Question about RCA F36645 TV
No audio / speakers blown.
I have an RCA P52755ST rear projection TV in excellant condition; except the speakers have gone bad. Where do I get replacement speakers?
  • 88 Answers
I would just take one of the speakers out and take it to a electronics or t.v. dealership and see if they can get you something of equal value.
Posted on Dec 07, 2008
I think my speakers are blown on my sony 53 inch rear projection tv can I run the sound through my home theatre and bypass the blown speakers?
check your audio menu on your tv. mine can turn off the speakers and sends the audio signal out the rca's when the speakers are off.
Oct 25, 2010 | RCA P52960 52" Rear Projection Television
Service convergence alignment procedure
Most non-LCD and plasma TVs have to be manually adjusted with special tools that are used to adjust the internal comparator circuits that align your image. It could be a cheap repair job at a shop.
Jun 04, 2010 | RCA F36645 TV
I PLUG MY SPEAKER WIRES INTO THE BACK PART OF THE TV, BUT FORGOT TO UNPLUG MY WIRE FROM THE RADIO AN TURN THE RADIO UP AN THE TV WENT OUT. NOW THE TV HAS NO SOUND AND IT KICKS ON AND OFF. TV REPAIR MAN...
Very bad!! By connecting the radio and the TV to the same speakers at the same time, the TV lost and you have blown up the audio amplifiers in the TV. this type of failure can involve a short circuit in the amplifier which could cause the TV to turn itself off as a protection measure.
Didn't the repair person tell you all this?
Dec 27, 2009 | RCA D52W19 52" Rear Projection Television
The tv acts like the cable has gone out even though it has not. on my mitshubishi rear projection 52 in
do you have the yellow video and red and white audio rca cables ?
it will give you a better picture than the coax connection.
but the tv tuner may be going , so using the rca jacks would eliminate the tuner, but finding out which tuner is bad ( cable box if using one or the tv tuner)should be checked with another tv to see if it also happends to that tv , if it does not then the other tv tuner is bad and needs to be replaced
Apr 18, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Sound won't work on RCA D52W25 TV
first things to check in settings check to see if the settings to make sure the set is set to internal amplifer. not external. there two other things this can be the speakers if blown or the audio amp is blown if the amp is blown the the main board will need replaced. Tech have special equipment needed to replace this and at my shop it would run about 250
Apr 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No sound
there is a switch on the back of the tv that has internal and external speakers slection i would check that especialy if you have hooked up any new componants
Dec 07, 2008 | RCA P46924 46" Rear Projection Television
Volume distortion only on tv setting
RCA HAD A CERTAIN MODEL SERIES THAT HAD A REALLY BAD DESIGN,,IT SEEMS THAT SOLDER CONNECTIONS STARTED BREAKING LOOSE AND DEPENDING WHERE THEY CAME LOOSE,,YOU WOULD HAVE PROBLEMS IN THAT CERTAIN CIRCUIT..TO DETERMINE IF YOU HAS THAT SERIES,,WE WOULD NEED THE CHASSIS # ON THE BACK...
IF THE CONNECTIONS CAME LOOSE IN THE VERTICAL CIRCUIT--THE PICTURE WOULD CLOSE UP ,,IF IN THE TUNER SECTION--YOU WOULD LOOSE CHANNELS ,,IF IT WAS IN THE AUDIO SECTION--YOU WOULD GET CRACKLYN SOUND OR NO SOUND
ONE THING YOU CAN TRY--PUT IT BACK IN THE TV MODE,,GENTLY TAP ON THE CABLE CONNECTOR IN THE BACK OF THE SET AND SEE IF IT CLEARS UP,,IF SO YOU HAVE THE CONNECTION ISSUE--WILL NEED A TECH..GOOD LUCK ..TUNICA
Oct 30, 2008 | RCA P52926 52" Rear Projection Television
Blown internal sony tv speakers
in menu(button on remotr) ,,scroll right to audio ..scroll down to speaker and turn them off!
Jan 26, 2008 | Sony KP-57WV600 57" Rear Projection...
Sound gone on tv big screen guideplusgemstar
this you forget the MUTE buttom on the remove control?
Dec 01, 2007 | RCA P52926 52" Rear Projection Television
Tv below listed on ebay i'm interested in buying not sure if worth or what repair would be?
Depends on how much do they want for set repair cost verys anywhere from 250 up to 375.00.Set might only need to realine convergence on customer level.
Sep 09, 2007 | Panasonic PT-47WX53 47" Rear Projection...
RCA F36645 TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
