Question about Olevia LT27HVX 27 in. LCD Television
Tv screen is black with a "NO SIGNAL" message lower right on screen
  • Anonymous Dec 09, 2008
    I HAVE THE SAMA PROBLEM NO SIGNAL
  • 3 Answers
Check your cables and check your SOURCE. this is indicating that the TV is not hooked up correctly or your set on the wrong input.
Posted on Dec 30, 2008
My tv do not want to turn on
Posted on Dec 18, 2008
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Mac Mini - Signal is not compatible with this intput
Can you change the signal format in the display settiings? 1080p is the native one on your monitor, try difrent ones if availabe. also test difrent resolutions.
Jul 06, 2008 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
PC - TV Screen solution issues.
the resolution of your monitor is not working on your tv. Try changing the screen resolution to a different size. Right click on the desktop and choose display settings. change to either a lower or higher setting . you can work from low to high until the tv works.
Jun 15, 2013 | Philips 32PFL3505D 32 in LCD TV
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
VGA: signal out of range on Dell1800FP. I see this type of card MSI PM8M3-V (7211010VPM8M3V) Motherboard installed. I know nothing, but would connect on Vga a Dell1800FP. Message : signal out of range
You need to lower your screen resolution. Right click desktop > Properties. Lower Screen Resolution to 800x600. You mave to do this in Safe Mode by pressing F8 during boot.
Sep 30, 2012 | MSI PM8M3-V (7211010VPM8M3V) Motherboard
Hi I have sharp lcd tv 19'' when I connect from my computer hdmi output to the tv it show me black screen and give me this message (not compatible with this signal)
Hi this normally happens if the refresh rate is to high in your graphics settings for the computer, try going into control panel > appearence and personalization > click on adjust screen resolution > click display and see if your TV is listed there and select it if it is, click advanced settings click on the monitor tab and adjust the screen refresh rate to a lower setting then click apply. you may have to keep trying different refresh rates or screen resolution to get the tv to work.
many computers use manufacturers software sometimes found in the lower right of the taskbar right click there or double left click to open properties find you tv model , it should be listed somewhere click on it and navigate to the screen refresh rate and try all the lower settings usually 25hz works for the uk and euorpe and 30hz works for other countries other frequencies (refresh rates) my be higher depending on the tv you have but one of them is sure to work.
Also make sure you have the latest drivers and software for your graphics card/board in your computer.
Hope this helps
Midge.
Let me know if you managed to get it to work!
Thankyou and good luck.
Feb 10, 2011 | Sharp 19 in. LCD HDTV
Vizio TV with "No Signal" floating on screen
Tries take out the HDMI cable and replug it back in the HDMI socket.Unplug the Directv power plug and replug,press the off/on botton on again to reboot the signal.Should be every back to normal.
Sep 29, 2009 | Televison & Video
Kv-29fa210, black screen with no signal message,can hear channel
If you are running some kind of sky tv for your stations it is your scart lead fault re-fit /replace
if not some times an dvd player if attached can interfare with the signal geting through
failling all that re-set your tv and re-do serach for channels again But it dose not sound like a tv fault but a signal fault.
if none of these work get back to me on pbviewingsky@yahoo.ie- and I'll try find out more on this problem.P
Aug 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blue screen no signal
You need to replace the surface mounted voltage regulator IC (small black square chip with a metal tab on one end, and two legs on the other end.) it is on the main board, right behind the signal input board. It's a BA09FP regulator IC, you can purchase this on mouser.com
it requires a bit of disassembly, but it is relatively easy to do. it is component number IC9C25. It could be bad, or just have bad connections . This IC supplies 9 volts to the terminal board. Try resolding it first.
Jan 15, 2009 | Mitsubishi WS-65513 65" Rear Projection...
TV turning on and off
Air 2 is the source it's looking at for a signal - - where is the signal plugged into? and are you able to change the input or source to look at another?
Bill
Nov 29, 2007 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Olevia LT27HVX 27 in. LCD Television Logo
70 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
