Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic pt47wx53 i think i have a convergence issue. i did the 9 point test and everything lined up good with the white crosses. but the picture size is still larger than the screen(like its in zoom mode).and in only one of the apect ratios the picture is ok but the sides are black on each side for about 2 inches. when i took the back cover off the mirror looked like it had a green prizm to it. is this normal? i thought it would be clean like a bathroom mirror. i this something easy to fix. also what kind of solder, heat paste and wattage of iron should i buy in needed and where to get these products? thanks
  • Panasonic Master
  • 5,138 Answers
Getting into and setting convergence on these sets can be a DOG so if you do not have correct information you can shut set down when adjusting, make sure you get sams on convergence.
Posted on Dec 10, 2008
The screen is a grainy and most of the time its almost as if there are is a delay in the picture its as if there are two of everything. but the picture is fine if it is a slow moving sceen.
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergnce select that and wait a minute the TV will adjust itself and give you a clear picture. If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the curser (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It taked time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture. You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch. RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
You can pay somebody to do it, but may cost you like 100.00 dollar or do it yourself, it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
. Good luck and if you still have the owners manual
May 12, 2011 | Panasonic PT-51SX30 51" Rear Projection...
Everything has red highlights. but adjusting with the remote does not change things to correct the problem?
Go into the menu with your remote a click on picture next scroll down to convergence and click on it. Follow the on screen instructions on how align or converge the diffrent color lines togeather. It will usually have a white cross on the the screen. This should solve your problems if not have a tech replace the 2 convergence chips in the back of you set
Aug 13, 2010 | Panasonic PT-47WX49 47" Rear Projection...
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Have aligned all the + signs already but is still out of focus!
with the original remote go into the customer menu and find CONVERGENCE---you will be able to adjust a single cross and also if you continue it will give you several points on the screen with a grid of lines----what you are looking for is does the red and blue adjust in all areas----if either will not adjust up/down and left right---you have a convergence problem--need to replace both convergence IC's and then align the convergence. Hope this helps you.
Aug 09, 2009 | Panasonic PT-51HX40 51" Rear Projection...
Replaced convergence board, but can't adjust convergence
Bad chips or faulty soldering....
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 10, 2009 | Zenith R40W46 40" Rear Projection...
Alot of red and double image
I had same problem. First went in tomenu and went to set up settings and went to convergence area. I then reset this back to default, which I later was told I should have not done so do not attempt this it will temporarily fix issue but problem will persisit.
I found a local tv repair man thru tvrepairguy.com or something like that as they are hard to find.
The issue turned out to be the convergence boards or circuits, He then went in to master control and rset the convergence settings for the main picture by lining up the red and blue lines on to a white cross on the screen until it is black and white with no red or blue protruding vertically or laterally. He then did this for 7 points around center picture moving the lines. He suggests you play with this for awhile in a position you would normally sit in and at proper eye level to give you the truest picture for alignment. The part cost 109 to replace with labor and service total was 331. The repairman was very nice and explained the issue should be fixed and we should get another 6 to 7 years out of television.
Hope this helps,
Dec 04, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Convergence On Panasonic PT-47WX54j
You dont need codes for the service menu you need to repair the convergence circuit. If the lines wont line up in the customer menu they wont line up in the service menu either. Do you know how to solder? If so we can fix this yourself with a little instruction. Otherwise you will need to call a repairman. A good repairman will run you $300-$500 depending on your area. Let me know what you want to do.
Tim Nolan
Sep 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Red shadows
Iam having the same issue where i cannot align the RED color ,iam elect savy so if any one can guide me to repair it i would be able to do so
Dec 01, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Picture not lined up
You will need to replace the convergence ICs I'm afraid. Then do another alighnment. If you already replacxed the IC's, you most likely did not get the exact replacement ICs recommended by the service manual, but whats called after market type IC's, and they just wont do!.
Jun 09, 2007 | Panasonic PT-51HX42 51" Rear Projection...
Convergence
If the CRT Projection television has several colors or one that arent lining up, if due to an impact - you may have a broken mirror, if just happened all by itsself it may be a convergence issue, either issue is repairable, probably for around $400-$500. I dont recommend taking a set like that into the shop as sometimes transport can break/crack a mirror or throw convergence off.
Sep 30, 2006 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
101 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
