts list for you unit hope this helps they also have the tech sheets available there also
Jul 13, 2010 | Kenmore 50522 / 50524 Side by Side...
Paint Refrigerator Rubber Door handles
Paint usually will rub off a rubber part. You can order new handles from any appliance parts house near you or get them online.
Jan 17, 2018 | Whirlpool Gold White-on-White 21.9 cu. ft....
On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Sep 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Broken door handle needs replacing
I assume you need a paert number for the handle. according to the model number you gave I need to know the color of the refrig in order to get you the correct part number or you can go here input your model number then find youre part yourself. just remeber your looking for your color handle to be sure and get correct one. peyton
Jan 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Want to reverse door swing on Kenmore refrigerator model # 795
Actually, I have a Kenmore 795 model with the top door and bottom drawer freezer. I just tried this, based on "guru's" advice. Unfortuately, though the TOP hinge on this model is reversible, the bottom hinge is NOT. I got it all apart before I discovered this problem. Also you might want to note that the 7/16th wrench is too big for my bolts and the 3/8ths is too small. I had to use an adjustable wrench...maybe they are metric.
An allen wrench will get the handles off for you. You will find little ports for it if you look carefully.
Nov 27, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
158 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
