Question about LG LMVM1935 Convection/Microwave Oven
LG over the stove model lmvm 1935
Tuntable is noisy and doesn't turn as smoothly as it used to but does still turn
  • LG Master
  • 9,098 Answers
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
In some cases, cleaning them helps. Lubrication is not recommended.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
Posted on Dec 07, 2008
It makes that same noise when I turn it by hand.
Its still noisy with out the glass top.
What could I clean to make it better, or what would be possible solutions?
Posted on Dec 08, 2008
LG touchpad doesn't work
use the common sense,logically, fix it. God bless you
a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Aug 02, 2012 | LG Microwave Ovens
Can,t turn the over the stove lighting on
Replace the bulb. If that doesn't work, the "Membrane switch" under the plastic film control panel is damaged. There is no good way to fix them. Contact hotpoint to see if they still have replacement panels available for this model. If not, either live without the light or replace the whole microwave.
Sep 24, 2011 | Hotpoint RVM1625 Microwave Oven
HI I HAVE A LG MICROWAVE OVEN MODEL# LMVM 2277ST ;1100W IT WORK BUT SLOW IT TAKES TIME TO WARM THE FOOD
I see by looking at the owner's manual there is an option to set power level from 0% to 100%, maybe that is set too low (see page 14 of manual). If don't have manual for that model (LMVM2277ST), can get from this web page (look near bottom of page and click words "owner's manual" that are underlined) :
http://www.ajmadison.com/cgi-bin/ajmadison/LMVM2277ST.html
Jan 15, 2011 | LG LMV1625 1000 Watts Convection /...
Plate will not move back and forward
That is either tuntable motor or turntable motor coupler, depending if the motor is working or not. If the turntable is stuck it is more likely the coupler located underneath the plate.
Apr 20, 2009 | LG Over-the-Range Microwave
Microwave Does Not Heat. Timer Works.......No Heat Display shows F-9 LG Microwave Oven/ Household Model LMVM 19455 SB Mfg. 2003
Test the high voltage capacitor,the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 12, 2009 | LG LMVM1945 Microwave Oven
Ge spacesaver turntable will not turn
my mocrowave turntable will not turn but it will heat up.
Dec 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replace oven ligh on LG microwave
Hello Bob,
Here is a link to the service manual for your micro.. you should find everything you need to know about testing it and disassembling it as well.. Hope this helps you..
http://136.166.4.200/contents/Microwave/LMVM1945xx/LMVM1945_Service_Manual.pdf
Hope this helps you.. if it does, please rank this response accordingly..
Good Luck
Sep 30, 2008 | LG LMVM1945 Microwave Oven
Take microwave door apart completely on a lg 1935 sb microwave?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 01, 2008 | LG Microwave Ovens
LG LMVM1935 Convection/Microwave Oven Logo
287 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
