Question about ASUS K8V-MX Motherboard
No Display Hello, Sir, My name is Ankur. I'm doing MCA. I have a system Intel Pentium 3 machine. I have a problem of No Display. If i run a PC in SAFE MODE than it will be booted and run the OS. But if I run a PC in Normal Mode than it shows me WINDOWS XP Professinol LOGO. After some time the monitor has no signal and nothing will be seen on screen. But fan of CPU and SMPS is still running. I cann't Understand...... Please Help me.....
  • Nicolas
    Nicolas May 11, 2010
    Hellu Ankur!
    Did your pc worked whitout errors before this happend?
    Did you installed any new softwhare or hardwhare latly?
    Scholar:
  • 111 Answers
I think the problem is with the resolution of your display or the refresh rate.
Get into safe mode, and set display resolution to the lowest setting (640 x 480, 256 color).
Once, you get into normal mode, change the display setting again as necessary. Don't set refresh rate to any higher one than your monitor can support.
Posted on Dec 10, 2008
Hi i am enver parson can you tell me wot tipe of graphics card are you using
Posted on Dec 07, 2008
Sir my laptop name is lenovo G550 intel pentium inside, the problm is battery back up is 3 hours but am not getting atleast 45 min please help me
Hi Kiran
It sounds as though your battery may be failing to charge properly. This can either be due to insufficient charging time or the battery going faulty. Also your machine could be simply drawing unneeded power during use. Ways to extend battery time include dimming the display, turning off wireless connections, it all depends on what you are doing while the machine is on battery. Have you previously achieved the 3 hour battery life? if so then it is likely that the battery may be going faulty. Try to do a full charge/discharge cycle a few times to see if the life improves. Hope this helps.
Feb 18, 2013 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Troubleshoot D530 Pentium 4, i get the boot screen, over n over
Run hard drive tests, if HD tests good, and no data to keep, restore os from restore partition with f10. If data needs kept, run a repair installation of os. Run fixboot and fixmbr commands from prompt. Also try sfc/scannow from command prompt.
Nov 21, 2009 | HP Compaq d530 CMT Intel Desktop PC -...
Want my audio driver intel pentium 4 865 gv micro 478
download the driver magic and install it, while running the driver magic it will ask for login, select skip option and go further, if it ask for registration or other options give negative clicks, then it will display all your driver list, and you can find the name of your display card, soundcard, ethernet card etc.,
note down the display and soundcard name... and mail.. i will help you further.. (md_ehsan_1@yahoo.co.in)
download driver magic
http://www.symplisit.com/en/drivermagic.html
Jun 17, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
It says. message mode not supported. H:53.4KHZ V:84GHZ. It won't let me see anything. Please Help. (HP Compag xp pentium 4)
The message means that your monitor can't handle the current display settings. Try rebooting in safe mode and lowering your display settings in the control panel.
May 16, 2009 | HP Compaq d530 CMT Intel Desktop PC -...
Where can i get the sound driver for my motherboard intel d865gkd
The sound driver you need is the SoundMAX Cadenza driver. according
IBM YOUR IS http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-51191&velxr-layout=printLenovo
Thank you.
Mar 26, 2009 | Computers & Internet
Caut un driver audio pt intel pentium 3 500mhz procesor deci va rog sa ma ajutati sa gasesc
Time of this report: 2/9/2010, 11:40:13
Machine name: PC-C662274E7060
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: Italian (Regional Setting: Italian)
System Manufacturer: I.C.S. SpA
System Model: Olivetti MK800
BIOS: Award Modular BIOS v6.00PG
Processor: AMD Athlon(tm) Processor, MMX, 3DNow, ~840MHz
Memory: 192MB RAM
Page File: 212MB used, 158MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
ma puteti ajuta cu un driver audio va rog mult
Mar 08, 2009 | Intel Pentium 3 , 450 MHz Pentium III...
Problem regarding booting
due to the increase in temperature inside the cpu for the protection of the motherboard and components it might not be getting started ..
this happens if the processor fan is not running properly or if it stucked due to some dust or obstacles ...
try cleaning it after separating heat sink and processor ....
after refitting the processor trying booting it should work ....
if needed replace the processor fan ..
regards
-Dileep
Nov 27, 2008 | Intel Computers & Internet
Hp pavilion dv4420 us notebook pc/ laptop
turon your pc..pres f8 until the pc on.the will go to safe mode..
select safemode using up and down arrow.wait until the windows run.
Jul 24, 2008 | HP Intel Pentium Dual Core Desktop...
Intel 845 glly board please solve the problem
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
Intel Desktop Board D845GLLY
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
Apr 19, 2008 | Intel D845GLLY Motherboard
ASUS K8V-MX Motherboard Logo
73 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
