Question about Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and
Water is warm not hot. How do i adjust the scorch guard?
Need to know how to breakdown this model and find the scorch guard feature. Need to adjust it for warmer water output?
  • 1 more comment
  • Anonymous Dec 30, 2008
    I have already tried to adjust the plastic device but still not getting any hot water only luke warm. When I turn the water on in the tub then the water in the shower will get hot enough to take a bath?
  • airhound1 Feb 28, 2009
    I have an older Delta single-handle shower/tub faucet. Showers are tepid. Other showers in huse are fine. When I dissamble the valve, I fin: retaining ring, a white plastic ball with several holes in it onto which is attached the handle. All of this is in a brass valve hosuing with tow outlets containing rubber gaskets and springs. I see no adjustment possibilities. What do I need to do to increase hot water flow through this valve to the shower head and bath outlets? Thanks. airhound1@cox.net
  • Anonymous Mar 23, 2014
    the temperature of the water is not even warm
  • 33 Answers
Here is the breakdown of the model number shown:
Delta T13420
The way to adjust the temperature is by this:
  1. Get a pocket thermometer.
  2. Turn on the water to the hottest setting.
  3. Remove handle.
  4. Check the temperature with the thermometer. (adjust to your liking, scald begins above 100 f)
  5. Set temperature by removing and rotating the plastic piece just below the handle left or right until the desired temperature is achieved.
  6. Replace handle.
This should do it.
Hope this helps and please rate this!
Posted on Dec 08, 2008
Red light off on time guard , hot water not coming on
Lets try a general answer. A time guard is a feature that prevents a unit from short cycling. This, as well as a lot of other data is programmable by the user. Repeatedly pushing the set button will scroll through all the adjustable options. Pick what settings you want at each window then press "RUN" to lock it all in. Hope this helps you.
Dec 02, 2013 | Honeywell Programmable Thermostat Heater
Adjusting Apollo hot water tank
I am not sure what you are asking, But i am going to assume that you want to know about changing the Temp on the heater for inside the house.
If the floor heat was installed properly than it should have a temperture manifold or adjustable thermostat for seperate heating.
You need to find the thermostat or manifold for the garage heat and set it at what ever temp you want the garage to stay at.
Then you can change the A B C knob to a higher setting A is cold B is warm ac is hot. So Increase your temp setting on the heater and this will increase your house water temp for hotter showers and faucet temps. However, they recommend not setting the temp above 120 degrees to prevent severe burns.
If you have a newer home increasing the Hot water heater temp setting may not change the temp at the shower or faucets if you have scald guard faucets installed in the house. This will require adjusting the scald guard valves on each faucet.
I recommend using a candy thermometer or digital thermometer to check the faucet and shower Temp prior to using them and make sure that you inform everyone in the house after you change the temp so that no one gets scalded.
I hope this answers you question, feel free to contact me if you need more help!
DR Wilkins
Oct 15, 2013 | Water Heaters
We have a Moen shower valve in our motor home and we are not getting any hot water. It has worked fine for the sence it was new. It;s a 2007
Assuming that you have hot water everywhere else my thoughts are that you have a small bit of rust,sediment or other foreign matter in the control cartridge. It's possible that the scald guard feature of the faucet has slipped so it's not allowing hot water to get thru. Either way if you purchased this new moen will provide replacement parts free.If you are mechanically inclined you can perform these repairs yourself and save significantly.Last time I checked the cartridge,scald guard balancing valve are all one part and cost about ninty bucks. Prepare to be patient and call 1-800-BUY-MOEN. You will need the model number,approx. age and explanation of your problem.Good luck. Hope this is of some help to you. Thanks.P:S they will generally provide installation,adjustment instructions and trouble shooting tips if you ask.
Nov 05, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Wateris not hot enough, need to know how to adjust scauldgard on faucetto getmore hot water, and less cold.
Assuming that you have sufficient hot water, you need to adjust the Scald-Guard valve. It's usually quite easy to do. The intent is to limit the amount of hot water that can be fed to to shower head or tub spout. On the 1300/1400 series faucents there is a disk behind the faucet knob/lever called the rotational limit stop. Remove the knob/lever, either by popping the cover off the knob and removing the screw with a Philips head screw driver, or removing the handle with an allen wrench. Next adjust the rotational limit stop disk clockwise to increase the limit on hot water flow. Delta claims each tooth you click past clockwise will increase the maximum water temperature by 6 degrees F.
Delta has a great FAQ on their web site. As of Jan 30, 2011, this link is valid:
http://www.deltafaucet.com/customersupport/faq/Water+Temperature/
If the rotational limit stop disk is already turned to the maximum point (clockwise), then you may have a hot water flow problem (either with the cartridge or to or in the manifold). The cartridges require a little more know-how to replace. You'll need to shut off the main water valve prior to removing the old cartridge. There are a couple of places that detail how to replace and/or service the cartridges, including a short video on youtube. I can post more details on this if you find you need to replace the cartridge.
Oct 06, 2010 | Delta & Single Handle Shower Faucet
What Temperature is crease guard. also fast wash on hoover 1300
usually crease guard is a combination of hot and cold (warm depending on water temp and water pressures)
Hoover fast wash is generally a shorted time cycle of the normal washes
Nov 20, 2009 | GE S8000E
Cold water only from single-arm shower faucet in master bathroom
Yes - This is an easy (though not widely known) diy fix! Remove the cover of the faucet handle (may pop off if crystal type or use a screwdriver to remove the screws) inside there is a scald guard safety mechanism - using a flathead screwdriver, turn the guard some the left. There should be a guide so that you do not turn the water up too hot. If there is not, you may need to consult a plumber or supplier in order to adjust the hot to a moderate temperature.
Hope this helps! ;)
Aug 27, 2009 | Kohler Home
Not enough hot water
Some higher end models do have an adjustment that is behind the face plate. You would have to remove the handle and the screws in the faceplate to expose them. If you have adjustments they will be located on the brass valve body facing you. You will need a flashlight and a flathead screwdriver to make the adjustment. If your model is not equipped with adjustments you could have a faulty valve stem. The stem is comprised of a rubber band like gasket that separates port holes into which the waters flow. There could be some piece of trash blocking the port not allowing adequate water from the hot side into the valve.Some valves stems are also able to be installed upside down causing the same issue as the ports do not rotate fully to allow adequate supply. However you say that you have adequate pressure on the hot side but not warm enough. There is another possibility also based on the way the shower supply was plumbed but there is no need to go into this unless this does not resolve your issue. I hope this is of assistance and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Oct 20, 2008 | Home
Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and Logo
1,469 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
